Old 06-23-2013, 01:26 PM   #17386
Chris_W_65
XR KILLER
Oddometer: 51
Originally Posted by stevh0 View Post
whats the easiest way to fit a keyed ignition? Bike needs to go for road worthy and I doubt they will pass it without.
I have one on my bike - I can take pics but everything is in pieces right now
Chris_W_65 is offline   Reply With Quote
Old 06-23-2013, 04:56 PM   #17387
smoothride
smoothride's Avatar
Oddometer: 234
Originally Posted by slabm7 View Post
I need some carb help guys, I recently installed a Mikuni TM40 and am having problems tuning it, the bike won't idle below 1800 rpm, as soon as it drops below that it sputters and quickly dies, the idle also hangs when I let off throttle, it will hand around 3000 and then very slowly drop. I have played with the idle adjustment and the pilot screw, also put in a larger pilot jet but I am not having much luck. Anyone have any ideas on where to look next?
Try putting a bigger pilot jet in I run a 27.5 pilot and a 140 main jet. Your bike sounds like it is leak on the pilot. Check the throttle cables for slack.
00 XR650R plated
08 DR650
smoothride is online now   Reply With Quote
Old 06-23-2013, 06:52 PM   #17388
ride4fun562
ride4fun562's Avatar
Oddometer: 209
Hey guys , this has probably been asked before but i just installed bar risers, i tried to re route the cables but it only worked for the clutch, the decomp cable is getting caught when i turn my bars to the right. Does anyone know if theres an oem decomp cable.from another bike thats an inch or two longer. I dont want to buy custom cables . Thanks in advance
ride4fun562 is offline   Reply With Quote
Old 06-23-2013, 07:05 PM   #17389
Adamco2
Part time adventurer
Adamco2's Avatar
Oddometer: 127
I rerouted mine like this
Adamco2 is offline   Reply With Quote
Old 06-23-2013, 07:24 PM   #17390
ride4fun562
Oddometer: 209
Honestly that will probably work but i have ocd about dumb stuff like that, itll annoy the heck outta me but if nobody knows of another cable that will work ill do that
Old 06-23-2013, 08:51 PM   #17391
Adamco2
Adamco2's Avatar
Oddometer: 127
I understand. That was a middle of nowhere fix that I have been to lazy/cheap to rectify.
Old 06-24-2013, 03:11 AM   #17392
BuRPsa
Finally growing up..
BuRPsa's Avatar
Oddometer: 548
... I doubt they will pass it without.
I don't, an ignition key's not mandatory - only a kill button which I presume you have.
BuRPsa is offline   Reply With Quote
Old 06-24-2013, 05:00 PM   #17393
bill pierce
I don't wana pickle
bill pierce's Avatar
Oddometer: 741
[QUOTE=stevh0;21707660]whats the easiest way to fit a keyed ignition? Bike needs to go for road worthy and I doubt they will pass it without.[/QUOTE
I used a Honda switch and a relay so it would be a little harder to steal. But just a switch that is open in the on position parallel to the kill button will work
bikes
BMW R1100s,destroyed by deer strike.
Yamaha FZR 1000 (sold)
Honda Cr 500 sold
bill pierce is offline   Reply With Quote
Old 06-25-2013, 08:14 AM   #17394
crypto666
Oddometer: 1,342
Dried blood on the tank and handle bars will keep people from stealing it too, maybe scatter some spent shell casing around the scene, a little yellow crime scene tape, the bike isn't going anywhere.
crypto666 is offline   Reply With Quote
Old 06-25-2013, 11:21 AM   #17395
stevh0
Super Retard.
stevh0's Avatar
Oddometer: 1,461
meh,my indicators on the pig is dead. I've got a broken rear turn signal too. Could this be the reason that none are working?
06 950S, YZ250WR, 300 TXT Pro
Ex 1150GS, 650R, Ex 950SE, Ex 950ADV,Ex SM610, FS570, WR450, Africa Twin(s)
stevh0 is offline   Reply With Quote
Old 06-25-2013, 11:22 AM   #17396
stevh0
Super Retard.
stevh0's Avatar
Oddometer: 1,461
[QUOTE=bill pierce;21717666]
Thanks bud!
Old 06-25-2013, 12:06 PM   #17397
crypto666
Oddometer: 1,342
Yes, most likely,
Old 06-25-2013, 09:49 PM   #17398
Gunga Galunga
Gunga Galunga's Avatar
Oddometer: 230
Bill Pierce
Since I'm a simpleton, do I understand to add the switch before the kill button?
Thanks.
2001 Honda XR650R (Plated)
1992 Yamaha WR500ZD
Gunga Galunga is offline   Reply With Quote
Old 06-25-2013, 09:58 PM   #17399
jesusgatos
fishing with dynamite
jesusgatos's Avatar
Oddometer: 2,393
padlock (through the rear disc rotor) > keyed ignition
jesusgatos is offline   Reply With Quote
Old 06-25-2013, 11:26 PM   #17400
Capt. Egregious
Capt. Egregious's Avatar
Oddometer: 376
Here is what I use. Stock Honda switch.
Capt. Egregious is online now   Reply With Quote
Times are GMT -7.   It's 09:41 PM.
