Old 07-07-2013, 11:41 AM   #106
jules083 OP
jules083's Avatar
Oddometer: 3,781
Originally Posted by Barnone View Post
jules,
I have the Harbor Freight version of your trailer for my Ural ( can't tow it yet because it voids the warranty ) and the box is bolted to the frame in four places with big fender washers on the inside.
You have the one I should have bought. Instead I bought the flatbed model from Harbor Freight and a car-top carrier from Sears. I sat and looked it it for a bit longer, I have a good plan now using 2x4's.
Originally Posted by DAKEZ View Post
Are you sure about that?
It seems to me that for all the time, effort and money you are using to set up and equip your bike and trailer you could have found and purchased some better gear and IMPROVED your camping experience (and saved much more than 5 pounds) without even bothering with a trailer and the increased risk of pulling one.
My gear is actually pretty good, it's just that there's a lot of it. The most recent trip I brought, not counting what I was wearing:
Rain gear x2
Tent (euraka that packs small)
Sleeping bags X2 (mid grade stuff, packed pretty small)
3 pairs of pants, 2 for her one for me
4 pairs of socks (2 each)
Flip flops X2
4 shirts
Tarp (build a lean-to next to tent. Rained hard both nights, it was worth it)
2 Pocket chairs (I recommend these) http://www.amazon.com/Allstar-Market.../dp/B004P33I70
Shower stuff (we shared most of it)
Sleeping pads, the blue things on the saddlebags
Cell phone charging
tools
shorts x2
That's about it off the top of my head. I could have lost the tarp, chairs, and sleeping pads. Without the tarp we would have been huddled in tents rather than all of us enjoying the evening. Chairs pack pretty small (see the link) and were nice to have. Sleeping pads were a luxury. I could get smaller ones, but I doubt i would have saved much.
Truth be told I don't know if I'd have used the trailer here, considering it was only 3 days. Any longer and I would have. Riding solo I wouldn't have needed it at all.
COBDR and UTBDR on my klx250:
http://advrider.com/forums/showthread.php?t=1003485
jules083 is online now   Reply With Quote
Old 07-07-2013, 04:09 PM   #107
100mpg
This sentance intent
100mpg's Avatar
Oddometer: 17,382
I think you will get better mileage with some tires.
Looks good! I am don't like the swivel hitch but to each his own. The lower you can keep the box to the frame, the better off you will be. I think you can get away with some rubber mats if the box has any reinforcment where the bolt hole are, or, a 1"x3" running from front to back, either painted or use one of the under coat in a spray can. Won't rot or even get soggy and it will give you some strength.
If you haven't gotten the lights yet, LED's are the only way to go. SUPER bright and that is nice on the back of the bike at night.
Originally Posted by jules083 View Post
Ok, trailer is getting close.
Don't drive like my brother!
"I'd rather wake up in the middle of nowhere than in any city on Earth" - Steve McQueen
National Suicide Prevention Lifeline 1-800-273-TALK (8255). DSI #694
100mpg is offline   Reply With Quote
Old 07-08-2013, 07:00 AM   #108
mr duck
psych
mr duck's Avatar
Oddometer: 73
Are there advantages to a high mounted hitch? For smaller trailers?
mr duck is offline   Reply With Quote
Old 07-08-2013, 07:00 AM   #109
jules083 OP
jules083's Avatar
Oddometer: 3,781
Tires... Hmm.... I knew I forgot something.
I was undecided on the swivel hitch. For every person that said it's important another said not to use it. The deciding factor for me was getting the hitch and ball in my hand then looking at the lean angle, it just didn't seem like enough. The farther to the side the ball went the more it got tight and didn't want to move as freely.
LED's are sitting in the garage, tonights project is wiring.
Here's what I came up with to mount the box. There's a 1/2" wood spacer under the 2x4 to keep everything tight. The 2x4 is treated, spacer isn't. I'll have to keep an eye on it. I'm going to try to find some rubber to put between the box and 2x4, but if nothing good comes along it probably won't make much difference.
Tonight is wiring, put the hitch on the bike, road test, and clean the garage. It's had a few back-to-back projects in it, getting pretty rough.
Old 07-09-2013, 06:55 AM   #110
jules083 OP
jules083's Avatar
Oddometer: 3,781
Well, it's kind of done.
I was finishing up the wiring while texting a friend, and told him about how the harley has different wiring than a car so I used different lights for the turn signals and brake lights to keep power from back feeding through the wiring. He then told me about diodes, which is exactly what I need. Oops. Today I'm going to go get plates, I'll work on the wiring some more tonight.
The test ride was about what I expected. Can't tell the trailer is there except for acceleration is worse, and the noise. I'm going to add some rubber to the bottom of the box to try to quiet it down. The other sound is my exhaust note bouncing off the trailer. I have a quiet exhaust though, not a big deal at all.
Times are GMT -7.   It's 10:03 AM.
