Old 07-11-2013, 04:38 AM   #1081
JimVonBaden OP
Oddometer: 53,263
Originally Posted by Ride4Coffee View Post
I think I see another Tech Day project for me!
Hey Jason,
You are welcome to come by and assist/watch if you like.
Jim
Old 07-11-2013, 08:27 AM   #1082
Sniperx
Oddometer: 465
Are you guys putting lenses in these too or just swapping bulbs? I did a hid conversion in my Vw bus a few years ago. I pulled it out in a month. Withou the lens the light is just a scatter all or the place. Yeah it was bright but the reflector tech didn't match the bulbs output pattern. I was lighting street signs 2 block down even when the light was properly aimed. The lens collects and focuses the light as well as provides acut off to protect other drivers. My high watt h4 bulbs put out a cleaner brighter light than the Hid kit did.
Sniperx is offline   Reply With Quote
Old 07-11-2013, 08:33 AM   #1083
JimVonBaden OP
Oddometer: 53,263
I know it is a long thread, but go back to the first few posts and your questions will be answered.
There is some dispute about the shape of the reflector, but most agree it works fine. The "lens: is clear, it is all reflector.
Jim
Old 07-12-2013, 02:21 PM   #1084
JimVonBaden OP
Oddometer: 53,263
OK, 5 years after I installed my first HIS in an R1200GS I have done it again. The basics are the same. The HIDs are now cheaper and smaller. The ballast is almost the size of a slim ballast, and I got the kit with two HIDs for only $27 off E-bay. No issues installing them, actually they were even easier, and they work without a fault in my 05 GS.
The photos will not come with descriptions, because you can get the info on the first few posts.
Jim
PS Please do not quote the whole post if you have a question or comment. Just select the appropriate photo.
Old 07-23-2013, 08:54 PM   #1085
strangebru
strangebru's Avatar
Oddometer: 11
DDM Tuning 55watt: the good, the bad, the ugly
I've had 4 DDM Tuning 55 watt HID's (5K & 4.5K) installed for about 2 months now in the headlights and OEM fog lights of my 2012 R1200GSA and this what I've experienced.
The good: awesome lighting, much better than and much more light especially in dark back roads where you really need it. Very bright in the daylight and attention getters for potential drivers who might otherwise pull out or turn in front of you. I would only get flashed at night if I had the fogs on with lo-beam headlight. No melting or heating problems of the OEM equipment with the 55 watt in. For several weeks I had no LAMPF!...until...
The bad: several weeks into the install I noticed the low beam was not coming on or would come on after restarting my motor and eventually failed to come on. Swapped it with the hi-beam and got it to work. Then one of the fog lights went out. I ordered two extra 55 watt ballasts and bulbs. I replaced both failed ballasts and all was good in the world...until..
The ugly: So originally I put in the ugly as failure of 3 of the 4 installed ballasts while I was on my 2000 mile trek...BUT...now that I'm back and had a moment to test them...well, they all worked!! Seems I need to wire them directly to the battery because for some unknown reason the ZFE has decided to shut off the extra power they need to start up. My bad :/ Which is kinda weird since they used to work with stock wiring but now they don't.
Conclusion: I know some people are getting their DDM Tuning 55 watt HID's to work with stock wiring but after a while it was insufficient on my 2012 GSA. The remedy seems to be a wiring harness coming off the battery.
DDM Tuning was very prompt getting me an RMA and the lifetime warranty means I can send as many back as I need to but the thought of screaming through a dark night on a back road and my lights suddenly going out is a bit disconcerting. DDM will be getting 2 out of 6 ballasts returned when I get home...it's not good Goose...time to punch out!!!
Most of the 55 watt ballasts I saw were some form of the China imports with few exceptions including DDM's. I'm now looking at the Morimoto's from Retrofit Resource but I'd pay 5 times as much. They're made in Japan and hopefully not a China import in a different wrapper!!
I've scanned through most of this thread and it looks like currently FutureVisionHID ($250+ for a pair...gack!) has the best review followed by the Morimoto's ($150/pair). Although the 35 watt ballasts seem to be much more reliable all the way around...if I could just get over the power of those 55 watters...I'm slightly addicted to them now
Anyone else have a better source for 55 watters????
I have the Morimoto's 5-five's mounted and installed on all my GSA lights. I'm quite impressed with the Morimoto's...they're a little smaller than the DDM's but only slightly thicker and do not have a separate igniter. The 4300K lights are impressive at night. I tried using the Morimoto error cancelers (they call it "Standalone CAN-BUS") but they didn't work on either the lo or hi-beam. So far the stock BMW aux. fog light plugs will power up with the ballasts as does as the hi-beam plug (no relays needed for the time being and no LAMPF!). The lo-beam LAMPF! error shuts down the power after a few seconds even when connected to the Morimoto however when the lo-beam plug is attached to a relay it stays powered despite the LAMPF!. FYI, the Morimoto's power up significantly faster when it's attached to the battery by a relay. The lo-beam was the only lamp giving me a LAMPF! so I tried load resistors to see if that works. The common 6-ohm 50 watt nor the 6 ohm and 18 ohm 100 watt load resistors did the trick, BUT, even with a large aluminum heat sinks they got too hot, so now I'm looking for a suitable add-on 10 watt light which is enough to cancel the LAMPF!.
To conclude, what worked was...Morimoto 5-five's, a relay for the low beam and the low beam plug powering the relay and a 10 watt light (I just added a small marker light to the rear of my motor) and no canbus eliminators. A set of aux lights connected to the lo-beam would work as well.
strangebru screwed with this post 09-06-2013 at 10:19 AM
strangebru is offline   Reply With Quote
Old 07-23-2013, 10:13 PM   #1086
WindSailor
WindSailor's Avatar
Oddometer: 712
I don't think the Future Vision 50W ballasts are going to be compatible on your low beam side.
50W SLIM BALLAST TECHNICAL SPECIFICATIONS
Model HD-B50-HID
Input Voltage Range 9-32VDC
Typical Operating Voltage 12.8VDC / 24VDC
Typical Input Current 4.3A @ 12.8VDC / 2.2A @ 24VDC
Max. Inrush Current 8.5A
WebJester has done some valuable testing regarding the parameters on the low beam...
Originally Posted by webjester View Post
So, it is finally cold enough in Michigan and, sadly, too cold for my DDM HID kit. Below about 65F the low beam craps out, i.e., LAMPF! (despite the "CAN Bus cancellers" from DDM). So far the high beam has been working down to 40F. We'll see how it holds up when the winter comes.
Just to reiterate, the central control electronic measures the current to the low/high beam and disables the output if the current is either too low or too high to warn of a failed bulb or prevent circuit damage, respectively (remember, this bike does not have fuses). It does that by measuring the voltage across a shunt inside the module and only allows a certain voltage window.
After reading the recent posts I decided to do some further tests and here are the results (2008 R1200GS):
A. Forget the resistor in series. The HID module controls the power, that means if you reduce the effective input voltage by using a series resistor the HID tries to compensate by increasing the current. I confirmed this with an adjustable power resistor. Once the resistor is big enough the HID just starts to flicker. I managed to get the HID to stay on for a maximum of 250 milliseconds. That's it. So the module checks the current after 250ms after start-up (again).
B. By using an adjustable resistor instead of the HID, I also measured the thresholds (low and high current) to find the point at which the central controller shuts down the low beam. The upper threshold was at about 6.2A @14.2V. The threshold is probably somewhat lower while the alternator gets to full output. During this time the current rises (for about 2-3sec after crank). The lower threshold was at 0.86A @14.2V. So, the current must be between these two values to be acceptable for the central controller.
I didn't check the high beam as these thresholds are typically higher,
This confirms everybody's findings:
A. Some kits are just above, some below the 6.2A. Keep in mind that there is also some tolerance of the threshold from one bike to another.
B. Using a relay to switch battery directly to the lamp will work if you have a resistor in parallel to the relay coil of about 14.2V/0.86A = 16 Ohms to satisfy the minimum threshold. Maybe 15 Ohms to be on the safe side. At 14.2V this resistor "consumes" 14.2Vx14.2V/15Ohms = 13.5Watts. Make sure that the resistor has adequate cooling surface. A 50W resistor can only handle 50W with a huge heatsink!!! Consider using a 15W or 18W automotive lamp instead (you know how hot that gets! The resistor is no different).
Finally, there is one other option I am going to investigate when I have some more time (not for the faint hearted ). As mentioned earlier the central controller uses a shunt to measure the current. If I could reduce that shunt by, say 20%, the thresholds for the current would increase by 25%. But there are a bunch of "If's". I would assume that the module is sealed against water intrusion etc. - We'll see. I'll report back if this is feasible (you can really fuck up your bike if something goes wrong ). Anybody know off hand where this module is hiding??
Cheers
The newer Morimoto's are close to that upper value. I can't say whether they would work without using a relay and a load resistor or not. So far on my setup, they haven't let me down once I got the load resistor value right and my connections tight.
There currently may be more options out there. Don't know...
Anyway - always keeping an ear open to new ideas and information on what other people are doing.
WindSailor is offline   Reply With Quote
Old 07-24-2013, 05:01 AM   #1087
TuefelHunden
TuefelHunden's Avatar
Oddometer: 600
JVB, which kit did you get? There are a zillion on eBay and they vary in price.
Right now I'm waiting for HIDSRUS to send me a new bulb, but it may be the ballast that is the problem and it may have to be replaced too. This is warranty stuff. I may just spend $30 and get a new set. My 55W DDM high beam has worked for about two years without a problem. It has always been a low beam issue, 35 or 50 watt.
IMO this is absolutely, positively NOT a CanBus issue. It is a ZFE issue AND not only do the ZFE's vary each year, but IMO they MUST vary in production units. I believe that because on a bunch of these threads DDM's will work for one person and not another. WebJester's info is excellent. IMO when you read most of the threads on the HID failures, it supports my theory that the ZFE's cut off is not totally the same from unit to unit.
Old, but not Dead
TuefelHunden is offline   Reply With Quote
Old 07-24-2013, 06:15 AM   #1088
JimVonBaden OP
Oddometer: 53,263
I have this kit, and it has worked flawlessly for the last two weeks.
http://www.ebay.com/itm/281008218250...ht_5611wt_1340
In my experience the 55 watt lights have many more lampf issues than the 35 watt kits. I find the 35 watt kits still produce much more than stock H7s.
Jim
Old 09-06-2013, 05:15 AM   #1089
smokeeater495
smokeeater495's Avatar
Oddometer: 602
I just installed 35w DDM kit. Light output seems considerably less than 55w I had on my Tiger? Went with 35W to avoid LAMPF issues.
Harley, been there done that. Don't want to be a pirate.
smokeeater495 is offline   Reply With Quote
Old 09-06-2013, 06:30 AM   #1090
genka
SUV hater
genka's Avatar
Oddometer: 1,624
Another way to deal with the LAMPF issues would be to run aux lights from the low beam circuit and power the HID through a relay.
When I was playing with HIDs, I thought about the same solution webjester described- modifying ZFE's current sensing shunt. But I don't think ZFE is serviceable. On the pictures it looked sealed.
Форум мотоциклистов в США http://www.xytopok.net/mvnforum/listthreads?forum=31
genka is online now   Reply With Quote
Old 09-06-2013, 08:20 AM   #1091
TuefelHunden
Oddometer: 600
Jim
Thanks Jim, I got the kit and it has worked very well. Totally agree about the 55w being more trouble, but not on high beam. From what I have experienced the ZFE senses current and/or voltage on low beam but on high beam it seems only to sense if the light is burned out or missing.
The 55 on high is great because it definitely pumps out some light; however, IMO way too much for low beam. I rarely get flashed on low beam by oncoming cars. I'm sure that would not be the case if I could get a 55 to go around the ZFE.
Old, but not Dead
Old 09-26-2013, 03:07 PM   #1092
Falco888
Falco888's Avatar
Oddometer: 63
2013 r1200gsw
Has anybody install a HID on the 2013 GSW?
thanks!
Falco888 is offline   Reply With Quote
Old 09-26-2013, 03:22 PM   #1093
dirty_t
dirty_t's Avatar
Oddometer: 153
Jim
OK - quick question, JimV - what are you using for the clear headlight guard? Is that homemade, or bought?
dirty_t is offline   Reply With Quote
Old 09-26-2013, 04:01 PM   #1094
JimVonBaden OP
Oddometer: 53,263
Home made from polycarbonate.
Jim
Old 09-26-2013, 04:42 PM   #1095
Ride4Coffee
Ride4Coffee's Avatar
Oddometer: 210
Jim
Hey Jim, How's the kit held up over the past couple months that you've had it? I'm shocked to see a HID kit for $24. I just thought it would be some major expense.
IBA# 57940
Need the 90mm bolt for your Kaoko?
Ride4Coffee is offline   Reply With Quote
Times are GMT -7.   It's 01:17 AM.
