Old 06-19-2013, 07:23 AM   #16
JM
JM's Avatar
Oddometer: 781
Originally Posted by rotaryracer View Post
Hi JM - there is a foam gasket on the back of the door. It compresses when you lock the box and does a nice job of keeping things dry.
Any other questions, please let me know.
One more question for you. Is the door opening wide enough to get a quart of oil inside? I'm looking for a way to stash engine oil away from the things inside my panniers.
Thanks for the speedy reply to my first question.
John
Postponing retirement one farkle at a time!
JM is offline   Reply With Quote
Old 06-19-2013, 08:24 AM   #17
rotaryracer OP
rotaryracer's Avatar
Oddometer: 634
Hi John - the door opening is 2.375" wide by 5.5" high with the door completely removed from the box (it lifts out versus being hinged). I don't have a quart of oil nearby at the moment to measure, but hopefully that size opening will work for you!
Thanks...
Jason Smith
www.advmotorrad.com
Check out the ADV Motorrad vendor thread for great deals on adventure gear!
rotaryracer is offline   Reply With Quote
Old 06-19-2013, 08:55 AM   #18
JM
JM's Avatar
Oddometer: 781
I just measured a Qt of oil. It looks like it should work but it will be close. Any chance you can try and put a Qt of oil in a box and let me know how it fits?
John
Old 06-20-2013, 07:25 PM   #19
arraflipper
Oddometer: 460
Nice idea
Will have to think hard about this as they look well made and seems I always can find something to put in any available spot.
arraflipper is offline   Reply With Quote
Old 06-21-2013, 03:17 AM   #20
rotaryracer OP
Oddometer: 634
Thanks guys - I've been away from the shop this week on travel but will get some additional measurements and update the list of group buy participants. At a quick count, I think we are at five deposits, so there's a good chance we will start kicking up into new discount tiers soon!
Thanks again...
Jason Smith
www.advmotorrad.com
Old 06-21-2013, 03:42 AM   #21
Texas Aggie
Texas Aggie's Avatar
Location: Nanjing, China and sometimes..... Dallas, Texas
Oddometer: 96
I just put my deposit down. Great idea
DT
Keeping the rubber side down........most of the time!
Texas Aggie is offline   Reply With Quote
Old 06-21-2013, 04:17 AM   #22
rotaryracer OP
Oddometer: 634
Thanks Texas Aggie!
I managed to catch a stable WiFi signal and we are at five deposits, which means the group buy is in the **% discount tier. There's still a few days left to kick that up to **% (or better!), so if you've got friends and family with Hexhead/Camhead GS Adventures, let 'em know about the awesome deal on ADVrider!
I've received a couple of questions on finish. The boxes are raw/natural aluminum and are not put through a finishing, clearcoating/anodizing, or polishing process, so you'll get some "character marks" in the aluminum as part of the production process and from being moved around the manufacturers's workshop. It's usually nothing you'll even notice after a few miles mounted on the bike but just want to set the right expectation. If you want to spiff up the cosmetics, we've had a few folks take their raid boxes off at the end of the season and use steel wool or Scotchbrite pads with WD-40 to give it that brushed aluminum "Exile" effect.
Jason Smith
www.advmotorrad.com
rotaryracer screwed with this post 07-02-2013 at 04:22 AM Reason: Group buy ended
Old 06-21-2013, 05:43 PM   #23
arraflipper
Oddometer: 460
Deal
Looks like to good of deal to pass up, I just ordered one. Hope a few more people get in and everyone saves a little more.
Old 06-21-2013, 08:32 PM   #24
Hikertrash
Oddometer: 2,768
JM,
I just received a new one from Jason and they will fit a quart of oil in it. Nothing else will fit, but it'll fit in there. Just be aware that there's sharp rivet nipples poking all over the inside so its possible they might puncture the bottle if you go offroad.
Hikertrash is offline   Reply With Quote
Old 06-21-2013, 09:27 PM   #25
JM
JM's Avatar
Oddometer: 781
Originally Posted by Hikertrash View Post
JM,
Thanks for the info. Is there enough room leftover inside the box with the oil in it to glue a thin layer of rubber mat or something else to cover the rivet heads?
John
Old 06-22-2013, 12:00 PM   #26
rotaryracer OP
Oddometer: 634
Hey guys - just did some measuring on a quart of Formula Shell oil and the dimensions (of the quart) are 9" tall by 4.25" wide by 2.5" deep. The quart just passes through the box opening, but it will slip through fine. I took a few shots of it in a first generation demo toolbox (no angle cut at the front), but confirmed against a Generation II box that it will fit nicely with the spout inserted first. When the quart is in the box spout-in, you'll have about 2.5" behind and above the quart, and approximately 0.5" on the side (or 0.25" on each side).
I've also included a picture of the box with nothing in it so you can see the rivet construction and threaded inserts for the mounting brackets. There's also a shot of the back of the toolbox door to show the foam gasket (ignore the missing lock - yours will come with one!).
Hope this helps...any other questions, please let me know!
Jason Smith
www.advmotorrad.com
Old 06-22-2013, 04:24 PM   #27
Hikertrash
Oddometer: 2,768
Yes, there's room for a mat in there. I was thinking of wrapping the quart in duct tape. 2 layers should prevent any damage.
Old 06-23-2013, 07:16 AM   #28
WEEZAR
WEEZAR's Avatar
Oddometer: 9
That looks Awsum!!! I want one! Any thoughts of making for 13 LC ?
WEEZAR is offline   Reply With Quote
Old 06-23-2013, 09:13 AM   #29
rotaryracer OP
Oddometer: 634
You bet! I don't have a firm release date yet, but DS Bike has already been prototyping parts for the new LC. Stay tuned over the next few days for a dedicated thread for just LC parts!
Jason Smith
www.advmotorrad.com
Old 06-23-2013, 12:25 PM   #30
WEEZAR
WEEZAR's Avatar
Oddometer: 9
Will do !! Thanks
Times are GMT -7.   It's 01:09 PM.
