Old 07-13-2013, 02:15 PM   #7516
RandoCommando
Wannabe
RandoCommando's Avatar
Oddometer: 1,394
Originally Posted by Tsotsie View Post
I have, but not as bad as the 08's did. The reason for the 08 piston and ring design change was oil usage at the higher rpm and ring lands breaking. And when a land broke, there WAS oil usage!
Was this on certain year Gen I models?
I've never burned as much as a drop on my 99, regardless of how I rode.
1999 KLR 650 (her name is KLaRissa) DOOHICKEY DONE!
2013 BMW F800GS (her name is FranGelicaS)
Please. Ride careful, ride safe, ride defensively! This thread should be mandatory reading!
MySPOT
RandoCommando is offline   Reply With Quote
Old 07-13-2013, 02:17 PM   #7517
RandoCommando
Wannabe
Oddometer: 1,394
Originally Posted by XpressCS View Post
Have a stroll on over to some of the other KLR forums. A lot have reported oil burners, mine burns a little bit of oil.
That.
Hmm... I see you have an 04. I wonder if this issue started during certain model years.
Hopefully your issue won't get worse.
MySPOT
Old 07-13-2013, 03:29 PM   #7518
Tsotsie
Semi-reformed Tsotsi
Oddometer: 1,733
It is my understanding that it applied to Gen 1 pistons as they were breaking lands. Whether it applied only to certain years of castings, I do not know. It was enough of an issue for them to change the design. As soon as the Gen 2 pistons were available they changed the P# and the Gen 1 pistons were no longer available. Then in early 09 they changed them or the rings again. I have not had need to nor seen or compared those to the previous generations as by then had gone to the forged 685..
Tsotsie is offline   Reply With Quote
Old 07-13-2013, 03:45 PM   #7519
bdcorrigan
bdcorrigan's Avatar
Oddometer: 647
'06 non oil burner with 6k miles! I hear it is a roll of the dice when you get above '01.
bdcorrigan is offline   Reply With Quote
Old 07-13-2013, 05:26 PM   #7520
DesertDuster
Old Pueblo Rider
DesertDuster's Avatar
Oddometer: 191
Originally Posted by deejmeister View Post
Any of you guys have any valve shims to sell or swap? I need 2x235 and 2x255s. I ordered from Mike but he's still moving his shop so it's bomb to be a while. Pm me thanks!
Rocky Mountain ATV can get them to you in a couple of days.
http://www.rockymountainatvmc.com/
dd
DesertDuster is offline   Reply With Quote
Old 07-13-2013, 05:31 PM   #7521
8lives
Dharma Bum
8lives's Avatar
Oddometer: 1,944
2001,23800miles and only burns about 200cc between 2000 mile oil changes
What would you do if you weren't afraid?
Perimeters suck!
I used to do drugs,I still do drugs,but I used to too!Mitch Hedburg
8lives is offline   Reply With Quote
Old 07-13-2013, 06:28 PM   #7522
beemerjim
beemerjim's Avatar
Oddometer: 428
If you have a bmw dealer near you, the shims from a K75 are the same--and they are cheaper, believe it or not.
jim
The older I get, the faster I was.
It's all about attitude & timing.
I'm not sure where we're going, but this road seems to be paved with good intentions.
beemerjim is offline   Reply With Quote
Old 07-13-2013, 06:31 PM   #7523
RandoCommando
Wannabe
Oddometer: 1,394
Thanks Tsotsie. I appreciate it.
MySPOT
Old 07-13-2013, 07:25 PM   #7524
the_sandman_454
Oddometer: 421
I wouldn't be so sure it'll take too long. I just ordered some filters, gaskets and stuff from him on the 9th or 10th and when I came home Friday it was in my mailbox (and I'm in MI).
Tim
09 KLR650
the_sandman_454 is offline   Reply With Quote
Old 07-14-2013, 12:48 AM   #7525
One Fat Roach
One Fat Roach's Avatar
Oddometer: 1,529
Im pretty lucky I didn't damage my engine from over filling the oil. I drained it out, refilled and put the 2.5qts back in. Cleaned the airbox and air filter very well and cleaned the swingarm, rear brake rotor and tire as much as I could. I took it for a ride today and it was its old self. Dodged a bullet and learned my lesson
Originally Posted by Mr. Fisherman View Post
This is an adventure, not a field trip!!
One Fat Roach is offline   Reply With Quote
Old 07-14-2013, 01:05 AM   #7526
sandalscout
blah blah blah
sandalscout's Avatar
Oddometer: 2,143
Glad everything turned out well! Keep an eye on the airbox, you might recoat everything behind it as it seeps out the last of the oil.
My KLR650
Matt's Trippin' in Peru
sandalscout is online now   Reply With Quote
Old 07-14-2013, 02:19 AM   #7527
Stephen_m64
n00b AdvRider
Oddometer: 52
ordered my doohickey kit from him and got it pretty much the next day, i'm in Sacramento and hes in the LA area that does not mean much but looks like he is shipping items asap.
'95 DR650, '00 DRZ400S
Stephen_m64 is online now   Reply With Quote
Old 07-15-2013, 06:48 AM   #7528
stuser
Putt putt putt
Oddometer: 379
new piston
Due to the well documented burning of millions of litres of oil on the 08 model, I have today finished dismantling my top end.
The cams look great, as does most everything else, except:
one of the valve lifters didn't want to come out.
The piston has a nice big lump of carbon / burnt oil on it, and the underneath of the head / combustion area is BLACK. SO much burnt oil.
The spark plug was almost indistinguishable from the head, so much grey ashy crap built up on it.
The bike only has 27,000 KMs on it.
I'm ordering a Schnitz 685 piston kit and getting the cylinder bored to match obviously.
What else should I consider replacing while I have it apart?
I'm thinking of getting the head cleaned professionally while I get the cylinder done. Thinking maybe I'll replace all the valves / seals etc. Thoughts anyone?
Anything else?
It's amazing it still runs, check out the spark plug!
I'm liking the lower centre of gravity...
stuser screwed with this post 07-15-2013 at 07:11 AM
stuser is offline   Reply With Quote
Old 07-15-2013, 08:47 AM   #7529
Keating
pre-n00b
Oddometer: 187
Roughly 16000 miles on my new-to-me '04.
Came with a fresh oil change (top of sight glass with bike level) when I picked it up from the dealer, and there is no perceptible change in level now, after 1000 miles with several 1+ hour, 5500-6000RPM slab flaggings.
The wife is still a little freaked by the whole thing but what ya gonna do? Stay at home and die in your sleep? - laramie LC4
'04 KLR650
Keating is offline   Reply With Quote
Old 07-15-2013, 09:27 AM   #7530
XpressCS
Must. Have. Lumens..
XpressCS's Avatar
Oddometer: 1,195
Originally Posted by XDragRacer View Post
Then again, I wouldn't be surprised at ANYTHING found on, "other KLR forums."
I'd trust anything found on those "other" KLR forums before I trust anything here on this forum, any day, every day Just my general observation, but there's not many members here actively trying to improve the KLR as a whole.
And if you did read, there's plenty of Gen1 bikes that burn oil. It's the nature of older engines, especially those who roll 4000rpm+ daily, they tend to drink a little bit of their own blood as they get older.
My 04 burns only a little bit of oil between oil changes, as in from the top of the sight glass to about 1/8" below the sight glass.
As is with everything, your oil consumption may vary. Some engines burn it, some don't, plain and simple. Just because MY engine burns it doesn't mean YOUR engine will.
2004 KLR650
My KLR is my therapy session. My quiet time. My deep tissue massage. Me without my KLR is reason enough to be deeply concerned. It is what calms me the most. Soothes my mind. Eases my stress. -Me
XpressCS is offline   Reply With Quote
Times are GMT -7.   It's 07:41 PM.
