Old 07-04-2013, 01:01 PM   #16
CycleDoc59
Wrench Rider
CycleDoc59's Avatar
Oddometer: 981
Originally Posted by duck View Post
Not exactly true. Going from an 80 to 90 aspect ratio means the 90 tire is 12.5% taller than an 80.
(90-80)/80
A 110/80-18 tire has a diameter of 24.91 inches.
If a 110/90-18 tire were 12.5% taller, it would have a
diameter of 28 inches, which is over 3 inches taller...!
As you in my earlier post below, the actual height difference is 22mm
overall, or about 11mm higher under the fender.
Aspect ratio is NOT A FUNCTION OF OVERALL HEIGHT, but
of cross-sectional width:
Aspect Ratios indicate a tires cross-sectional profile. The smaller the number,
the lower the profile. It expresses the height to width ratio as a percent.
A 90 aspect ratio means the tire's cross sectional height is 90% of it's width.
CycleDoc59 is offline   Reply With Quote
Old 07-04-2013, 01:06 PM   #17
duck
duck's Avatar
Oddometer: 10,403
You shouldn't drink so early.
Aspect ratio is the height of a tire as a percentage of the width.
The height of a 110/80 is 88mm.
The height of a 110/90 is 99mm.
The difference is 11mm - which is less than half an inch.
duck is offline   Reply With Quote
Old 07-04-2013, 01:27 PM   #18
joexr
Oddometer: 3,773
Semantics.
Old 07-04-2013, 02:25 PM   #19
hankmoody OP
Ummmmm?? REALLY?!
Oddometer: 1,149
Thanks for all the info guys.
Looks like Im going to just order the proper size tire...although I am only finding 100's...but at least I know they will work without issue...
I don't need any drama on this trip!
I put the laughter in manslaughter
hankmoody is offline   Reply With Quote
Times are GMT -7.   It's 04:55 PM.
