Old 07-05-2013, 06:01 PM   #1
Rodknee OP
sensitive? who, me?
Rodknee's Avatar
Oddometer: 2,463
help! fork spring swap
okie, i am swapping fork springs on my 12' adv.
i loosened the fork caps from the tubes, then loosened the caps from the locknut. BUT, they unthread about an inch or so then stops. it stops fairly solid, and i don't want to force it. what am i missing to remove the cap from the pushrod?
edit* i need to get from this:
to this:
i just tried again, and it stops solid when it is close to being unthreaded.
Rodknee screwed with this post 07-05-2013 at 06:09 PM
Rodknee is offline   Reply With Quote
Old 07-05-2013, 06:26 PM   #2
tacosupreme
tacosupreme's Avatar
Oddometer: 269
They just unscrew, there isn't any keepers or set screws. Mine came loose by hand, just a little nudge to break them loose with the wrench. I know, not helping. Maybe the threads are bunged up from a previous owner?
'12 990 with some orange stuff on it to make it go faster.
tacosupreme is online now   Reply With Quote
Old 07-05-2013, 06:34 PM   #3
georgedaman
Oddometer: 123
  • I think you forgot to turn the preload adjuster all the way out before removed the cap.
georgedaman is offline   Reply With Quote
Old 07-05-2013, 07:39 PM   #4
Rodknee OP
sensitive? who, me?
Rodknee's Avatar
Oddometer: 2,463
no, i am the first to go in there. bike has 1k miles.
Originally Posted by georgedaman View Post
  • Screw the cap back into the into the fork sleeve
  • Turn the preload adjuster counter clockwise all the way
  • Unscrew the cap again
  • Pull the cap up/spring down and hold the exposed 22mm nut
  • Loosen the preload adjuster counter clockwise against the 22mm nut under
i did that. halfway through the threads on both forks was a tough spot. little more pressure, and both spun off after. it just didn't seem right at first, as i didn't want to booger it up. got them swapped, we are good.
another question though: one fork had one neoprene washer under the cap, the other had 2. any reason why one of them had 2 washers? i swapped to .58's, so i put only one washer on both.
Old 07-05-2013, 10:26 PM   #5
mjskier
mjskier's Avatar
Oddometer: 474
This is pretty common with WP forks (both my 05 450 EXC and my 07 300 XC-W had the same "issue")
My understanding is that they test the springs and compensate differences in rate with washers.
mjskier is offline   Reply With Quote
Old 07-06-2013, 03:37 AM   #6
Sumi
Sumi's Avatar
Oddometer: 1,796
This is the normal behavior for these forks, no worries:) Just force it, and it will get past that point and unscrew easily after.
Old 07-06-2013, 01:25 PM   #7
fast4d
Oddometer: 2,339
in the pic he will unload the preload all the way THEN unscrew the cap from cartridge
Alan
2011 KTM RC8R
2012 BMW S1000RR
2000 Kawasaki ZRX1100
2013 KTM SMT 990
fast4d is offline   Reply With Quote
Times are GMT -7.   It's 09:59 AM.
