Old 07-09-2013, 06:35 PM   #19516
Squeaks
Squeaks's Avatar
Oddometer: 10
Originally Posted by WageSlave View Post
I picked this up yesterday and am happy to have a bike again.
What size front tire is that?
2003 KLX 400 - the GREEN DRZ
2003 ZZR1200
Squeaks is offline   Reply With Quote
Old 07-09-2013, 06:40 PM   #19517
kioti
Cruzinonline
Oddometer: 187
SM's run 17" front/rear.
kioti is offline   Reply With Quote
Old 07-09-2013, 07:39 PM   #19518
WageSlave
WageSlave's Avatar
Oddometer: 352
Front and rear are Pirelli RallyCross MT 21 's. The front is a 120/90-17, the rear is a 130/90 -17.
WageSlave
Current ride - '09 DR-Z400SM (Adventurized)
WageSlave is offline   Reply With Quote
Old 07-09-2013, 08:06 PM   #19519
Starchamp
Rebel Scum
Starchamp's Avatar
Oddometer: 1,014
Originally Posted by tdrrally View Post
is the sm rear rotour larger than an e ?
Yes. E and S are the same, SM is larger.
Starchamp is offline   Reply With Quote
Old 07-09-2013, 08:50 PM   #19520
focallength
You're Welcome
focallength's Avatar
Oddometer: 4,985
Originally Posted by PhiSig1071 View Post
Which seal? The ceramic one at the back of the impeller shaft? If I do that I'll also need all the gaskets for the water pump as well as the primary cover gasket on that side. That will likely end up costing a lot more then $25. If you're talking about the gasket on the outer water pump cover, that doesn't seem to be the source of the leak.
And FYI I have tried searching ADV Rider and this thread, but it appears that the search function is down.
what gaskets? the reusable rubber ones or the side cover one that's reusable? you don't need new gaskets unless you rip the paper side cover one, eben then $5 tube of copper gasket maker fixes that issue.
focallength is offline   Reply With Quote
Old 07-10-2013, 04:01 AM   #19521
tdrrally
tdrrally's Avatar
Oddometer: 3,380
thank you
1996 Dr350se 1997 DR350se
1980 TS125 project in the corner 2002 Drz250k1 i miss that bike
tdrrally is offline   Reply With Quote
Old 07-10-2013, 06:33 AM   #19522
Plane Dr
Plane Dr's Avatar
Oddometer: 865
That's where I got most of my information. I'm just wondering if I go to all the trouble to pull the side cover and RTV the ceramic washer, doesn't it make more sense just to replace it with the new assembly for an additional $50 over the cost of gaskets/RTV/etc to do the "fix"?
The new parts are just as likely to fail as the old ones. I haven't heard of anyone needing to redo the "fix". I did mine when it was 4(?) years old. No problem to date and the engine has been torn down twice and I've never changed back to "new" parts.
The SM rotor is the same size as the RM and most "street" bikes.
01/09 DRZ470SSW more bits than necesary
2005 R1200 GS AKA The Mothership
2003 Z1000 Nuclear Pumpkin (gone)
86 RG500WW (gone)
Bikes are like women. What you think you want, and what you want, change after the first ride.
Plane Dr is offline   Reply With Quote
Old 07-10-2013, 06:43 PM   #19523
59DEN
59DEN's Avatar
Oddometer: 882
FCR 39 for Tubliss system.
Hi, I have a spare FCR 39 that I would like to swap for a 21 and 18 inch Tubliss system (Gen2), plus spare inner tubes to suit.
If interested give me a PM,
Cheers
Dennis
59DEN is online now   Reply With Quote
Old 07-11-2013, 02:29 AM   #19524
John_L
Oddometer: 527
Wolfman Racks
I've got a left over set of Wolfman side racks from my DRZ if anyone is interested.
Feel free to make me an offer.
Here's the Flea Market Ad.
www.advrider.com/forums/showthread.php?t=900465
Cheers
John
John_L is offline   Reply With Quote
Old 07-11-2013, 09:02 AM   #19525
150ron
150ron's Avatar
Oddometer: 1,409
Put on a WolfMan enduro pocket tank bag, holds me keys, phone, wallet and camera, so i dont have to have all that stuff in me pockets anymore, definately worth the $, sets up in a few minutes, and once its on, does not budge at all, nice piece for sure imo.
Just some dude...
150ron is offline   Reply With Quote
Old 07-11-2013, 09:08 AM   #19526
Falcon86
I just work here.
Falcon86's Avatar
Oddometer: 1,698
Forgive me for asking again, but what mirrors are those? I need to order mirrors ASAP and forgot how awesome those are.
Falcon86 is offline   Reply With Quote
Old 07-11-2013, 09:15 AM   #19527
150ron
150ron's Avatar
Oddometer: 1,409
Those are the Power Madd mirrors, cost about $15-$20 bucks new for a set, depends on where you get them from, ebay, amazon, etc.
They work great, and show lots more then the stockers, they also show your blind side too, and the mirrors themselves rotate, so you can get the angle that works for you, im really happy with them.
Just some dude...
Old 07-11-2013, 09:18 AM   #19528
Falcon86
I just work here.
Falcon86's Avatar
Oddometer: 1,698
And it looks like you just used the same bolt that was there securing the plastic handguard to the barkbuster?
Old 07-11-2013, 09:29 AM   #19529
150ron
150ron's Avatar
Oddometer: 1,409
Same spot, different bolt, i needed one that was a bit longer, so that i could slide the mirror on it, and then washer and locknut to keep it in place.
The mirrors swivel too btw, if you need them too, but even in a drop, they do not get damaged, as me how i know
Just some dude...
Old 07-11-2013, 09:37 AM   #19530
joec63
joec63's Avatar
Oddometer: 280
Ron, looking good. How's the bike been now that you've had it awhile? Looking to move up myself but may still keep the 250.
________
Semper Fi
joec63 is offline   Reply With Quote
Times are GMT -7.   It's 09:17 PM.
