Old 05-16-2009, 05:41 PM   #31
Dave92029 OP
Oddometer: 554
Wicked Here is my thinking
Originally Posted by DolphinJohn
Well, I just put Castrol Syntec (full synth) in my bike the other day,
but I haven't ridden it yet.
I suppose I could drain it and use a blend or non-synth
if it really is a big no-no, but I honestly think my bike
is broken in at 3,000 miles... Snipe.
I believe that the Castrol Act-EVO that is recommended by BMW is because most Synth oils are too slippery for the CLUTCH, the engine is fine with full Synth.
I figured that since there have been a few isolated Clutch failures, that It might be a good idea to have BMW recommended oil in the oil pan, just in case my clutch decides to blow up, and BMW tests the oil while doing their Warranty Inspection. It just seemed penny wise rather than dollar foolish,
Just my 2 cents ...
Dave
Escondido, CA
IBA #43
2013 Vespa 300ie S GTS
2014 G650GS
Dave92029 is offline   Reply With Quote
Old 05-20-2010, 08:28 AM   #32
Tor
Native Viking
Tor's Avatar
Oddometer: 803
Originally Posted by ride2little
THEN...you should be beaten with a wet noodle. The SHAME in it all.
Honestly. This subject is way overblown. Run what makes you comfy. the bikes will break in just fine. Ever run into a bike that has not been broken in properly? Or one that is "taking too long to break in"?
Knock wood...in all of the motors I have owned in my life, not one has given me any oil/lube related trouble. Just be diligent with the PM's. Even my lawn mower...a HOnda I bought in 1988 is still going strong. Used straight 30W for the longest time. Now i just use whatever synthetic I have sitting around (usually M-1).
Which is why I'll dump 3 jugs of M1 10W40 4T Synth. on the hole when my 800GS hits 600 miles.
I started using M1 Synth. in my ST1300 at 100 miles. Now at 60000..miles, and the engine is running very nicely, with no oil use....
"Be Always Sure You Are Right - Then Go Ahead"
2005 Honda ST1300 / 2010 BMW F800 Gelände-Straße
Tor is offline   Reply With Quote
Old 07-12-2013, 12:09 PM   #33
Pete7874
Pete7874's Avatar
Oddometer: 408
Originally Posted by darmahman View Post
No BMW uses dino- They need to be broken in with dino, then they can be switched to synthetic @ 6,000 - 10,000. Not enough friction? with synthetic to allow for good break in results.
This may have been the case in the past, maybe around the time when this comment was made. However, I looked in the 2013 owner's manual, and the comment about not using synthetic for the first 6,000 miles is no longer there.
As was said earlier, many automotive engines now come with synthetic straight from the factory. I wonder if these new BMW bike engines do, too? I tried asking BMW Motorrad USA this question, but they had no idea. I wonder if there is a contact at BMW Germany that could answer this...
Pete7874 is offline   Reply With Quote
Old 07-12-2013, 05:20 PM   #34
moe.ron
I got nuthin'...
moe.ron's Avatar
Oddometer: 2,575
Check the age of the oil threads you are replying to, old news...
Pig Can Fly.
moe.ron is offline   Reply With Quote
Old 07-12-2013, 08:10 PM   #35
Pete7874
Pete7874's Avatar
Oddometer: 408
I realize that, but when I did a search for synthetic oil, only these old threads came up.
Old 07-12-2013, 08:24 PM   #36
moe.ron
I got nuthin'...
moe.ron's Avatar
Oddometer: 2,575
BMW put out a bulletin on the oil that is around here somewhere, I may still have a copy.
Pig Can Fly.
Old 07-13-2013, 08:04 PM   #37
JRWooden
Oddometer: 4,230
This came out in March of 2012:
http://www.bmw-motorrad.dk/se/sv/services/media/PI_OlL_BMW_MC_2012_MD.pdf
Times are GMT -7.   It's 12:16 AM.
