Old 07-12-2013, 03:45 AM   #60586
techforlife
CDI REPAIR
techforlife's Avatar
Oddometer: 4,333
Originally Posted by kenny61 View Post
I tried it with the lip towards the crank and gear facing the cover. I found the chain rubs the drive gear that way, so did this guy http://www.advrider.com/forums/showthread.php?t=676313
This vid shows it with the lip facing away from the crank too, as well as any other pictures and vids that I was able to locate
GOOD TO KNOW,,,,i thought i was losing it,,,,more than usual anyway
But i think they upgraded the pic of this in the manual in 1995 from my 1993 manual in my findings due to the crappy pic in the earlier manuals...my 95-2004 manual has a real good pic..but i still don`t trust manuals....i`ve had issues with this manual before..
B
techforlife screwed with this post 07-12-2013 at 04:34 AM
techforlife is offline   Reply With Quote
Old 07-12-2013, 04:09 AM   #60587
Lost on Row 1
Lost on Row 1's Avatar
Oddometer: 247
Originally Posted by mcma111 View Post
B,
I'm not trying to piss you off. Even if I wanted to...
The gear has a spacer on one side. That spacer or collar goes towards the engine case and the gear teeth are away from the case.
The powerband is installed backwards.
1993 XR650L; 14T CS, Dave's carb mod, Modified stk muffler, Airbox Mod, Battery relocation, Bar risers, Uni filter, No passenger pegs(to make it super lite), Blue powerband.
Lost on Row 1 is offline   Reply With Quote
Old 07-12-2013, 04:36 AM   #60588
techforlife
CDI REPAIR
Oddometer: 4,333
Smarten up........
The powerband has a 13 spline 40mm hole in one end and a 23 spline 30mm hole in the other.......you can`t put it on wrong even while drinkin,,i tried.......
B
Old 07-12-2013, 05:55 AM   #60589
prince_ruben
prince_ruben's Avatar
Oddometer: 1,734
Originally Posted by techforlife View Post
hmmmmmmmm..never heard of anyone with a bad reg yet,,this`ll be a first...i`d go OE...i`d never put anything but on these bikes as the charging is usually bulletproof...
B
I'll take another stab at troubleshooting the charging system. Voltage drops as RPM's increase and the battery isn't getting charged as the bike runs. Thanks.
prince_ruben is offline   Reply With Quote
Old 07-12-2013, 06:01 AM   #60590
RZRob
RZRob's Avatar
Oddometer: 1,699
Interesting. Of course you've triple-checked connections and grounds. I'd especially check the plug coming off the motor (stator). What you're describing was exactly what my Aprilia did when the stator packed it's bags. When I pulled it off to have a look, it was visibly toasted - as was the plug going to the reg. I've fried an RZ stator before from too many farkles (heated grips etc.)vrunning for too long.
RZ Rob
RZRob screwed with this post 07-12-2013 at 06:07 AM
RZRob is offline   Reply With Quote
Old 07-12-2013, 06:23 AM   #60591
XR650L_Dave
Oddometer: 3,761
Originally Posted by KyoXR View Post
I was looking at the XCMH as the next front tire to try ,
Have you tried a Surge I front tire? I would like to hear how you think that compares with the XCMH and the Scorpion Pro, traction wise.
(RZRob) the damper looks good, I really like mine.
No, I have only run the stockers, MT-21s, XCMH, the old MT18HD, the terrorflex, and the one scorp on the front.
I have been out once this year, in may, I do not think I'll need to replace my worn tires anytime soon.
I was always used to riding alone, then I had a few years where folks were actually going out and riding, got used to company, now no one else goes out anymore- or at least doesn't tell me ahead of time.
So, I haven't gotten back to just going out when I have a chance vs. saving my opportunities for when there's a group ride.
---->>Thanks for the rotor, guys!<<----
XR650L_Dave is offline   Reply With Quote
Old 07-12-2013, 06:29 AM   #60592
prince_ruben
Oddometer: 1,734
RZ Rob
Single checked but I'm heading to the lab now. Thanks.
Old 07-12-2013, 06:50 AM   #60593
techforlife
CDI REPAIR
Oddometer: 4,333
I`ve heard of 2 guys that blamed the reg for not charging,,,,,,,,,but eventually found the ground under the seat was the issue,,just sayin...
B
Old 07-12-2013, 09:14 AM   #60594
prince_ruben
Oddometer: 1,734
B
Yeah Checked that TFL. It was fastened but had some corrosion. I removed the bolt and used 230 sandpaper to clean the connection. I just went over the bike checking the grounds and everything looks clean, wires are intact, no pinching identified. I'll spent more time to review again, button the bike back up and conduct more testing. Thanks again.
Old 07-12-2013, 10:00 AM   #60595
Spud Rider
Spud Rider's Avatar
Oddometer: 3,815
At the 2:50 mark he put the pulse generator rotor on backwards, didn't he? The nub should be located away from the cam chain, or it won't trigger the pulse generator.
Spud
Spud Rider screwed with this post 07-12-2013 at 10:30 PM
Old 07-12-2013, 10:16 AM   #60596
Mossy-Back
Wet-Sider
Mossy-Back's Avatar
Oddometer: 1,652
Originally Posted by purpledrake View Post
Glad to hear it. 2 more months to Roosie elk season, no?
Been too busy to think about hunting season lately... 9 hour work days with a 45 minute commute one-way makes it more like 11 hours total. Not a great schedule, but getting lots of good experience working for BLM, maintaining OHV trails, and getting paid to ride them too!
'05 CRF450X
Once a Marine, always a Marine!
Mossy-Back is offline   Reply With Quote
Old 07-12-2013, 10:18 AM   #60597
XR650L_Dave
Oddometer: 3,761
BTW the regulator does its job by 'eating' any extra power.
If it is doing that at all, it should get at least warm.
Old 07-12-2013, 10:19 AM   #60598
AZ TOM
Oddometer: 4,089
Originally Posted by Spud Rider View Post
At the 2:50 mark he put the pulse generator rotor on backwards, didn't he? The the nub should be located away from the cam chain, or it won't trigger the pulse generator.
Spud
I would say yes
AZ TOM is online now   Reply With Quote
Old 07-12-2013, 10:50 AM   #60599
techforlife
CDI REPAIR
Oddometer: 4,333
I`ve had 1 person here and 2 at TT that put the pulse gen rotor on backwards and couldn`t figure out why it would not start...i now have a picture in PB to show them what they did wrong
B
Old 07-12-2013, 12:02 PM   #60600
RZRob
RZRob's Avatar
Oddometer: 1,699
B
That 6mm ground lug has gotten me a couple times. That's why I too mentioned to start with that.
RZ Rob
Times are GMT -7.   It's 09:22 AM.
