Old 06-29-2013, 04:59 PM   #13321
DR Steve
DR Steve's Avatar
Oddometer: 323
As Bergdonk mentions, keeping a good front sprocket makes a big difference to chain life.
I too change them out around the 6K mark.
'13 DR650
DR Steve is offline   Reply With Quote
Old 06-30-2013, 03:25 AM   #13322
CCCC
Oddometer: 290
Originally Posted by Big Willy View Post
Here you go...
TORPEDO7 Motorcycle Wheel Balancer | Buy Tools Online | Shop @ Torpedo7
Before I bought one of these, I used car axle stands and a bit of round steel.
Definitely balance with rim locks or do away with them. As Nordie says it'll drive you bonkers before long and it'll put a toll on your shockie and linkage bearings
Thanks, just ordered one. Looks good
CCCC
CCCC is offline   Reply With Quote
Old 07-11-2013, 05:14 AM   #13323
DR650OZ
Oddometer: 22
DR 650 Jetting
Hi New to the forum and DR 650's. Hoping to pick the brains of the experience on here.
Have been reading about lean jetting being STD on these bikes, mainly by people in the USA.
My question is STD jetting to lean from new on 2012 Aussie DR650 ?, I have GSXR muffler/kientech mid pipe, standard header, standard airbox not cut with snorkel intact.( Due to induction noise and economy don't intend to change airbox or Carby)
Bike feels fine to me and runs well(only done 1,800 km) but I am concerned if it is running lean about possibly burning out valve sometime down the track.
Cheers
DR650OZ is offline   Reply With Quote
Old 07-11-2013, 12:51 PM   #13324
B1
Carbon-based bipedal
B1's Avatar
Oddometer: 3,386
see the first post of the BST magic thread. it suggests lean off idle but not bad elsewhere. the OP did my DR with the mods in that thread and definitely transforms the bike. you'll get similar results with an aftermarket jetting kit too. economy should be similar if ridden economically (i still get 20-22km/l on easy adventure rides) but will obviously use more when ridden hard.
free enduro training vids for gumbies here
B1 is offline   Reply With Quote
Old 07-11-2013, 04:31 PM   #13325
DR650OZ
Oddometer: 22
Thanks B1, Will have a read through all that. As mentioned don't think it is running bad at all just concerned if it is lean what that may do long term.
Cheers
Old 07-11-2013, 04:39 PM   #13326
BergDonk
BergDonk's Avatar
Oddometer: 3,583
If there is no surging, and no flat spots when accelerating, it should be fine.
If you lift the needle a notch, or two to be sure, as a test, you'll get an indication of how it runs when its a bit richer from 1/8 to 2/3 throttle FWIW.
Lifting the needle is done by removing the carb top and pulling the slide out, pretty easy if the Phillips head screws cooperate. Best to replace these, and the float bowel, with Allens for the future.
shed time IS quality time
BergDonk's DR650 BergDonk's XT1200Z
BergDonk is offline   Reply With Quote
Old 07-11-2013, 05:21 PM   #13327
DR650OZ
Oddometer: 22
Thanks Bergdonk, will move clip one notch as test to see if runs any different, thanks for the advice
Old 07-11-2013, 05:46 PM   #13328
DR650OZ
Oddometer: 22
Hand Guards
In the process of setting up my new DR 650 and looking for any advice on best fitting handguards, the ones from Highway Dirt Bikes in USA appear to be good quality anyone have them?
I guess the local choice is Barkbuster VPS or Acerbis Multiplo, looking for best fit with cables etc and clearance of switchgear. Main use will be for keeping cold off hands not doing any bashing through overgrown or rugged single track.
Cheers
DR650OZ screwed with this post 07-12-2013 at 01:04 AM
Old 07-11-2013, 05:58 PM   #13329
rutsthematter
rutsthematter's Avatar
Oddometer: 157
Ihandguards
I bought the moose ones from procycle. They have the big plastic deflectors for good wind protection and bar end spacers to give clearance to the levers.
rutsthematter is offline   Reply With Quote
Old 07-11-2013, 06:01 PM   #13330
DR650OZ
Oddometer: 22
Thanks, will check them out
Old 07-11-2013, 08:04 PM   #13331
RideAlongAtlas1
IS GOOD ! ! !
Oddometer: 147
Designed for those poor office souls who'd rather be riding
Well it's Friday here in Australia.
I made a song while riding my bike.
Whilst on my DR650 of course.
My song is called "Staying behind the truck, not going to get F^cked."
Primarily designed for those in offices, trying to pass time. Please share if you know someone bored to-the-craphouse in an office environment, poor bastards.
Song is here: http://www.youtube.com/watch?v=SRoyXtdfd5M
[IMG][/IMG]
See my DR650 motovlog here https://www.youtube.com/ridealongatlas
RideAlongAtlas1 is offline   Reply With Quote
Old 07-11-2013, 09:39 PM   #13332
B1
B1's Avatar
Oddometer: 3,386
keep an eye out behind when behind the truck, you never know what dangers might lurk behind you....
Old 07-12-2013, 03:18 AM   #13333
Flodder
Flodder
Flodder's Avatar
Oddometer: 472
New dr650
Anyone know what a new dr650 is worth at the moment. Flodder junior is getting cashed up in the Airforce and is interrested. Be good if he gets his own so i can ride mine a bit more
Cheers Flodder
Flodder is offline   Reply With Quote
Old 07-12-2013, 03:45 AM   #13334
Starky14
Yowie Bait
Starky14's Avatar
Oddometer: 242
DR with lights
Spotties now on the DR. I can be seen about a month away through the trees.
I would be unstoppable if not for Law Enforcement and Physics!
Starky14 is offline   Reply With Quote
Old 07-12-2013, 04:26 AM   #13335
Canary
Canary's Avatar
Oddometer: 647
Cheers Flodder
Pretty sure that junior Flodder should be able to get one for around $7500 ride away.
2012 DR650
1980 GS450T
Monarchs 1965 - 2015
50th Celebration June 2015
Canary is offline   Reply With Quote
Times are GMT -7.   It's 01:14 PM.
