Old 07-12-2013, 07:51 AM   #1
txtallywhacker OP
screw schedules
txtallywhacker's Avatar
Oddometer: 108
high fender
im puttin a high fender on, and i wanna convert to a single front disc. anyone done it or see any problems with it? f650 gs is same frame so it would work, but it has conventional forks....
Originally Posted by drrags View Post
So I sashay on down to the local sanatorium with a cup full of poop.
txtallywhacker is offline   Reply With Quote
Old 07-12-2013, 11:35 AM   #2
Grits&Gravy
Grits&Gravy's Avatar
Oddometer: 347
Some people just go to one rotor without changing anything, but it is my understanding that you should also switch to the F650GS master cylinder, which is designed for a single rotor. Something to do with the hydraulics and pressure applied to have the brakes function and respond properly.
Grits&Gravy is offline   Reply With Quote
Old 07-12-2013, 11:51 AM   #3
txtallywhacker OP
screw schedules
Oddometer: 108
sweet
thanks man, getting a single brake line made tomorrow, and im lookin for a 650 master cylinder as we speak.
Old 07-12-2013, 12:17 PM   #4
LukasM
Oddometer: 5,418
The stock MC will still work, it will just displace too much fluid for a single caliper. Practically you are getting shorter lever travel at the expense of more pressure required, giving a more wooden feel.
Old 07-12-2013, 09:13 PM   #5
txtallywhacker OP
screw schedules
Oddometer: 108
dang I dunno what to do, just get two brake lines made or go to one disc...what would yall do?
Old 07-13-2013, 02:08 AM   #6
Bill the Bong
Supern00ba
Bill the Bong's Avatar
Oddometer: 961
I would run 2 lines from a junction to get rid of that weird set-up that BMW thought up. In fact, I think I will do that in the near future. Now proceed with your conversion
KTM 690 R - "Its just a little crush..."
Bill the Bong is offline   Reply With Quote
Times are GMT -7.   It's 02:18 PM.
