Old 06-19-2011, 05:45 PM   #1
ctp13 OP
Oddometer: 255
Shocks for my Ural :(
So 1998 Sportsman R80 installed Mostly finnished Rideable Motor and Carbs need some fiddeling
BUT This Thing Needs real shocks ! what ever They were thinking when they built these was wrong! Total loss Oiling systom and I meen Total loss = dripping everywhere and it handles ( if handeling could be considered in this application) ah... Poorly
Iv Owned quite a few Hacks Only one Ural But have some idea what it should feel like Im sure it is Shocks perhaps The tires ( yes they have air in them ) and maybe the wheels ( cant realy find any loose spokes but..)
What souloution have others come up with?
Chuck in Sacramennto
ctp13 is offline   Reply With Quote
Old 06-19-2011, 06:42 PM   #2
windmill
windmill's Avatar
Oddometer: 4,084
The new Ural OEM Sachs, or Hagon http://www.hagonshocksusa.com/HagApps8.htm
"Take care, sir," cried Sancho. "Those over there are not giants but windmills".
windmill is offline   Reply With Quote
Old 06-20-2011, 12:20 AM   #3
ctp13 OP
Oddometer: 255
Please dont take this wrong But millions of these things running around shockless leaking oil and theres only one aftermarket replacement?
Or am I the only one with dripping shocks?
Chuck
Old 06-20-2011, 05:16 AM   #4
moto.irbit
Oddometer: 14
Chuck
In Russia there are many replacement shock absorbers for Urals. Some made in India or China. Some made in Russia. Plaza SPB makes shock absorbers for solo motorcycles, sidecar motorcycles and heavy duty use. But most people will just rebuild the original shock absorbers. You may use different hydraulic oils to vary the performance and if you are knowlegable you may modify the parts inside to vary the performance also. Seals and oil and some time is much cheaper than buying replacements. After 13 years it is probable that your shock absorbers will require rebuilding.
moto.irbit is offline   Reply With Quote
Old 06-20-2011, 08:39 AM   #5
windmill
windmill's Avatar
Oddometer: 4,084
Chuck
Most shock suppliers can probably supply shocks for a Ural, but would be big money. The stock shocks are primitive but suit their intended usage and do need to be serviced occasionally.
Yours were just not properly maintained.
The new OEM and Hagon shocks make such a significant improvement in handling over the Russian shocks, it's a no brainer to me, if you can just get new shocks. When my Russian shocks give up I'm not going to bother rebuilding them.
Old 06-20-2011, 09:03 AM   #6
Tarka
Doesn't wave back.
Tarka's Avatar
Oddometer: 2,047
Unless the damper rods are deeply rust pitted and scrap,just remove yer shocks...then strip them,clean them out and rebuild with new seals and fresh oil.
My 650 was transformed by a shock absorber rebuild.
The inner 'flying saucer' damper rod seal wasn`t available at the time but I found that two tap washer seals stacked up did the job perfectly.
I'd only waste my money if I didn`t spend it on all my bikes......
Tarka is offline   Reply With Quote
Old 07-01-2013, 07:47 PM   #7
gervais
Oddometer: 70
hi,would you have any replacement for my Patrol 2007?
i have back problem because of the supposed to be rear suspension!!!
thanks
Gervais,
ve2ckn2 at hotmail.fr
gervais is offline   Reply With Quote
Old 07-02-2013, 02:30 AM   #8
Tarka
Doesn't wave back.
Tarka's Avatar
Oddometer: 2,047
thanks
Gervais,
The answers are written in the posts above,so there was no need to ask that...but here`s some extra info.
Stock Ural shocks are rebuildable and you can experiment with different oil rates.....they`re preload adjustable and always seem softer and more forgiving than the later fitment Sachs which aren`t rebuildable and seem stiff and harsh.
Hagon can provide customised spring rates if you need them.
Old 01-03-2015, 03:56 AM   #9
roscoau
roscoau's Avatar
Oddometer: 559
Ok... ignoring the old bikes - who has replaced their shocks on a later model? What's out there for them? I know of Hagon and Ikon, so what else?
Aussie Ural Owners
rosco.id.au
Ural - speed limits aren't a restriction, they are an achievement!
roscoau is online now   Reply With Quote
Old 01-04-2015, 06:06 AM   #10
murfalert
Oddometer: 93
Does anyone have a link for the stock shock rebuild?
Murf
murfalert is offline   Reply With Quote
Old 01-05-2015, 07:37 PM   #11
silvergoose
Oddometer: 52
Ural Shock rebuild/replacements
Check the Soveit Steeds forum, good information and tech support of sorts.
Good Luck
2002 BMW K1200LT
2003 Indian RoadMaster Chief
2008 Can Am Spyder(s) two times
2009 Moto Guzzi Stelvio
2007 Moto Guzzi Norge
silvergoose is offline   Reply With Quote
Old 01-06-2015, 01:51 PM   #12
GillaFunk
I use profanities
GillaFunk's Avatar
Oddometer: 4,115
Well,
There's this
http://www.advrider.com/forums/showthread.php?t=847445
HotMammaAndMe upgraded his shocks
http://www.advrider.com/forums/showthread.php?t=644782
EVERYTHING I need to know I learned from Porn
2011 Gear-Up; "سميرة" (Samira)
2013 DR800; "The Dirty-Hooker Too"
2007 FJR1300; "Sally Jupiter"
2003 1150GSA; the 2 Wheeled Submarine
GillaFunk is offline   Reply With Quote
Old 01-06-2015, 09:48 PM   #13
Strong Bad
n00balicious
Strong Bad's Avatar
Oddometer: 4,198
Try some of this:
Just kidding, any aftermarket shock mfgr. can make a shock to fit. The brand of bike has nothing to do with it.
"I couldn't wait for success, so I went ahead without it."
Strong Bad is offline   Reply With Quote
Times are GMT -7.   It's 06:16 AM.
