Old 07-06-2013, 10:47 PM   #1
indr OP
Oddometer: 1,197
What's happening in this video?
What exactly did he do to save it?
indr is offline   Reply With Quote
Old 07-07-2013, 04:07 AM   #2
omeoxlv
omeoxlv's Avatar
Oddometer: 262
Havent slow moed it or anything but would guess not going that quick in first place and (most important) stood up!
He caused it by giving full throttle and then backed right off.
omeoxlv is offline   Reply With Quote
Old 07-07-2013, 04:47 AM   #3
DSM8
Where fun goes to die....
DSM8's Avatar
Oddometer: 3,752
Perfect example of a highside but was going slow enough he did not get tossed off bike. Good save on his part.
DSM8 - A different kind of mean
SQL > SELECT finger FROM hand WHERE id=3
http://share.findmespot.com/shared/f...d5LbKWMz6cHxaH
DSM8 screwed with this post 07-08-2013 at 10:51 AM
DSM8 is offline   Reply With Quote
Old 07-07-2013, 05:04 AM   #4
markie*mark0
Oddometer: 10
poor control in the first place, if you watch carefully you can see the on/off of the throttle, combine that with the weight transfer of the bike and the rear looses traction.
highsides tend to kick you out of the seat, the good thing with that is all of your body weight is instantly transferred to your pegs, this means the centre of gravity is put as low as possible to make the bike more stable.
combine the lucky kick out of the seat with an instinctive "turn into the skid" and he saves it.
Work on positive throttle control for next time and this wont happen
markie*mark0 is offline   Reply With Quote
Old 07-07-2013, 09:23 AM   #5
DAKEZ
DAKEZ's Avatar
Oddometer: 19,703
He cut the throttle and used the clutch to help the rear wheel regain traction... And let the bike have the freedom to right ITSELF.
“Watch out for everything bigger than you, they have the "right of weight"
Bib
DAKEZ is offline   Reply With Quote
Old 07-07-2013, 09:26 AM   #6
DAKEZ
DAKEZ's Avatar
Oddometer: 19,703
weighting the pegs does NOT lower the center of gravity.
Originally Posted by markie*mark0 View Post
highsides tend to kick you out of the seat, the good thing with that is all of your body weight is instantly transferred to your pegs, this means the center of gravity is put as low as possible to make the bike more stable.
Bib
DAKEZ screwed with this post 07-08-2013 at 06:28 PM
Old 07-07-2013, 07:02 PM   #7
superhobie
Soil Sampler
superhobie's Avatar
Oddometer: 108
Never touched clutch
superhobie is offline   Reply With Quote
Old 07-07-2013, 07:54 PM   #8
rocker59
diplomatico di moto
rocker59's Avatar
Oddometer: 15,703
To answer the OP's question, when the rear end kicks out, do not chop the throttle. Slowly roll off the throttle as the rear end comes back in line.
If you leave too much throttle, the rear will wash out and you'll low side. Chop the throttle too quickly and it will snap back in line and high side you.
Practice sliding a dirtbike and you'll see what I mean... Though, it's not really something you can practice for on the street.
Rocker59 (aka guzzimike), Aux Arcs (NW Arkansas)
Moto Guzzi Sport 1100
IBA #24873
"Do what you can, with what you have, where you are." - Theodore Roosevelt
rocker59 is offline   Reply With Quote
Old 07-07-2013, 08:04 PM   #9
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 51,662
It started by braking and unweighting the rear tire. Watch closely and you will see the front squat.
As for the save, back on the gas lightly by reflex, and standing up to weight the rear again. It is a common theme on Mulholland Drive!
Jim
JimVonBaden is online now   Reply With Quote
Old 07-07-2013, 08:41 PM   #10
lnewqban
Ninjetter
lnewqban's Avatar
Oddometer: 291
He didn't.
lnewqban is offline   Reply With Quote
Old 07-07-2013, 08:49 PM   #11
rocker59
diplomatico di moto
rocker59's Avatar
Oddometer: 15,703
Jim
I just re-watched the vid and didn't see his fingers on the brake (or the clutch).
The slide was throttle induced. There are hundreds of vids on the web of bikes doing the same thing at the same spot on that road.
He rolled on too much throttle on the exit and lost rear traction, putting him into a power slide. He then chopped the throttle a little too quickly and almost high sided when the rear end came back in line.
IBA #24873
Old 07-07-2013, 08:49 PM   #12
rocker59
diplomatico di moto
rocker59's Avatar
Oddometer: 15,703
Originally Posted by lnewqban View Post
He didn't.
Well, at least he held on tight during the rodeo.
IBA #24873
Old 07-07-2013, 09:11 PM   #13
JimVonBaden
"Cool" Aid!
Oddometer: 51,662
You are right, same effect though. I could see his wrist as he let up on the throttle.
Jim
Old 07-07-2013, 10:27 PM   #14
lnewqban
Ninjetter
lnewqban's Avatar
Oddometer: 291
Cool2
Yes, more or less, ......................and he was lucky that the surface upon which the recovery happened was still slippery, allowing the rear re-gain traction gradually.
This guy was not as lucky:
http://www.triumph675.net/forum/showthread.php?t=40391
Old 07-08-2013, 04:45 AM   #15
Navy Chief
Navy Chief's Avatar
Oddometer: 1,544
Great photo sequence of exactly what happens during a highside... Glad the rider was okay.
Navy Chief is offline   Reply With Quote
Times are GMT -7.   It's 06:28 AM.
