Old 07-02-2013, 04:50 PM   #1006
duck
duck's Avatar
Oddometer: 10,403
When clearing a paper jam in your laser printer, do not pull out the toner cartridge and touch whatever that hot thingy is with the tip of one of your fingers. It's fuggin' hot. (338F - I looked it up.)
duck is offline   Reply With Quote
Old 07-02-2013, 05:10 PM   #1007
Marco Moto
Voyager
Marco Moto's Avatar
Oddometer: 1,242
Uhm, yep, that'll be the "Fuser".
-Marco Moto
Marco Moto is offline   Reply With Quote
Old 07-02-2013, 05:20 PM   #1008
PathLessTraveled
PathLessTraveled's Avatar
Oddometer: 27
Center Stand
Do NOT assume that you can rock your new (used) 1150GS on to the center stand while seated like you could with your Royal Enfield Bullet 500.
PathLessTraveled is offline   Reply With Quote
Old 07-03-2013, 06:04 AM   #1009
TrailOut
TrailOut's Avatar
Oddometer: 17
Never assume you've dropped your keys inside the fuel tank (cause you heard them fall somewhere and they're not on the ground) before making sure they aren't simply stuck between the bash-plate and the engine.
Boy that was frustrating...
www.TrailOut.net - Deep Down Portugal
TrailOut is offline   Reply With Quote
Old 07-03-2013, 10:46 AM   #1010
fastdadio
Still gettin faster
fastdadio's Avatar
Oddometer: 2,098
Doh!!
Do not lay your textile jacket over the gas tank during a stop and allow the plastic zipper to contact the hot head pipe.
fastdadio is offline   Reply With Quote
Old 07-07-2013, 09:43 AM   #1011
Motojournalism
motojournalism.com
Motojournalism's Avatar
Oddometer: 1,641
Note to self: inch-pounds are... not much.
"Absorb what is useful, Discard what is useless, Add what is uniquely your own" - Bruce Lee
Motorcycle Travel Photography tips at motojournalism.com
Way Out West - Canada to the Darien Gap
Follow me on Twitter
Motojournalism is offline   Reply With Quote
Old 07-07-2013, 10:03 AM   #1012
PFFOG
Richard Alps-aholic
PFFOG's Avatar
Location: Western NY, further from NYC than 6 entire states
Oddometer: 2,561
Unless you are a small fastener..........................
PFFOG is offline   Reply With Quote
Old 07-07-2013, 10:26 AM   #1013
Motojournalism
motojournalism.com
Oddometer: 1,641
Indeed:
Way out West-0751 by Motojournalism.com, on Flickr
Old 07-08-2013, 07:12 AM   #1014
road_thing
chingadero
road_thing's Avatar
Oddometer: 36
Be very careful...
...not to knock the box containing your indexed numbered drill bits on the floor.
The little tiny ones aren't marked and it'll take you an hour with a dial caliper to get them all sorted out again.
Never mind how I know this...
road_thing is online now   Reply With Quote
Old 07-08-2013, 04:24 PM   #1015
Jamming
Desert RAT
Jamming's Avatar
Oddometer: 2,883
Make sure when you run the clutch cable adjuster all the way in BEFORE you adjust the clutch on a Harley.
Only took me 15 seconds to realize my mistake.
2014 Victory Cross Country
2007 Triumph 1050 Tiger
WWW.Motorcyclistcafe.com
Jamming is offline   Reply With Quote
Old 07-08-2013, 07:48 PM   #1016
troidus
Oddometer: 14,322
When you buy a new front hub for your FWD vehicle (to replace one burned blue by a bad bearing), make sure the new one fits on the splines of the halfshaft before having it pressed into the steering knuckle assembly.
troidus is offline   Reply With Quote
Old 07-09-2013, 10:45 AM   #1017
Laconic
Anodyne
Laconic's Avatar
Oddometer: 17,507
Don't pee on the third rail.
Laconic is online now   Reply With Quote
Old 07-09-2013, 11:02 AM   #1018
PFFOG
Richard Alps-aholic
PFFOG's Avatar
Oddometer: 2,561
........................or an electric fence!
Old 07-09-2013, 09:14 PM   #1019
Dr. Hemlock
Honky Mofo
Dr. Hemlock's Avatar
Oddometer: 124
next time look for an Adam's apple
Dr. Hemlock is offline   Reply With Quote
Old 07-10-2013, 03:49 AM   #1020
Laconic
Anodyne
Laconic's Avatar
Oddometer: 17,507
Times are GMT -7.   It's 04:59 AM.
