Old 03-31-2013, 08:12 PM   #1066
RFlagg42
One hoopy frood....
RFlagg42's Avatar
Oddometer: 1,188
Originally Posted by JimVonBaden View Post
You can buy bulbs on e-bay any time. That said, the ballast is more likely to fail than the bulb.
Jim
Thanks! I see now. I didn't realize all those connectors were standard sizes and that you could buy replacement bulbs with the wiring/connectors in place.
RFlagg42 is offline   Reply With Quote
Old 04-01-2013, 02:23 AM   #1067
mikegc
mikegc's Avatar
Oddometer: 1,642
HID Conversion on a 12GS (pictorial)
Originally Posted by RFlagg42 View Post
Pardon me if this is a stupid question, but after installing one of these upgrade kits, the HID bulb will eventually fail. At that point, do you have to puchase a new kit? It doesn't look like you can just buy a replacement bulb the way the wires are connected to it.
Eric
Not a foolish question at all. Jim is quite correct about the bulbs/ballast. I installed a 35W kit in my '09 GSA in March of 2011 and it's still going strong. I've a spare bulb and ballast in the bag but, so far . . . . . . .
Mike
IBA 25881
Duty- Honoring a Friend
mikegc is offline   Reply With Quote
Old 05-30-2013, 07:09 PM   #1068
freiheit
Oddometer: 6
My experience w/ a DDM Tuning HID Conversion kit
The following is my experience with a "DDM Tuning" HID kit which I purchased in early April (shipped from China to Canada in about a week) and was installed on my 2009 R1200GS in early May of this year:
HID Kit: Two H7 bulbs (5,000 Kelvin), two 35 watt ballasts, two igniters, two error code eliminators (part # BOW3), and ballast brackets. Shipping (including all-inclusive duties, taxes, and fees of US$34) was over 40% of the total cost.
I wired the kit according to instructions and everything worked as expected (both high beam and low beam). I taped up the wires, re-assembled the bike, and re-tested the set-up again. Everything worked fine. The next day, I started up the bike and the low beam flashed for about one second, then went out and I got the dreaded "Lamp Failure" warning. Thinking that this might be an anomaly, I rode the bike a few more days, trying hot re-starts, quick re-starts, high beam on, etcetera, with no luck (except once, and I don't know why). Throughout this period, the high beam always worked fine (lighting whenever I flipped the switch).
So I e-mailed DDM Support explaining my situation, suggesting that I might have received some defective parts. They replied promptly and suggested that I switch some components around to see if I could isolate the problem. I simply switched the igniter and ballast connectors between bulbs and to my surprise, both bulbs (high and low beam) worked as they should!
I was trying to figure out how this was possible (apart from making poor connections, which I doubt happened) and all I can think of, and this is pure speculation, is that BMW's CANBUS system on my bike has slight differences between circuits (e.g., high and low beams) such that minute differences in ballasts, igniters, error code eliminators, and/or bulbs is enough to trigger, or not trigger, a circuit fault.
This made me think that it would be nice if BMW designers or someone else could figure out how to access and re-program CANBUS circuits so that they could be made tolerant of an HID conversion, without having to employ error code eliminators or other workarounds.
So, if you have trouble with your HID conversion, I think it might be worthwhile to experiment a little and swap components around before throwing in the towel.
Even after the troublesome installation, I'm very pleased with the HID lights and glad I did the conversion. I think they offer greater safety (both to see, and be seen) and the "white" light looks better. I typically do not "flash" my high beam so the slight delay required to get to maximum intensity is not an issue for me. I hope this helps some of you decide if the DDM Tuning kit is right for you.
P.S. Thanks, Jim, for providing the helpful installation guide and photos. Between you and Beemer Boneyard, I can almost afford the bike!
freiheit screwed with this post 05-30-2013 at 07:32 PM
freiheit is offline   Reply With Quote
Old 06-14-2013, 01:06 PM   #1069
DFWBo
DFWBo's Avatar
Oddometer: 269
DDM Order
I just called DDM about having the 90 degree connectors for the AUX lights, the rep said "we don't sell them". I canceled my order.
DFWBo is offline   Reply With Quote
Old 06-14-2013, 02:11 PM   #1070
EJ_92606
Rider
EJ_92606's Avatar
Oddometer: 1,779
I have the full DDM 35w kit as well as a larger ballast that was required for the low beam to work on my GS as well as two GS headlight caps with the holes cut in them, so you can keep your stock caps if you ever want to remove the HID. I removed this kit from my GS to prep it for sale, so it is used, but tested and proven to work. Will sell the whole thing...three ballasts, 3 bulb assemblies, and the two pre-cut GS 1200 headlight caps for $25 plus shipping...CONUS only.
EJ_92606 is offline   Reply With Quote
Old 07-04-2013, 09:56 AM   #1071
johnny80s
johnny80s's Avatar
Oddometer: 267
I can say I did read this entire thread over the last 3 days. That in itself is noteworthy. I think I am going to try the ddm kit since they are local to me. For 30 bucks you can beat that with a stick.
johnny80s is online now   Reply With Quote
Old 07-04-2013, 10:25 AM   #1072
EJ_92606
Rider
EJ_92606's Avatar
Oddometer: 1,779
I'm local to DDM too...come on over and buy my kit...I sold my GS and removed the DDM HID. I also have a larger ballast that won't throw a canbus error on the low beam which the DDM ballast did and I have 2 precut BMW headlight caps so you won't have to cut yours. Make me an offer and it's yours.
Old 07-04-2013, 10:56 AM   #1073
johnny80s
johnny80s's Avatar
Oddometer: 267
Sent you a PM.
Old 07-04-2013, 03:13 PM   #1074
GL1800
RAT PACK---GS GAINT
GL1800's Avatar
Oddometer: 101
hid kits
http://www.futurevisionhid.com/home
I have bought 4 sets . I have hids in high/low headlights and oem aux lights on my 2009 GSA. Installed them over 3 years ago with no lamp failure warning light problems. Bruno uses quality bulbs and balllast
Work Hard----Play Harder
2009 R1200GS Adventue
2012 GS GIANT
GL1800 is offline   Reply With Quote
Old 07-04-2013, 08:51 PM   #1075
ghostrider1964
Edumacated Red Neck
ghostrider1964's Avatar
Oddometer: 6,860
Gonna use different vendor bought 2 sets off of flea bay and they last about a year at most. I am in my third set and have an aux light out from install last November.
2008 R1200 GSA (Ghostrider), G650 X/Challenge
"Fuck'em. I'm a lifer. " SlowOldGuy
"The older I get, the faster I was", HardyBaker
TEXAS-ROLL THE BONES RALLY 6 10/23-10/25/2015: ?.......
http://www.rollthebonesrally.com/
ghostrider1964 is offline   Reply With Quote
Old 07-09-2013, 05:21 PM   #1076
tallguy-09
Smile 4 Miles
tallguy-09's Avatar
Oddometer: 1,436
I'm using the cheap and small DDM 35W digital slim ballast on my 2010 without any issues since 2011, no Lampf.
tallguy-09 is offline   Reply With Quote
Old 07-10-2013, 07:41 PM   #1077
JimVonBaden OP
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 52,929
New HIDs for my R1200GS:
Slim ballasts with no igniter.
Jim
Old 07-10-2013, 07:56 PM   #1078
rider257
rider257's Avatar
Oddometer: 103
Hey JVB where did you geth this bad boys. And are we gonna see a installation pictorial to along with the DVD I already have wink
rider257 is online now   Reply With Quote
Old 07-10-2013, 08:14 PM   #1079
Ride4Coffee
Ride4Coffee's Avatar
Oddometer: 210
Jim
I think I see another Tech Day project for me!
IBA# 57940
Need the 90mm bolt for your Kaoko?
Ride4Coffee is offline   Reply With Quote
Old 07-11-2013, 04:38 AM   #1080
JimVonBaden OP
"Cool" Aid!
Oddometer: 52,929
I got them for $27 shipped directly from China in a nice foam box, see photo.
I'll definitely post up some photos, but it likely won't be much different than my original post so long ago.
Jim
Times are GMT -7.   It's 11:01 AM.
