Old 06-30-2013, 02:41 PM   #1
tagesk OP
Tuscan rider
tagesk's Avatar
Oddometer: 3,211
Wilbers-BMW: 0-1
My Wilbers failed real bad today. No luggage, no warning: Suddenly my GS was a low-rider.
Fortunately the speed was low.
A friend went to my house, found the old shock on the attic, and brought it out in Chianti were I was stranded.
I carry enough tools to replace it on the side of the road.
I am happy to tell you we had a outstanding lunch prior to this failure, so it was still a good day.
[TaSK]
'02 R1150GS - Adds life
My Riding in Tuscany-thread is here.
Renting out motorbikes in Toscana, Italy
Proud contributor to Wisdom and GSpot FAQ and European Ride Report Index.
IBA: 33616
tagesk is offline   Reply With Quote
Old 06-30-2013, 04:14 PM   #2
Joeboxer82is
Oddometer: 26
Thank god u're ok. Lucky u were not riding fast. It's weird how a shock like Wilbers can break just like that. My Ohlins is 4hrs away from it's 1st servicing/rebuild as e seals are gone. Anyway i think u should show Wilbers e broken rear shock of theirs!
Joeboxer82is is offline   Reply With Quote
Old 06-30-2013, 04:16 PM   #3
EJ_92606
Rider
EJ_92606's Avatar
Oddometer: 1,779
Whoa, glad you're ok. Were you riding offroad at the time?
Hopefully you were able to have a nice chianti while you waited
EJ_92606 is offline   Reply With Quote
Old 06-30-2013, 04:17 PM   #4
Swinefahrt
RooteR
Swinefahrt's Avatar
Oddometer: 579
Tagesk, I remember you having rear drive issues and now this!
'07 GS
If its got tits or wheels, it'll give you problems!
Swinefahrt is offline   Reply With Quote
Old 07-01-2013, 04:52 AM   #5
tagesk OP
Tuscan rider
tagesk's Avatar
Oddometer: 3,211
This was the situation as we came to a halt. The steel rod broke, it seems, and the spring then slid off the stud.
Here, the swing-arm is pointing down as the wheel has been removed. When we were on the bike, the spring was resting on the swing arm.
We were riding on normal tarmac when it happened at abotu 50 km/h; no luggage!
I think the damping went first; we passed over a bump and I really felt like in an American car (no offense!). We went up and down two or three times.
Then the crack of something breaking, and the rear and fell at least 10 cm and the wheel banged up underneath the seat.
I'll see if I can find info about Wilbers and ask if they want the remains.
Now - a new shock is 850 euro. A 2008-9 BMW R1200GS Adventure is 10.000 euro. Look at those numbers and think about it.
Speaking of FD-failure: I have had four so far.
[TaSK]
IBA: 33616
Old 07-01-2013, 05:26 AM   #6
kinkster
kinkster's Avatar
Oddometer: 117
wilbers
[TaSK]
It will be interesting to see if Wilbers will come to the party!
Glad you are OK though.
What did you think of the wilbers before the failure?
www.galwayhouse.com.au
kinkster is offline   Reply With Quote
Old 07-01-2013, 05:57 AM   #7
fred flintstone
fred flintstone's Avatar
Oddometer: 525
WoW! Does the lower mount (still attached to the swing arm in the pic) still swivel or is it frozen? Some Ohlins failures were attributed to that seizing up.
Glad you are OK this could have ended badly.
fred flintstone is offline   Reply With Quote
Old 07-01-2013, 07:43 AM   #8
Racegun
Single Track Mind!
Racegun's Avatar
Oddometer: 2,547
Question could it be you are over loading the bike?
4 fd failures? WOW... what make of gear lube are you using? Who is rebuilding them? And If you do not mind, what is the total weight that your bike is carrying?
Cheers!
Dave
Racegun is offline   Reply With Quote
Old 07-01-2013, 09:20 AM   #9
capeklr
capeklr's Avatar
Oddometer: 321
That was my first thought as well looking at the pics. If that mounting seizes then the shock shaft will break.
1998 KLR 680C; to many mods to list.
2007 BMW 1200GSA.
capeklr is offline   Reply With Quote
Old 07-01-2013, 09:53 AM   #10
Okie Preacher
Okie Preacher's Avatar
Oddometer: 864
The man has his priorities straight!
Okie Preacher is offline   Reply With Quote
Old 07-01-2013, 12:34 PM   #11
tagesk OP
Tuscan rider
tagesk's Avatar
Oddometer: 3,211
Not frozen.
At least not when I started to work to get it off.
[TaSK]
IBA: 33616
Old 07-01-2013, 12:37 PM   #12
tagesk OP
Tuscan rider
tagesk's Avatar
Oddometer: 3,211
[FONT=Verdana]
Wilbers say in an email today:
Of course, a shock must not break. I would ask you to send us the defective shock. You have written that your shocks got a regular service.
Please send us copies of the service work.
When the shock arrived, we check it directly.
We'll see.
The shock has worked very well, and after rebuild it has been like new every time.
[TaSk]
IBA: 33616
Old 07-01-2013, 12:41 PM   #13
tagesk OP
Tuscan rider
tagesk's Avatar
Oddometer: 3,211
I've used some standard oil, don't know the brand.
During our 13.000 km journey to Nordkapp (North Cape) we were 520 kg (about 1150 pounds).
And we regularly do 1000 km days at 140 km/h for hour and hour.
Just be to absolutely clear: I have never complained about having to replace four big bearings road-side.
[TaSK]
IBA: 33616
Old 07-01-2013, 12:52 PM   #14
Schlug
JockeyfullofBourbon
Schlug's Avatar
Oddometer: 7,370
Disgrazia!
Glad you're okay TasK.
Keep us informed.
"So what makes this protest different is that you're set to die, Bobby?"
--May well come to that.
"You start a hunger strike to protest for what you believe in. You don't start already determined to die or am I missing somethin' here?"
-- It's in their hands. Our message is clear. They're seeing our determination.
Schlug is offline   Reply With Quote
Old 07-01-2013, 01:54 PM   #15
Dan-M
Dan-M's Avatar
Oddometer: 969
The important question is, what did you have for lunch?
Dan-M is offline   Reply With Quote
Times are GMT -7.   It's 05:34 AM.
