Old 04-19-2013, 03:36 PM   #61
mezcal
mezcal's Avatar
Oddometer: 449
I got it thanks, im a short ass at 5'8", 2" rise should be fine as when I am up on the pegs the bars seem a little low.
mezcal is online now   Reply With Quote
Old 04-20-2013, 03:09 PM   #62
dep411
dep411's Avatar
Oddometer: 150
Nice stuff
dep411 screwed with this post 04-20-2013 at 04:41 PM
dep411 is offline   Reply With Quote
Old 05-08-2013, 04:40 AM   #63
mezcal
mezcal's Avatar
Oddometer: 449
All fitted up but throttle cable seems a little tight with 2 " risers. Can't remember if this was the case before, catches on radiator overflow cap.
Awesome bit of kit, credit to you rbott
Old 05-08-2013, 06:18 PM   #64
Brown Dog
North Georgia Dual Sportr
Brown Dog's Avatar
Oddometer: 1,947
Are the throttle cables routed BEHIND the bars
Brown Dog is offline   Reply With Quote
Old 05-09-2013, 12:46 AM   #65
mezcal
mezcal's Avatar
Oddometer: 449
Yep, they seem ok its just me .
Feels so much better than before, 1 hand off the bars and not even a slight wobble. Yet to hit the rougher trails, thats weekend stuff
Old 05-17-2013, 10:35 AM   #66
christian
Exchange your GPS Track!
christian's Avatar
Oddometer: 2,609
hi Rbott
do you sell just the pin mount without the handlebar/triple mount?
if yes - how much?
thx
KTM 950 ADV '05.5
KTM 690 '10
christian is offline   Reply With Quote
Old 05-19-2013, 06:00 PM   #67
Rbott OP
Oddometer: 382
Originally Posted by christian View Post
hi Rbott
if yes - how much?
thx
Yes, the frame bracket is $124.95 plus shipping. Email or PM if you would like to place an order.
Ryan
2014 Husaberg FE350
2004 KTM Adventure 950
Underground Machine LLC
Rbott is offline   Reply With Quote
Old 05-19-2013, 06:24 PM   #68
sdd04
Location: The Ozarks....SW MO, NW AR-great place to play!
Oddometer: 798
Ryan
Does the steering lock still work with your frame bracket?
sdd04 is offline   Reply With Quote
Old 06-25-2013, 09:04 PM   #69
gen
gen's Avatar
Oddometer: 802
Hi Rbott,
Your setup looks the cleanest out of all of the options out there.
Have you had anyone set up with Fasstco Flexx bars? I'm trying to figure out whether to add more rise on the frame bracket or add more rise from the bars.
Thanks in advance,
DoD#1458 | GaijinRiders | 2010 KTM 690 Enduro
gen is offline   Reply With Quote
Old 06-26-2013, 07:18 PM   #70
Renazco
Formerly AKA Boejangles
Renazco's Avatar
Oddometer: 4,744
Newly designed system with built in handlebar cradle.
Optional risers should one want to use 1" or 2" rise increments, threaded for 1" Ram ball/ GPS, roadbook, smartphone, etc
Ryan does a great job
We have a few left in stock and more being manufactured, let us know if we can help.
690 with Flexx bars,
Seats www.renazco.com
Parts & Accesories www.renazcoracing.com
Renazco is offline   Reply With Quote
Old 10-07-2013, 06:37 PM   #71
Tug Boat
Oddometer: 15
Top bit of gear Ryan fitted perfect and looks great this is the one to buy .
Fitting took a bit over an hour.
KTM 690 R 2013 New Zealand
Tug Boat is offline   Reply With Quote
Old 10-22-2013, 01:24 PM   #72
vegemanNZ
Oddometer: 50
Using Rox anti-vibe risers as well.
Hi,
I have standard bar clamps with rox anti-vibe risers. the height above standard must be at least 2" which works well for me and also works with the cables etc.
With the risers there is plenty of room for the scott damper to fit underneath but I would need a very thin triple mount/bracket so as not add extra height to the bars.
BAsically, I don't want to get rid of the rox units yet...so am looking for a real low profile plate. Rbott's nicely machine block seems like the one, and the lowest height is 1"...but as mentioned, that would still add too much height overall.
I was wondering if I could use the rbott 1" mount, and then cut down the standard bar clamps by 1" meaning the overall heught remains the same OR perhaps recess the mount to accept the standard risers.
The other option I guess is to get rid of the rox risers...but I like them.
Thoughts?
2008 KTM 690E - Adventurotard - forget dual sport, get triple sport!~
vegemanNZ is offline   Reply With Quote
Old 10-22-2013, 03:29 PM   #73
Rbott OP
Oddometer: 382
Originally Posted by vegemanNZ View Post
Hi,
Thoughts?
A 1" submount and the stock height bar clamp is the shortest you can go without the handlebar hitting the top of the steering damper. I would recommend getting rid of the Rox risers and using my 2" submount with the KTM PHDS bar mounts. It will be a much better set-up than the Rox risers......
I can supply the whole set-up. PM or email me if you have any questions or would like to place an order.
Ryan
2014 Husaberg FE350
Old 10-22-2013, 04:54 PM   #74
Brown Dog
Brown Dog's Avatar
Oddometer: 1,947
... I would recommend getting rid of the Rox risers and using my 2" submount with the KTM PHDS bar mounts. It will be a much better set-up than the Rox risers......
Ryan
+1
Listen to this Wise Man
The Rox are VERY WEAK & will Bend Easily when bike is dropped.
Old 10-22-2013, 05:38 PM   #75
vegemanNZ
Oddometer: 50
Ryan
I'm sure you will be right, let me get home tonight and measure things up...as I don't want to go lower than the current height as I've finally got everything in the right position for standing.
Let me know the pricing for a complete set...you can PM me if that is better than posting to forum
Ship to New Zealand (ps did Marty from NZ get one?)
Times are GMT -7.   It's 04:36 AM.
