Old 06-30-2013, 02:45 PM   #1
NHKTM990 OP
Oddometer: 100
Noob Q, kick stand issue, real or theory
New guy question: Is the kick stand issue on the Adv R more theory than application? It reminds me of the chatter about the neutral switch issue oin the DR650. Yres if the neutral switch bolt (1/4 20) comes loose it can grenade your engine but it is rare. The mod is mostly peace of mind. Is that the case with the sidestand upfit?
Black Dog cycle works ad talks about it being an issue on both a side strike or "the weight of the rider resting on the sidestand". I would be surprised if another static 200+ pounds could crack an engine case, but not shocked if a ballistic hit like a crash could. Whats the real story Team Orange?
NHKTM990 is offline   Reply With Quote
Old 06-30-2013, 03:10 PM   #2
Racer111v
Racer111v's Avatar
Oddometer: 862
I should just tell you to do some research. But the short answer is you may never have an issue, but if you do it's a major expense. A hard hit to the kick stand will break the cases. Your choice.
2004 KTM 950 ADV ...............................1979 Suzuki RM400 VMX Race bike
2006 DR-Z400E plated........................... 2001 Ducati ST2 944
2001 YZ250N 2T plated.......................... 1986 Yamaha FJ1200
Racer111v is online now   Reply With Quote
Old 06-30-2013, 03:12 PM   #3
kaptinkaos
Just some nOOb
kaptinkaos's Avatar
Oddometer: 794
If you ride stuff like this:
Just do the relocation. Save yourself $3000 for cases and more $$$ on labor and downtime of a broken moto. If you 50/50 it and don't ride anything with rocks then take your chances. Fwiw, from an engineering stand-point, I would do it regardless. It's cheap insurance man... If it does ever happen you'd be ruing not relocating. I took about 5 hard hits directly to the sidestand spot today. I've relocated though so I didn't even think about it, ;)
kaptinkaos is offline   Reply With Quote
Old 06-30-2013, 03:28 PM   #4
Orangecicle
On a "Quest"
Orangecicle's Avatar
Oddometer: 3,149
First, yes, it's an issue. Cases are VERY expensive. Ducati bikes have the exact same problem, and I've seen those cases crack at the mount point as well.
Second, here is how you search the site for things using Google: http://www.lmgtfy.com/?q=site%3Aadvr...and+crack+case
Orangecicle screwed with this post 07-01-2013 at 04:34 AM
Orangecicle is online now   Reply With Quote
Old 07-01-2013, 07:59 AM   #5
woodchuckexc
Oddometer: 801
Very real issue. Lots of pics of broken cases floating around here. I personally have CJ Designs relocate. I like it much better than the BlackDog. Seen pics of the BD cracked floating around here. CJ relocate is rock solid and doesn't require and mods with a grinder
woodchuckexc is offline   Reply With Quote
Old 07-01-2013, 08:22 AM   #6
NHKTM990 OP
Oddometer: 100
Does the BDCW require grinding or is it bolt on? I am convinced!!!! Don't need to see more than one cracked case. Relocator and additional skid plate will be first! Thanks KTMers
Old 07-01-2013, 08:34 AM   #7
MortimerSickle
Semi-Adventurer
MortimerSickle's Avatar
Oddometer: 12,488
I believe only the early 950s need to have the frame web ground.
You might want to look into the Weld 86 skidplate/relocator combo deal- good price, good quality.
I miss round headlights.
"When I was a young man, I liked to race my horse...." -
G.H.W.S. 1878-1962
MortimerSickle screwed with this post 07-01-2013 at 08:39 AM
MortimerSickle is online now   Reply With Quote
Old 07-01-2013, 08:34 AM   #8
bikyto
Dans le doute...gaz!
bikyto's Avatar
Oddometer: 2,193
The bdcw is bolt on on all 990s. Only a few years of 950s required grinding (2004 and some 2005)
But I much prefer this one:
http://www.cjdesignsllc.com/products...ation-bracket/
I had both fwiw
The race is long and, in the end, it's only with yourself...
bikyto screwed with this post 07-01-2013 at 09:54 AM
bikyto is offline   Reply With Quote
Old 07-01-2013, 09:39 AM   #9
woodchuckexc
Oddometer: 801
There is a thread right now, "Broke my side stand relocate plate" it was a BlackDog. Plenty of photos of guys having to grind either the frame or notch the bracket. CJ designs relocate kit is very different from the other options I've seen iMO much better. Craig makes really sick stuff for these big girls
Old 07-01-2013, 09:56 AM   #10
bikyto
bikyto's Avatar
Oddometer: 2,193
To BDCW's credit, it looks like the ones that broke were modified.
CJ'S kit was designed by someone else and he took over the product. He did add some improvements in 2012 which made it even better. I have a pre 2012 version and super happy.
Old 07-01-2013, 11:05 AM   #11
1stiski
Ride that nasty thing
1stiski's Avatar
Oddometer: 1,659
PABiker had a nice relocate set up. I got it, and it works.
"04" 950 Adventure S 37,000+ miles
2003 Harley XL883 converted to CAFE (2013-14)
"Grim Brother" #1
1stiski is offline   Reply With Quote
Old 07-01-2013, 11:43 AM   #12
MortimerSickle
Semi-Adventurer
Oddometer: 12,488
I could be mistaken, but I really do believe grinding is necessary only on the early bikes.
G.H.W.S. 1878-1962
Old 07-01-2013, 12:05 PM   #13
charlie264
charlie264's Avatar
Oddometer: 8,401
Yep, pre June 2005.
Old 07-01-2013, 12:50 PM   #14
Apple Jam
Forest Flyer
Apple Jam's Avatar
Oddometer: 6,643
I had both fwiw
Exactly. I've also had both, and prefer CJ's (PA Biker's old design, now improved).
I do have Weld 86's excellent Skidplate, but liked CJ's relocator best.
I also have a welded up BIG ASS HOLE in my engine case because I did not get the relocator soon enough.
Mine didn't crack,....it broke the bolt flange right the fuck off!!
Here's my Side Stand story
BTW, it was a smallish 20 mph fall, in just the right place, not a bonafidee "crash" that did it.
GET the relocator, any relocator
I had a piece of Alu diamond plate welded over the GAPING hole.
It still seeps oil today, but the patch is strong enough and cheaper than a new case. Any thoughts of resale are GONE, however
"got no problem with keeping truly roadless areas as wild....
On the other hand, if it has been logged or mined and roads already exist,,
...then that land should be open for public use" (peterman)
Apple Jam is offline   Reply With Quote
Old 07-04-2013, 09:41 AM   #15
PABiker
Anywhere but here
Oddometer: 3,923
'03 Suzuki DL1000 V-Strom
'12 Suzuki DR650SE
'10 Husaberg FE450 Plated
PABiker is offline   Reply With Quote
Times are GMT -7.   It's 07:45 PM.
