Old 06-28-2013, 04:37 PM   #601
just jeff
Oddometer: 1,091
Originally Posted by flxibl2006 View Post
I think he is saying without saying, know what I am saying? I have the same problem, '08 KLR650 right front valve cover bolt stripped. Found many of the same bolt holes stripped in my quest on many multiples of sights It is a special flange head bolt so using a longer bolt is not feasible. The bike is in a very "rural" area in the south central Philippines so no Graingers or anything else around the corner. Whatever the fix it needs to be strong and done with normal shop tools (ie no machines)
Thanks, Scott
You could certainly drill and tap the stripped hole for a Helicoil using a hand drill. Could you not get a Helicoil thread repair kit mailed to you?
My further investigation of the Loctite and Permatex liquid thread repair revealed that on a 6mm bolt it is only capable of 23in/lbs. Hardly worth doing in my opinion.
Regards....justjeff
just jeff is offline   Reply With Quote
Old 07-01-2013, 09:11 AM   #602
dirty_sanchez
Dirty_Sanchez
dirty_sanchez's Avatar
Oddometer: 2,967
Team-
I've been completely out of pocket @ Philmont for the last 2 wks and just now got back to civilization.
That Stripped thread repair kit isn't the thing to ise on stripped metal inserts in a plastic tank.
I'd use a suitable plastic adhesive in the stripped out hole, press the metal insert back in place, apply a very thin fulm of grease/release on the male threads, thread the fastener in the insert.
Then give the fastener an eighth or quarter turn every 5 minutes until the adhesive hardens a bit.
Dirty
No, really, the mustache means I love you.
dirty_sanchez is offline   Reply With Quote
Old 07-02-2013, 07:05 PM   #603
khpossum
poster
Oddometer: 476
Originally Posted by khpossum View Post
My XChallenge has a plastic tank. On top is a vent cap that is bolted to the tank with course SS screws, probably self tapping. Some of the threads in the tank are stripped. The threaded tank holes are blind holes. Does the Loctite form a thread have any chance of working in this application?
Dirty, any thoughts about this?
KP
khpossum is offline   Reply With Quote
Old 07-02-2013, 07:24 PM   #604
dirty_sanchez
Dirty_Sanchez
Oddometer: 2,967
KP
See post #604.
Working off of my B berry I forgot to mention you'd have to clean out the stripped out hole, let evaporate, dispense a dab of resin into the hole, press in the metal insert, then do the other things I suggested.
Dirty
Old 07-11-2013, 12:25 PM   #605
Motomantra
Registered Lurker
Motomantra's Avatar
Oddometer: 1,349
What's Dirty have to say...
I didn't read the whole thread, too lazy.
I have used regular J-B on engine side covers, no problem. Is there anything you can recommend for my on road repair kit that will seal a damaged engine cover that doesn't take 24 + hours to set?
Thanks Dirty
For those that fight for it, freedom has a flavor the protected will never know.
Motomantra is offline   Reply With Quote
Old 07-11-2013, 01:17 PM   #606
dirty_sanchez
Dirty_Sanchez
Oddometer: 2,967
Thanks Dirty
Metal Magic Steel Stick pn. 98853. I travel with half a stick and a few extra pairs of purple rubber gloves.
This stuff also kept my buddies boat from sinking at the mouth of the MS river years back when he ran it up on a rock jetty and holed it so bad the bilge pump couldn't keep up.
If you haven't already guessed it-I'mma believer.
Dirty
Old 08-11-2013, 02:51 AM   #607
stainlesscycle
stainlesscycle's Avatar
Oddometer: 2,270
i have loose threads on a shock reservoir schrader valve - the thread clearance of the shrader external threads to the reservoir body is terrible - i tried teflon tape and it leaks down over time... you have a thread sealant that might work for loose fit threads? 577 maybe?
current bikes
stainlesscycle screwed with this post 08-11-2013 at 02:58 AM
stainlesscycle is offline   Reply With Quote
Old 08-11-2013, 03:08 AM   #608
stainlesscycle
Oddometer: 2,270
i have motor mount bolts that loosen overtime. i was hoping to find a mechanical lock that works, but nothing seems to work..so maybe a chemical product will work... i have tried nord-lock and they still loosen overtime. i tried blue loctite, safety wire, double jam nut, nylock, split lock washers, and toothed lock washer (din 6797) and they still loosen. i have to retorque every 8 hours or so. is there a anti-vibration product that works? i really do not want to use red loctite, as i can't torque check them at all ...not like i need to - you can feel/hear when they loosen up and prevailing torque goes way down... ... and a couple times a year i pull the motor...it's a small 2 stroke, it doesn't feel like it vibes that much, but it is constantly loosening the mounts....
current bikes
stainlesscycle screwed with this post 08-11-2013 at 06:14 AM
Old 08-11-2013, 05:29 AM   #609
dirty_sanchez
Dirty_Sanchez
Oddometer: 2,967
577, 567PST, 565, or 545 all would be just fine to use on this application.
We're dealing with small parts, so apply the product one thread back from the tip end of the threads on the schraeder valve, 360 degrees, smear it into the threads so that the thread trough if full and you see the crown of the threads on the schraeder valve so we don't run the risk of getting thread sealant into the shock internals.
Let it sit overnight and you'll be Ace!
Dirty
Old 08-11-2013, 06:09 AM   #610
stainlesscycle
Oddometer: 2,270
all about the same price (567pst is a little more..) - so which one is best/whats the main differences?
current bikes
Old 08-11-2013, 07:30 AM   #611
stainlesscycle
Oddometer: 2,270
scratch that - mcmaster carries the .5ml bottle of 545 for under $2.00 - adding it to my next order. nice to have a single serving size!
current bikes
Old 08-11-2013, 07:33 AM   #612
wrk2surf
on the gas or brakes
wrk2surf's Avatar
Oddometer: 6,840
Thanks Loctite for the racing help! never saw this thread but will keep an eye on it!
wrk2surf is offline   Reply With Quote
Old 08-12-2013, 10:34 AM   #613
Twin-shocker
Oddometer: 1,673
A very good Loctite product that sticks things where most other things fail, is 480. A form of glue thats used to stick the studs into tyres fitted to ice race cars. Have succeeded in sticking rubber to plastic with it, and it seems to work on pretty much anything.
Old 08-12-2013, 10:58 AM   #614
Motomantra
Registered Lurker
Motomantra's Avatar
Oddometer: 1,349
Hey, Stainless
I was thinking about your vibration issue with the 2 stroke. I have tried, with some success, to tailor fit the bolt/hole relationship. Having the bolt fit perfectly snug in the hole has helped stop the bolt from loosening.
If you have the right sized reamer can you find a bolt slightly larger, then fit it with the reamer. Anyway, it worked on my old Triumph (not Henkley). The particular frequency of the vibration will have its own type of problem. That is to say; what works at one frequency may not work for another.
Good luck.
Old 08-22-2013, 04:17 PM   #615
leonphelps
TAT/Prudhoe Bay
leonphelps's Avatar
Oddometer: 1,044
Which Loctite for my rifle
@dirty_sanchez....
I am building an AR15 rifle and I'd like a recomendation for which loctite to use on the Gas Block screws. Most people say to use RockSet because it is good to 500 degrees. The forms say (I know, I know) that I want the equivalent of Loctite Blue but with temperature resistance to 500 degrees. The barrel gets pretty hot with sustained fire.....
Any help would be great. Thanks....
leonphelps is offline   Reply With Quote
Times are GMT -7.   It's 02:47 PM.
