Old 07-11-2013, 07:38 PM   #78601
JTB488
Oddometer: 152
Riding behind the truck...is it available on iTunes yet??
JTB488 is offline   Reply With Quote
Old 07-11-2013, 07:44 PM   #78602
AKASY
Noob
Oddometer: 2,170
Oil Filter Cover
On my last DR I did a good job of scuffing up the oil filter cover. Since then I have seen two others cracked by rocks--one we had to leave in the boonies until we could get a truck back in to get it. I ordered a cover but it did not clear my skid so I did some improvising.
Here are a couple of pics of what I came up with--don't know how well it will work if stress tested but I'm hoping it will at least give my oil cover some protection if I encounter a rock during a dirt nap.
Don't make the mistake of believing everything you think.
AKASY is offline   Reply With Quote
Old 07-11-2013, 08:00 PM   #78603
RideAlongAtlas1
IS GOOD ! ! !
Oddometer: 147
Thanks. Would be good if it got into a few office buildings on a Friday afternoon. That might make it a mild youtube HIT. It was a rainy day and I was rather excited. Rain gets me excited. Like an animal
Song: http://www.youtube.com/watch?v=SRoyXtdfd5M
[IMG][/IMG]
See my DR650 motovlog here https://www.youtube.com/ridealongatlas
RideAlongAtlas1 is offline   Reply With Quote
Old 07-11-2013, 08:05 PM   #78604
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Originally Posted by DockingPilot View Post
Well the counter sprocket was a little more hooked then I thought after pulling it off.
So a little 10k mile freshen up was in order.
New counter sprocket
Yea, your front sprocket shows more wear than I initially thought from the other pic. Looks it's been exposed to Salt as well?
Is it Suzuki OEM sprocket?
I'd also be concerned with your rear sprocket. Kinda "Pointy" no?
Hard to tell ... fuzzy pic ... but I'm guessing it's past due for replacement.
Is that a stock Suzuki sprocket? If not ... what brand?
Looks like you're ready for the rest of Summer! Safe riding!
Old 07-11-2013, 08:34 PM   #78605
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,723
Originally Posted by RideAlongAtlas1 View Post
Well it's Friday here in Australia.
I made a song while riding my bike.
Whilst on my DR650 of course.
My song is called "Staying behind the truck, not going to get F^cked."
Uhhhhhhhhhhhhh
Old 07-11-2013, 09:55 PM   #78606
Mambo Dave
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,692
Neat, but you could have just bought a cover for it - and the covers seem like they'd really protect the housing. This is my bike:
"After reading through this thread I've come to the conclusion
that more people cruise the internet looking for reasons why
X bike won't work in Y scenario rather than actually riding
their motorcycles
RyanR
Mambo Dave is online now   Reply With Quote
Old 07-11-2013, 11:25 PM   #78607
GSF1200S
Oddometer: 976
Ok, so with this all past me, I have a crazy theory. Tell me what you think of this:
I started out using kerosene in a squirt bottle and bel ray chain lube. Having no experience on the road, I figured kerosene could be easily sourced. I was wrong. As I ran into only being able to buy large quantities of kerosene, I switched to wd40 since I had read in many places about guys using that to clean their chains. I would spray the chain with wd40, then wipe it off with a rag, then apply chain lube and let it dry. I would always do this when the chain was hot.
The problem is, as some have mentioned, wd40 is a penetrant. My theory is that the wd40 penetrated the orings and ruined the grease inside, and soon the chain started rusting internally (despite my cleaning and lubing). At the same time, the Keintech simple stand I use isnt the most stable, but certainly weighs less, costs less, and takes zero ground clearance when stowed compared to a center stand; this stand allows the bike to move a little when I would spin the wheel to blast the chain with wd40. Overspray prolly hit the spacer by the cush hub bearing a number of times, consequently pentrating the seal (or around the bearing perhaps?) and destroying the grease in the bearing. As the bearing wore, it started to place all sorts of additional force on the wheel bearings and caused the one nearest to the rotor to start going bad. **EDIT** I really am not sure the cush bearing could put additional force on the wheel bearings, but id like your opinions.
I always check the wheel for movement when I deal with the chain, but I will confess I didnt always check the sprocket for lateral movement. This happened fast because I know in fairbanks there was no wheel slop at all.
Maybe im reaching here, but the cush hub bearing definitely had a rusty runny watery crap coming out of it, and this theory seems plausible.
Anyone else want to part some wisdom on me? I feel really stupid (and I was for sure) but at least I know better now. Im using diesel in a squirt bottle to clean the chain and silicone lubricant to keep the orings conditioned. I clean when warm, and I wipe the chain off before extended dirt sessions. Sound right?
Moral of the story: dont blast wd40 on chains or by accident, bearings. I guess some might spray wd40 on a rag, but for me diesel is so cheap, abundant, convenient and good at cleaning that Im just going to use it from now on.
GSF1200S is offline   Reply With Quote
Old 07-12-2013, 01:26 AM   #78608
BergDonk
BergDonk's Avatar
Oddometer: 3,722
Originally Posted by Adv Grifter View Post
Good post mate!
But I believe in cleaning my chain. Lots depends what you use for a chain lube. If a rider is using a Sticky/Tacky type lube ... and riding off road ... that chain/sprockets will need cleaning.
If you never go off road, and use something like a "lite" Teflon type lube, then nothing much to clean.
When you clean you shouldn't be forcing anything past plates to damage X rings ... UNLESS you are using a Wire Brush! I use a soft cloth and some WD40. When I'm using Teflon lube, I get some grit on my chain. With Teflon I simply spray on more Teflon ... then wipe it down. All clean, Grit removed. Done. But it doesn't last long ... maybe 100 miles.
With 90 wt. gear oil on multiple day rides, 400 mile days, I spend a bit more time cleaning and sometimes use some WD40, Kerosene or even Diesel to speed things up. I don't soak it ... just enough to shine up chain and remove grit off chain and sprockets.
Takes less than 3 minutes. (including wiping down rear wheel)
Off road I don't use any lube at all during the riding day. At days end I clean and lube the chain. (if I'm in one piece and still conscious )
Great comments on adjusting chains, changing CS sprockets and checking for wear. A++++ !
Maybe.
But as I stated above, don't over lube a chain, and there is no need to clean it, ever. And even if there is crud build up on it, its not on the wear parts, and its only cosmetic. IMHO, YMMV
shed time IS quality time
BergDonk's DR650 BergDonk's XT1200Z
BergDonk is online now   Reply With Quote
Old 07-12-2013, 03:48 AM   #78609
greer
Oddometer: 3,822
Tires
Take a look at the Shinko 244's and 705's.
Sarah
Originally Posted by SOTA View Post
New here I got a 2003 dr650 and I love it I've rode it a lot off road but I just got it registered and I need some good road tires I would like a 50/50 tire or maybe 70/30. I'm running a death wing up front and a Dunlop d606 in the rear the 606 is great in off road not the best on
'08 DR650
greer is online now   Reply With Quote
Old 07-12-2013, 04:41 AM   #78610
dankatz
Oddometer: 354
Sarah
The Shinko 244 are very inexpensive and great on the road (haven't had the experience of taking them offroad). Despite looking like 50/50 tires, I would say they are more like 70/30 tires. I will be replacing mine with the same ones. Interesting that the guy I bought the bike from had given me Dunlop 606's as well with only 100 miles. He hated them on the highway and immediately took them of.
dankatz is offline   Reply With Quote
Old 07-12-2013, 05:04 AM   #78611
DockingPilot
Hooked Up and Hard Over
DockingPilot's Avatar
Oddometer: 9,732
Hey Grift,
Yep, OEM, all of it. Even the new cs.
No salt water, I don't ride it to work. I guess it's just the photo.
Rear is good, I comped it to a new new, about the same.
And your are really spot on with the new cs and rubbers, the difference is quite noticeable!
Frank Reinbold
"Every bike I ever had, was the best bike I ever had, when I had it"
DockingPilot is offline   Reply With Quote
Old 07-12-2013, 06:11 AM   #78612
AKASY
Noob
Oddometer: 2,170
Cover
Originally Posted by 955616846 View Post
If you haven't sold the AMP cover it can be fitted with a little easy modification to the skid plate - it only needs to be spread 1/8-1/4".
I tried that and it could be fitted but it would be tight and difficult during oil changes. I also did not like the way it stuck out to the side. Still have not sold it, no rush of potential buyers
Old 07-12-2013, 06:12 AM   #78613
NWBoon
Oddometer: 88
Very true, especially staff at the Dirt Bike magazines. At City Bike (San Fran) we were a bit different. We embraced the DR (I attended the original product Launch in the Mojave in 1996) and our publisher owned two DR650's and supported the idea of low cost bikes for budget conscious riders. We lent out DR test bikes out to everyone ... no one could break them.
We even supported and sponsored some RTW travelers ... like Ted Simon and Greg Frasier ... and several more unknown riders. So not ALL mags are bad guys!
The shiny mag guys are jaded ... their purview is Race Bikes and the Moto Cross business (stress BUSINESS here) for the most part. Their demographic are ages 12 to 19. They just don't get ADV travel or exploring ... and it doesn't pay the bills either. Look at who there advertisers are. But there are ... thankfully, other mags ... and of course ADV rider.
The Dirt Bike mag guys rarely leave the L.A. area on a motorbike ... and never travel solo off road. If they go somewhere, it's in a $40,000 pick up truck on loan from Ford or Toyota. None ride on the street.
So, grain of Salt here. Don't take offense. Take heart and support mags like MCN. Editor Dave Searle has done specials all about the DR650 and understands LOTS of "Real" working man riders love this bike. He owns one and "gets" the DR 100%.
Wow, City Bike is a magazine name I hadn't heard in years! I went to college at Sacramento State from 1990 to 1995 and really enjoyed reading that publication. My only form of transportation from 90 - 94 was a 1988 Kawasaki EX500. I put 33,000 or so miles on that little bike and had a blast with it (first motorcycle). Thanks Adv Grifter for lots of great reading back in my wild days.
NWBoon is offline   Reply With Quote
Old 07-12-2013, 07:08 AM   #78614
malignity
The Hurt Locker
Oddometer: 409
Hey everyone,
I'm looking at possibly getting a 2000 DR650. Its got about 22,000 miles on it. How many more miles on average will I be able to get before I'm looking at a rebuild?
With proper suspension, will a DR650 be able to achieve freeway speed with a 240lb driver and 170lb passenger?
I want a backup/guest 'dirt bike', but also would like to kill two birds with one stone and have an adventure bike for my wife and I. The XR650L is too tall for a passenger, and the KLR is too heavy to be used as a dirt bike.
I'm hoping the DR650 will fit.
'10 Yamaha WR250R , '93 Yamaha TW200, '03 Honda Foreman 450ES 4x4, '96 Yamaha Big Bear 350 4x4. www.gldsmc.org
malignity is offline   Reply With Quote
Old 07-12-2013, 07:22 AM   #78615
MrBob
Certified Geezer
MrBob's Avatar
Oddometer: 7,563
Fabricating your own part always trumps just being able to whip out a credit card.
"When I was younger I was afraid I'd die riding now that I'm old and falling apart, I'm afraid I won't."
bwanacswan's dad
MrBob is offline   Reply With Quote
Times are GMT -7.   It's 04:36 AM.
