Old 07-11-2013, 04:18 PM   #301
blaine.hale
blaine.hale's Avatar
Oddometer: 3,178
Originally Posted by Tin Woodman View Post
Thanks Blaine for cutting to the chase - I didn't want to set off a firestorm. By the way, what oil do you think I should use?
Olive. Extra virgin.
1974 BMW R90 /6
1968 Bultaco Matador MK3
1973 BMW R75 /5 Toaster LWB
1969 Bultaco Bandido MK2
2013 Husqvarna Terra TR650
blaine.hale is offline   Reply With Quote
Old 07-11-2013, 06:04 PM   #302
Plaka
Brevis illi vita est
Oddometer: 4,609
I'm liking the sealed panasonic the PO put in. Must have 5+ years on it now.
Haven't priced a replacement.
With the small battery I would reccomend the most CCA you can stuff in there. And have a really first class full-auto-all-bells-and-whistles trickle charger/maintainer. The best you can find will pay off.
I don't think you're supposed to put oil in them. Anyway the sealed ones don't have a fill port unless you drill a hole somewhere.
Old 07-11-2013, 09:05 PM   #303
Tin Woodman OP
Mike
Tin Woodman's Avatar
Oddometer: 200
Everyone's a comedian. . .
Listen, I'm trying to run a serious thread here and all you guys want to do is ham it up with your pathetic humor. It's my thread and If anyone's gonna be pathetic, it's me.
However, while we're talking about olive oil et al, allow me to share a tidbit I picked up from a used car salesman years ago. It seems on occasion, if a clunker had a noisy transmission, he would stuff banana peels in it to quiet it down for a few miles post sale. I don't think our airhead trannies would notice a banana peel or two judging from what I've seen come out of a few of them.
One measly toaster
Tin Woodman is offline   Reply With Quote
Old 07-12-2013, 07:54 AM   #304
Plaka
Oddometer: 4,609
Wanna bet who gets their wiring done first?
Remind me to tell ya the land rover/banana oil story sometime...
Old 07-12-2013, 08:27 AM   #305
Tin Woodman OP
Mike
Oddometer: 200
Wiring - complete.
Battery - bought and charging.
Need for land rover/banana oil stories - overwhelming now that you stuck that image in my head.
One measly toaster
Old 07-12-2013, 08:29 AM   #306
Plaka
Oddometer: 4,609
Wiring - complete.
Complete, tested and documented?
Old 07-12-2013, 08:34 AM   #307
Tin Woodman OP
Mike
Oddometer: 200
Nope - dodgy, iffy, crusty and suspect. My four buddies. Again, hope rules supreme.
Land Rover/banana oil story please.
One measly toaster
Old 07-15-2013, 09:11 PM   #308
Tin Woodman OP
Mike
Oddometer: 200
Battery is fully charged and installed. All lights operate correctly with the exception of the turn signals because I haven't installed a new flasher unit. Spark plugs are bungeed to cylinder jugs and produce bright spark when I manually kick over the engine (these are the original coils - I read somewhere they have a life span of 10-15 years - these ones are 40 years old.)
Start button does not engage the starter (it's the original Bosch that I had dismantled, cleaned up and bench tested.) Traced the problem to the starter relay - looks like it's the original one, too.
With the can off, if I close the points with my finger, the starter cranks enthusiastically. According to Snowbum, I have three choices -
1. Buy a new relay.
2. Modify my existing relay (bypass the transistor circuit and run the risk of accidentally engaging the starter while the engine is running.)
3. Buy a generic relay and modify that with the same potential hazard as choice #2 above.
I welcome your recommendations.
One measly toaster
Old 07-15-2013, 10:06 PM   #309
photorider
photorider's Avatar
Oddometer: 301
You could try and fix it and probably get it to work. But, the first time your bike doesn't start you'll be kicking yourself for not replacing it. I would bite the bullet and get a new relay.
I was sure I had "fixed" mine before a trip last year. Left the house just fine. After about the sixth push start, I was calling myself a cheap bastard.
photorider is offline   Reply With Quote
Old 07-16-2013, 12:32 AM   #310
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,820
The ignition coils last a long long time. Most of was will still have these 6V series coils in another 40 years. It is a common failure point of many other ignition systems but not the early vintage Airheads.
The heavy Bosch starter is another hard working well made part on these bikes. They do have two varieties for the Airheads. Early bikes, 1970 through 1976, are 8 tooth starters. Starting in 1977 they become the 9 tooth starters. This is the major way we tell them apart. The number of teeth on the bendex matches the number of teeth on the flywheel. You use the starter that has 8 teeth.
If the stater needs rebuilding, eventually, it can be done if you have a good bendex. (that's the part that engages the flywheel) The 8 tooth bendexes are NLA any more. If you had a later bike with a 9 tooth starter those bendexes can be bought if needed.
There are after market starters that will replace the OEM one you have. They have the correct tooth count and they are lighter.
Back to the Bosch starters. There are two varieties of the 8 tooth starters. There is a longer number on the starter that is either 000115007 or 000115015. The 015 starter is later and fits earlier bikes. The 015 starter is a stronger motor. Not much difference but if you were shopping OEM starters look for the 015 starter.
Any Bosch starter with an 8 tooth bendex that works should not be thrown away but the modern replacement works better.
---Albert Einstein
Old 07-16-2013, 04:48 AM   #311
Plaka
Oddometer: 4,609
1. Buy a new relay.
You mean the starter protection relay? Throw it away. It's doing something automatically that a big boy like you can do for themselves.
I once had 2 /5's. Oe I rode and the other I parted out to myself over a great many years. So I had 2 starter protection relays. When first one died I learned to carry a little three way jumper to jump around it and not get stranded. When the second one died I jumpered it out for good. I was running Baren bar end mirrors so I had these left over holes from the original mirrors on the control perches. Just the right size for a cheapo radio shack rubber hooded momentary push button switch. This got wired in in place of the relay contacts. To start the bike I held the momentary with my index finger and hit the starter button with my thumb. Worked like a charm and the motion became reflexive on like day one. Bit of extra security too...you couldn't just start the thing with a nail anymore. Eventually the rubber hood rotted off the switch but the switch itself never failed (until very, very recently when I went to use one of the spares I had saved up...). I was very impressed with the silly little thing.
You can mount a momentary anywhere...but it's nice to be able to operate it and the starter button with either the right hand or the right hand and anything but the left hand.
Old 07-16-2013, 05:09 AM   #312
Big Bamboo
Aircooled & Sunbaked
Big Bamboo's Avatar
Oddometer: 3,839
Cool story, Bro!
Big Bamboo is offline   Reply With Quote
Old 07-17-2013, 03:22 PM   #313
Tin Woodman OP
Mike
Oddometer: 200
Good point although I don't need to call myself a cheap bastard - others will happily do that for me.
The start switch checks out OK and I'm liking the idea of keeping the protection circuitry stock although this little relay seems to be problematic judging from what I've seen on other threads. I've been following Swanker's thread and Pokie's comment about the starter relay working with the charging circuit reminded me I'm still waiting for my new diode board to show up (yes, the old board is shot).
Does anyone see any point in plugging in the old diode board and wiring it up on a temporary basis?
One measly toaster
Old 07-17-2013, 10:19 PM   #314
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 8,013
I'd wait til you had a good diode board and a working charging system in before condemning the starter relay. It may need replacement eventually but may be good now.
--Bill
'73 R60/5 Toaster
Old 07-22-2013, 10:19 PM   #315
Tin Woodman OP
Mike
Oddometer: 200
Rolled the project outside tonight, fire extinguisher in hand.
Tightened up the petcocks, put a little gas in the tank, tickled the carbs and . . .
http://www.youtube.com/watch?v=xos2MnVxe-c
Fired up like a champ - there's something almost eerie about hearing it's voice again after all these years. From boxes of inanimate parts to a living, breathing motorcycle, I'm frankly a little skeptical it really happened.
Very exhilarating.
Thanks everyone for your help - I really appreciate it.
One measly toaster
Times are GMT -7.   It's 05:03 PM.
