Old 07-12-2013, 07:22 AM   #78616
MrBob
Certified Geezer
MrBob's Avatar
Oddometer: 7,563
Originally Posted by Mambo Dave View Post
Neat, but you could have just bought a cover for it - and the covers seem like they'd really protect the housing. This is my bike:
Fabricating your own part always trumps just being able to whip out a credit card.
"When I was younger I was afraid I'd die riding now that I'm old and falling apart, I'm afraid I won't."
bwanacswan's dad
MrBob is offline   Reply With Quote
Old 07-12-2013, 07:30 AM   #78617
TrophyHunter
Oddometer: 2,214
Originally Posted by malignity View Post
Hey everyone,
I'm looking at possibly getting a 2000 DR650. Its got about 22,000 miles on it. How many more miles on average will I be able to get before I'm looking at a rebuild?
With proper suspension, will a DR650 be able to achieve freeway speed with a 240lb driver and 170lb passenger?
I want a backup/guest 'dirt bike', but also would like to kill two birds with one stone and have an adventure bike for my wife and I. The XR650L is too tall for a passenger, and the KLR is too heavy to be used as a dirt bike.
I'm hoping the DR650 will fit.
There are posts of couples going long distances on a properly set up DR and several on this forum have over 50K miles. I know of one that sold to someone here with 75K and they're still riding it.
It should work for your stated mission once it's set up. Happy hunting.
2005 DR650 '07 WR450
2013 HD Road King '73 Hodaka Wombat
"It's a small amount of gas, but it represents a long walk" My Dad...
TrophyHunter is offline   Reply With Quote
Old 07-12-2013, 08:53 AM   #78618
noreason
The coolest guy ever
Oddometer: 4
Recently purchased an 09 and I love it. But I have a question about its height/suspension.
The bike has an aftermarket Sargent low seat a few racks in the back with two soft bags with nothing in them. Nothing major as far as weight goes really. Maybe 10-15lbs max?
Anyhow, when the bike is on flat ground and the side stand, it's almost vertical and unsteady. I have to park with the wheel to the left, which I normally do, except on this bike, I literally have to. I have to park on the street facing the opposite direction (illegal?) because the slight curvature of the street won't allow it! Last but not least, if I have the stand down and sit on the bike, which I could do on my 99 dr 350, it just pushes me and the bike over to the right, pretty far, far from possible to just sit there and hang out on it.
So, I figured the previous owner lowered the bike, but everything (to me) looks stock. Links look normal, the shock adjustment is in the higher height slot and the spring compression adjuster (whatever the actual word is for that) seems to be in the stock position.
Any ideas on what else I can check?
noreason is offline   Reply With Quote
Old 07-12-2013, 08:58 AM   #78619
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,271
Crank in some more spring preload on the shock with the adjusters or get a heavier spring.
You could shorten the stand also, but if the bike is sagging that bad , you need more cowbell. (preload)
If you're not going to be offroading there's always a centerstand option.
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is offline   Reply With Quote
Old 07-12-2013, 08:58 AM   #78620
dman
Oddometer: 581
D606
Hmmm ... surprised to see criticism of the D606 recently. I now have over 2K miles on mine and they seem fine street and dirt, though I haven't ridden in rain (or mud). I finally did a "real" dual-sport ride last weekend, about 700 miles total with maybe 100 off pavement, a few of which were some pretty rocky and loose (by my noob standards) OHV trails in the Sierras, and on a few hills I needed all the traction I could get. But the 200+ miles of slab to-and-from the mountains was handled fine too. And on a few sections of twisty/bumpy paved FS roads (Frazier Creek Rd, Plumas NF - just ride it!) I didn't have much in the way of chicken strips left. BTW, this was the second longish ride I've done since installing ProCycle's lowered pegs and they definitely make a huge difference. The stock seat was really tolerable, and standing off road, though something I still don't feel totally comfortable with, was much easier.
-dman
dman is online now   Reply With Quote
Old 07-12-2013, 09:37 AM   #78621
TrophyHunter
Oddometer: 2,214
I think the 606 may be a little noisier than some want but my set worked well on the street. I was surprised at how much traction they had in corners. I'm not a canyon carver by any stretch but went too hot into a couple of corners and had to do the "steady throttle, lean - Lean - LEAN" mantra in my head and they hung on.
Hold up well in the rocky stuff, too.
Old 07-12-2013, 10:45 AM   #78622
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Originally Posted by GSF1200S View Post
Ok, so with this all past me, I have a crazy theory. Tell me what you think of this:
I started out using kerosene in a squirt bottle and bel ray chain lube. Having no experience on the road, I figured kerosene could be easily sourced. I was wrong. As I ran into only being able to buy large quantities of kerosene, I switched to wd40 since I had read in many places about guys using that to clean their chains. I would spray the chain with wd40, then wipe it off with a rag, then apply chain lube and let it dry. I would always do this when the chain was hot.
The problem is, as some have mentioned, wd40 is a penetrant. My theory is that the wd40 penetrated the orings and ruined the grease inside, and soon the chain started rusting internally (despite my cleaning and lubing). At the same time, the Keintech simple stand I use isnt the most stable, but certainly weighs less, costs less, and takes zero ground clearance when stowed compared to a center stand; this stand allows the bike to move a little when I would spin the wheel to blast the chain with wd40. Overspray prolly hit the spacer by the cush hub bearing a number of times, consequently pentrating the seal (or around the bearing perhaps?) and destroying the grease in the bearing. As the bearing wore, it started to place all sorts of additional force on the wheel bearings and caused the one nearest to the rotor to start going bad. **EDIT** I really am not sure the cush bearing could put additional force on the wheel bearings, but id like your opinions.
I always check the wheel for movement when I deal with the chain, but I will confess I didnt always check the sprocket for lateral movement. This happened fast because I know in fairbanks there was no wheel slop at all.
Maybe im reaching here, but the cush hub bearing definitely had a rusty runny watery crap coming out of it, and this theory seems plausible.
Anyone else want to part some wisdom on me? I feel really stupid (and I was for sure) but at least I know better now. Im using diesel in a squirt bottle to clean the chain and silicone lubricant to keep the orings conditioned. I clean when warm, and I wipe the chain off before extended dirt sessions. Sound right?
Moral of the story: dont blast wd40 on chains or by accident, bearings. I guess some might spray wd40 on a rag, but for me diesel is so cheap, abundant, convenient and good at cleaning that Im just going to use it from now on.
There have been tests run on NEW X ring chain ... soaked in WD40 for a week. WD did not get past X rings. ... BUT ... on a worn chain? Maybe you have a point? Go light on the WD40!
I don't flood my chain with WD (expensive!) and I try to wipe most of it off after cleaning. If you leave a lot on there ... then some chain lubes won't stay on the chain if it's wet with WD40. This is true for the Dupont Teflon product. So, clean off the WD best you can.
Diesel is great. My only complaint? It stinks and my rags end up stinking, but it's cheap and plentiful, does a good job. I say, go with it.
I don't believe WD over spray ruined your Hubb or wheel bearings. More likely water exposure and hard use. Rain riding, stream crossings and
off road riding will take a lot of life out of both your chain and your bearings.
I've no idea on the "order of failure" or how one would affect the other.
Don't forget to check your LINK bearings, especially the most exposed ones that are low down. Re-Grease when you can. (I do it about once a year if I've ridden in the wet)
Your DR will be in top shape by the time you make it home! Excellent maintenance reports ... and proves my point that starting off a long ride with lots of new parts and a complete fresh service, saves time/money on the road.
I learned this in the 80's doing Baja rides:
The standard rule for our 1500 mile Baja Ride (about 70% off road) was:
1. New Tires/Tubes (with 3 spare tubes on board)
2. New Chain/Sprockets (spare master link, spare CS sprocket)
3. New Battery
4. Complete service, checking/lubing all bearings
5. Loc Tite everything, check all fasteners
6. Complete Tool kit, spares, nut/bolt kit
7. First Aid kit
Old 07-12-2013, 10:53 AM   #78623
Adv Grifter
Oddometer: 6,128
Originally Posted by NWBoon View Post
Wow, City Bike is a magazine name I hadn't heard in years! I went to college at Sacramento State from 1990 to 1995 and really enjoyed reading that publication. My only form of transportation from 90 - 94 was a 1988 Kawasaki EX500. I put 33,000 or so miles on that little bike and had a blast with it (first motorcycle). Thanks Adv Grifter for lots of great reading back in my wild days.
Thanks Boon, glad City Bike is remembered so fondly! We all miss Joe Glydon, John De India and Herb Chain. What's funny is we constantly got high praise from the "Glossy" mag editors ... who LOVED City Bike ... they wished they could do ... and say ... what we could.
Cheers!
Old 07-12-2013, 11:20 AM   #78624
jeknow
Oddometer: 23
I like Dirt Bike magazine ok I sub to it. They didn't publish the whole letter I wrote were I said guys that just ride bikes in dirt circles shouldn't write about adventure bikes. But it's all good I like riding dirt bikes too. And I stand by all bike riders. Make that responsible riders. DR riders are different anyway you have to be to ride a 350lb. Dirt bike.
Sent from my XT907 using Tapatalk 2
jeknow is offline   Reply With Quote
Old 07-12-2013, 11:29 AM   #78625
DockingPilot
Hooked Up and Hard Over
DockingPilot's Avatar
Oddometer: 9,610
3. New Battery
7. First Aid kit
I have similar requirements when we go. Before our "Forever West trip, I asked my friend "how old is your 950 battery" ?
"4 years".
I told him to change it out before we leave,
why ? he asked.
"Because I aint pushing or towing your bike across the big empty on a 25 degree morning"
He said: "why not, I'd push yours".
wise ass.
He dropped a new one in.
Frank Reinbold
"Every bike I ever had, was the best bike I ever had, when I had it"
DockingPilot is offline   Reply With Quote
Old 07-12-2013, 03:06 PM   #78626
shu
Oddometer: 1,011
More chain care, if you care.
I carry a small (4 oz plastic bottle) of 75/90 gear oil, a very small can of WD 40 and a 1 inch cheap paint brush. These don't take up much space, less than the size of a can of chain spray and I can make these supplies last for a month on the road, if I'm careful.
To clean the chain- spray the wd 40 on the brush and rotate the wheel (I have a centerstand). One spray on the brush for each side of the chain. Then wipe off the WD 40 with a paper towel.
To oil the chain, use the same brush, only put some gear oil on it. Same routine, hold the brush against the chain and spin the wheel. Again, wipe off excess oil with the same paper towel.
When I'm traveling I do this everyday, usually in the morning but almost never when I should do it: at the end of the day when the chain is hot.
When the day's riding is done, it's beer time and I forget all about the chain.
Priorities.
...........shu
shu is offline   Reply With Quote
Old 07-12-2013, 03:17 PM   #78627
shu
Oddometer: 1,011
"4 years".
why ? he asked.
I replace my battery every 3 years now, even if it seems fine.
It works out to about $30 /year for the feeling of confidence you get when, after parking to take a piss 40 miles back in the woods, you return to the bike and put your thumb on the starter button. It's worth it : no more 'come on baby, start for me prayers', no special starter tricks, just push the button and go.
..........shu
Old 07-12-2013, 03:46 PM   #78628
DockingPilot
Oddometer: 9,610
..........shu
My thoughts exactly.
Frank Reinbold
Old 07-12-2013, 04:16 PM   #78629
Foot dragger
singletracker
Foot dragger's Avatar
Oddometer: 12,856
Ive burned through 3 or 4 rear 606's,they work pretty well in dirt and slide predictably for me,not too vibey on the street. I think they're about worn out,they get down to about 1/3 of a tire and then they seem to hang that way for a long time,that's when I get the mileage out of them. Maybe 2000 if I really run em down to nubs.
Never had any sliding on the street with em.
Some bikes around at times
Foot dragger is offline   Reply With Quote
Old 07-12-2013, 04:53 PM   #78630
Adv Grifter
Oddometer: 6,128
I like responsible dirt bike riders too (I am one! ) A lot of us started off riding Moto Cross or Cow Trailing ... 40 years later ... here we are!
I started riding AMA Enduro at 39, competed 7 years. It's discouraging to see guys abuse the land and ignore the rules ... I don't like a lot of the rules either ... but try to follow best I can. We're losing the battle and most riders I see could care less.
I still have a trail bike (Yam WR250F) but for overall travel fun, prefer my DR650. (yes, I have trouble picking it up when it's loaded with gear!)
Times are GMT -7.   It's 10:10 PM.
