Old 07-07-2013, 08:53 AM   #11041
Gravel Seeker
Thomas
Gravel Seeker's Avatar
Location: Dreary old Norway, dreaming of adventures past
Oddometer: 3,980
Originally Posted by ferals5 View Post
a quick google ... Dunlop official web site 40psi, Metzeler 40psi, Mitas 36psi, Bridgestone is the only one I could find out of step at max 57psi for M/C tyres.
Info provided so that your head may remain on your shoulders
Those figures are probably for tubeless tires, no ?
'01 F650 Dakar - modified as best I can
2005: Australia - 8 months/ 26.000 km (anti clockwise circle)
2009: Norway - 2 weeks/ 6000 km (Lindesnes to North cape)
Gravel Seekers.com
Hey !
It's the African ant eater ritual !
Gravel Seeker is offline   Reply With Quote
Old 07-07-2013, 09:40 AM   #11042
Gravel Seeker
Thomas
Oddometer: 3,980
Originally Posted by Don Coyote View Post
I just mounted my new Anakee III
What sizes did you go with ? And how do they ride ?
Gravel Seekers.com
Hey !
Old 07-07-2013, 09:54 AM   #11043
Don Coyote
Don Coyote's Avatar
Oddometer: 1,276
Correct DC, I would imagine the tyre would actually take more than double the max pressure when seated....the issue is the bead is moving during the seat process
Regardless of the pressure amount, i think one thing to be stressed is to inflate slowly and not with an unregulated compressor.
'06 F650GS Dakar
Those who believe you should always error on the side of caution usually become comfortable making errors and before too long know of little else.
Don Coyote is offline   Reply With Quote
Old 07-07-2013, 10:00 AM   #11044
Don Coyote
Don Coyote's Avatar
Oddometer: 1,276
I have a Kenda761 in back, this is just on my stock 21" front so not sure if that helps you. It is a 90/90 and it pulsates and feels very squirrelly while braking and in corners, but that might be somewhat related to the bead on one side being off and the tire being visibly out of round by a half inch when i spin it.
I'll give it a shot with a bike pump and some dish soap later today, and take it back to the dealer on Tuesday if that fails.
'06 F650GS Dakar
Old 07-07-2013, 10:28 AM   #11045
Gravel Seeker
Thomas
Oddometer: 3,980
Pulsating while braking you say.... sure it's not the disc that's warped ? Mine pulsates like a son of a bitch.... pulsates from not braking to damn near locking the wheel.... it's worst at low speeds.
And I though it got worse after I did the "bounce test" and re tightened the lock screw on the forks. I lost the "fall to the right when letting go of the bars" syndrome, but the pulsating doubled....
Gravel Seekers.com
Hey !
Old 07-07-2013, 11:13 AM   #11046
Don Coyote
Don Coyote's Avatar
Oddometer: 1,276
No, the pulsation is with normal straight line riding. Braking is more of a shimmy, the forks feel like they are made of noodles. The brake drags pretty consistently when spun. (The brakes do have less power than a while ago- i think it glazed a little when my fork seals were leaking...)
'06 F650GS Dakar
Old 07-07-2013, 04:32 PM   #11047
GSBS
FunHog
GSBS's Avatar
Oddometer: 3,932
Never screw the little nut more than halfway down the stem.
That way you
  • can see if it has moved, when the stem is not at 90o degrees to the rim
  • won't rip the tube by the stem if it moves since the stem is not locked down to the rim
I have to disagree with this...
Think about it, if there is slop in the nut on the valve stem and the tire does move, it's much more likely to yank on the stem sideways, damaging the stem or valve stem core, or ripping out the entire thing. Besides, if you run it halfway down it's gonna vibrate and move over time toward the rim or the cap anyway. You might as well not have it on there at all. Also, if it's not tightened down the valve stem can be angled from spooning on the tire prior to inflation. The purpose of the second nut is to keep the stem in it's correct position.
Also, if you have a flat you don't want that valve stem flipping and flopping around loose because that will likely rip it from the tube. On several occasions I've had punctures and was able to patch the tube to get me home and that is impossible with a tube lacking a valve stem!
GSBS is offline   Reply With Quote
Old 07-07-2013, 05:38 PM   #11048
ferals5
865+652
ferals5's Avatar
Oddometer: 1,125
All tyres
I'll have to disagree with your disagreement with GS
In my younger days I used to run them all the way down but now run them all the way up ( under the cap) if the stem can move (initial cause puncture) it is less likely to rip the stem and yes I only really need the nut for install otherwise it would be in the bin....saving weight 101
That little nut will not stop a tyre/tube from spinning .Not a right/wrong thing just from experience.
ferals5 is offline   Reply With Quote
Old 07-07-2013, 07:17 PM   #11049
DakarGuy
DakarGuy's Avatar
Oddometer: 112
Adding LED lights
I'm thinking of adding a set of Denali DM1 LED lights from Twisted Throttle to my Dakar.
I know very little about electrical systems, So was hoping for some advice. I searched for some basic guide on motorcycle electrical systems but never found much. If someone has a good link, that would be much appreciated.
I have a Yuasa YT12CL 12v AGM Maintenance Free battery. IIRC this is a 12 amp/hr battery. My research tells me 12v at 12AH = 144 watt hours. The Denali lights draw 5 watts per lamp for a 10 watt total. So without any charge, I could run the LED lights for 14.4 hrs, all things being equal. Is that right?
My first question then is; How many watts can I run concurrently on the battery before something starts to give? How do I work that out?
Say I want to run my OEM headlight, plus my heated hand grips, plus the Denali LEDs, plus heated clothing, plus a cell phone on charge, plus a Garmin Montana GPS, etc. How do I know what is safe? I don't want to damage the battery.
The instructions say to use the posi-tap connector to connect to a switched 12v power source. Second question; How do I identify a switched 12v power source?
Third question; what should I be careful about when fitting these LEDs? It looks pretty straight forward, but the electrical part concerns me because of my limited knowledge.
I know these are totally noob questions...but this is probably the best place to ask them.
I would like to do this myself and learn something in the process, rather than take it to the shop.
Any help is highly appreciated.
Previous rides: Honda MT50, Yamaha DT125, Yamaha XJ650, Kawasaki GPz750
Current ride: 2007 BMW F650GS Dakar
Blog: http://backroadsrule.blogspot.com/
YouTube Channel: https://www.youtube.com/user/IzzitHey/videos
DakarGuy is offline   Reply With Quote
Old 07-07-2013, 08:19 PM   #11050
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 9,358
I would recommend you go with the Piaa LP530s. They only draw 12 watts and put out a lot of light. $191 on Amazon. http://www.amazon.com/PIAA-5372-530-...=pd_sim_auto_2. Very easy to wire up using the provided harness.
twinrider is online now   Reply With Quote
Old 07-07-2013, 10:25 PM   #11051
Don Coyote
Don Coyote's Avatar
Oddometer: 1,276
I took the core out of the stem, the tyre deflated and the bead on both sides came off with a light touch of the fingers (bad sign, right?). I smeared dish soap in on the area that seemed to be riding low off the rim, then pumped the tyre up to 60 with a bike pump. Looked just the same as before so i let the air out reinstalled the core and pumped it up to normal (33) and rode 100 miles. Still looks uneven and rides like crap. I'll email Michelin about the mould markings and take the wheel back to the dealer when they open Tuesday...
'06 F650GS Dakar
Old 07-08-2013, 02:20 AM   #11052
WTFMATE
Oddometer: 50
The valve stem will cock sideways. but if you have the nut screwed tight then the valve stem will be ripped from the tube.
WTFMATE is offline   Reply With Quote
Old 07-08-2013, 07:36 AM   #11053
DakarGuy
DakarGuy's Avatar
Oddometer: 112
Thanks for the feedback. Do you have any pics of how you mounted those?
Old 07-08-2013, 09:45 AM   #11054
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 9,358
The light bar is homemade, using some aluminum stock, a hammer and a vice. Pretty easy to replicate looking at this pic.
I made my own because my Touratech fork guards would interfere with but that is a pretty good option as well if you don't have the TT fork guards. http://www.ezymount.com/kits/ezymount_f650gs.htm
Old 07-08-2013, 09:58 AM   #11055
kubiak
Oddometer: 4,829
nice lights and mounting bracket!
Times are GMT -7.   It's 06:19 AM.
