Old 07-04-2013, 03:21 AM   #1
ShaiDanny OP
ShaiDanny's Avatar
Oddometer: 41
Oil tank drain bolt
Hi all,
I have a small oil leak from my drain bolt (which is tightened correctly) and I want to open it and replace the washer.
The thing is that I replaced my oil recently and I don't want to drain it again if I don't have to.
Can anyone verify if I lay the bike on the right side (not on the ground but on a stool so it's not horizontal completely) I can open the drain bolt without any oil coming out?
ShaiDanny is offline   Reply With Quote
Old 07-04-2013, 04:15 AM   #2
jameslawson
Oddometer: 77
It'll still drain out!
Oil will still come out.
Undo the bold catch the oil in a clean drip pan replace bolt and washer put drained oil back in. Simple!
jameslawson is offline   Reply With Quote
Old 07-04-2013, 06:22 AM   #3
hennessyktm
Oddometer: 47
Tip
You probably dont have to get a new copper crush washer.
Hang the washer on a piece of bare wire, paper clip, etc (wear gloved or hold with pliers).
Heat it up with a torch until it glows red.
Remove it from the flame and quickly submerge it in a cup of water.
This causes the copper to expand and will again make a seal. I do it all the time and I've seen it posted in several threads on this site.
Hope this helps!
hennessyktm is offline   Reply With Quote
Old 07-04-2013, 06:28 AM   #4
DirtyADV
DirtyADV's Avatar
Oddometer: 2,322
Maybe with just leaning it but laying it flat on its right side and I doubt much will spill removing the oil tank drain bolt?
/Johan
Have changed name, was previously Dirty950
www.dirtyadv.com (under construction)
DirtyADV is offline   Reply With Quote
Old 07-04-2013, 06:48 AM   #5
ShaiDanny OP
ShaiDanny's Avatar
Oddometer: 41
I'll try and see what happens.
Draining the oil is always possible...
Thx
Old 07-04-2013, 01:22 PM   #6
HeatXfer
Bad knees
HeatXfer's Avatar
Oddometer: 716
Don't drain the oil, Just use a cork or rubber stopper to temporarily plug the hole: with a cold engine, slowly unscrew the bold, slip your finger over the hole first, line-up your stopper and pop it in until you've "conditioned" your crush washer.
You'll spill a minimum of oil, just keep an oil pan or paper towels directly under your work area to catch the few drips you'll have.
HeatXfer is offline   Reply With Quote
Old 07-05-2013, 11:28 PM   #7
what car??
down the road
Oddometer: 372
or you could just wait until the next oil change and take care of it then...
what car?? is offline   Reply With Quote
Old 07-06-2013, 11:31 AM   #8
HeatXfer
Bad knees
HeatXfer's Avatar
Oddometer: 716
Doh!
Old 07-06-2013, 12:39 PM   #9
mcmann
Motorcycle Maniac
mcmann's Avatar
Oddometer: 1,947
Originally Posted by ShaiDanny View Post
Hi all,
You could back the bolt out far enough to wrap the top three threads several wraps of teflon tape (doubled over so it is only half the normal width).
mcmann is offline   Reply With Quote
Old 07-06-2013, 05:39 PM   #10
tacosupreme
tacosupreme's Avatar
Oddometer: 276
I just fixed a leak on the hydraulic cam chain tensioner on the front jug with a light coat of anti-seize. Worked great, and will hold up to the heat better than teflon tape...
'12 990 with some orange stuff on it to make it go faster.
tacosupreme is offline   Reply With Quote
Times are GMT -7.   It's 08:19 AM.
