Old 05-29-2013, 06:29 AM   #16
Labar
Labar's Avatar
Oddometer: 10
Had the same...
Hi,
my 2011 did exactly the same thing after 3 months or so. The fault was it the starter relay (exactly on the picture few posts above). Nothing looked suspiciously, clear contacts, but it was dead inside. It happened on a one-week trip, so I had to start her with screwdriver shortcutting the contacts next to the relay (works fine)
Relay replaced and bug solved.
L.
Labar is offline   Reply With Quote
Old 05-29-2013, 07:04 AM   #17
renogeorge
Oddometer: 1,382
Relays
The relay on the battery box is the one you should concentrate on first. The other 2 are part of the "safety" system--side stand/clutch, etc.
If you need some help troubleshooting, give me a call. I sent you an e mail
KTMs--300, 518, 990
renogeorge is offline   Reply With Quote
Old 05-29-2013, 09:47 PM   #18
Big_John OP
Colorado Rider
Big_John's Avatar
Oddometer: 2,985
Doing a trip with the wife for our 25th.....but upon returning.....I may ring you.
John
2004 KTM 950 Adventure S
2004 BMW R1150RT
2003 KTM 450 EXC
Pointing the Way http://www.gracemotoadv.com
Big_John is offline   Reply With Quote
Old 06-21-2013, 10:43 AM   #19
Big_John OP
Colorado Rider
Big_John's Avatar
Oddometer: 2,985
Finally, after digging and digging...... I found a wire that had pulled away from a connector. The wire was to run into one of the Safety Starter Relays that are located up under the cowling on the left side.
Now she runs like a top!!!! Thanks to you all for suggestions and help.
John
2004 BMW R1150RT
2003 KTM 450 EXC
Old 03-11-2015, 12:13 PM   #20
DeeGee
I'm a Yorkshireman thanoz
DeeGee's Avatar
Oddometer: 1,882
After servicing the bike the last couple of days, she now won't start. Dash lights up, fuel pump primes (purring). Thumb the start button and nothing, but a thud followed by clicking (solenoid?). I'm not too hot on electrics, but this is a great help, I'll start checking the starter relay tomorrow and have a go at bridging the relay to see if it works.
OC. Simply the best.
DeeGee is offline   Reply With Quote
Old 03-11-2015, 12:46 PM   #21
Falconfixer
It is what it is....
Oddometer: 573
I had the same problem with my 950 last summer, and the culprit was the junk connector on the red/white wire behind the left hand fuel tank fairing. Ruined two trips for me. Grrrr......
Good luck in your troubleshooting.
Falconfixer is offline   Reply With Quote
Old 03-12-2015, 12:35 AM   #22
DeeGee
DeeGee's Avatar
Oddometer: 1,882
Old 03-12-2015, 09:50 AM   #23
Falconfixer
Oddometer: 573
Originally Posted by DeeGee View Post
Got it solved now, DG?
Old 03-13-2015, 01:17 PM   #24
DeeGee
DeeGee's Avatar
Oddometer: 1,882
No man, don't know wtf I've done, engine won't turn past tdc CCW. Stumped!
Times are GMT -7.   It's 02:23 PM.
