Old 07-01-2013, 01:22 PM   #1
Makwa OP
Makwa's Avatar
Oddometer: 75
No brakes after a long sit?
The EXC 450 I just picked up doesn't have any brakes. I argue that bikes like this do not necessarily NEED brakes, but alas, I have been outvoted and need to fix them.
The bike has sat unused for 2 years. They worked when it was parked.
I am going to try to bleed them now that I have the DOT 5.1 fluid. (Glad in my older age I have learned to read instructions... ie, manuals)
Is this a common issue?
Anything I should be on the lookout for or should do?
'05 450 EXC - Current
'01 RM 125 - Retired
'89 CR 125 - Retired
Makwa is offline   Reply With Quote
Old 07-01-2013, 01:30 PM   #2
Navin
Navin's Avatar
Oddometer: 7,814
Air in the line all gathers at the uppermost point in the loop on the KTM EXCs, try back bleeding the caliper with the cover off the master to start.
(knee against caliper, slowly press till it bottoms out the pistons)
Navin is offline   Reply With Quote
Old 07-01-2013, 02:00 PM   #3
Grreatdog
Grreatdog's Avatar
Oddometer: 11,053
It is a very common issue. My MXC tends to sit for long periods between rides so I used to have to bleed the brakes before every ride. After researching it a bit I learned using a small bungee cord to hold a bit of pressure on the lever prevents it. No problems since I started doing that. Well, except I forget about the cord sometimes and can't figure out why I can't push it out of the garage.
525EXC, 640 Enduro, XT200
Grreatdog is offline   Reply With Quote
Old 07-01-2013, 05:27 PM   #4
crazybrit
crazybrit's Avatar
Oddometer: 8,554
Originally Posted by Grreatdog View Post
It is a very common issue ... After researching it a bit I learned using a small bungee cord to hold a bit of pressure on the lever prevents it.
+1.
If it's chronic, ziptie lever to bars (i.e lever fully applied). Overnight usually fixes it.
crazybrit is offline   Reply With Quote
Old 07-01-2013, 09:17 PM   #5
Young-Gun
KTM Tragic
Young-Gun's Avatar
Oddometer: 958
Originally Posted by crazybrit View Post
+1.
So it will actually fix it or is this process only useful for prevention?
Ryan
KTM 950/990 Oil Drain Hoses For Sale
KTM 950 'S' - Loving it!
KTM 625SXC - Adventure bike (project)
Young-Gun is offline   Reply With Quote
Old 07-01-2013, 10:27 PM   #6
Fire Escape
Fire Escape's Avatar
Oddometer: 1,572
Worked For Me!
I guess that depends on your definition of 'fix'. My GG went from no brakes to good brakes overnight with the bugee trick. If the problem returns over time (weeks or months not days) was it 'fixed'? It certainly makes the brakes work though, something I have not always been able to do by bleeding.
Bruce
No one calls the Fire Department because they did something smart!
06 DR 650, Moose RS Holder, Handguards and Skidplate, ProTaper bars, Garmin 60CSx, Motech racks w/ 20mm Ammo cans, Renazco 08 Scrambler, Conti Trail Attacks and BlackTiger Fork mod, 05 FSE 450, 03 KLR 250, 02 FXDX, 72 WR 250 (again), 72 SL 350 K2 (again), 72 TR6R, 06 XT 225
Fire Escape is offline   Reply With Quote
Old 07-01-2013, 10:54 PM   #7
Young-Gun
KTM Tragic
Young-Gun's Avatar
Oddometer: 958
Bruce
Excellent! So tonight... I go home, squeeze the lever as far as I can against the grip, secure in place for a day or two and I should be good to go? Worth a try! Will report back
Ryan
Old 07-02-2013, 06:27 AM   #8
Grreatdog
Grreatdog's Avatar
Oddometer: 11,053
If not, the back bleeding per the first post should do the trick. Take the cover off the master cylinder, turn the bars to get it up to the highest point you can and as level as you can, press the piston back into the caliper and then pump the brake back up at the lever keeping an eye on the fluid level. Then do the bungee trick.
Old 07-02-2013, 07:48 AM   #9
crazybrit
crazybrit's Avatar
Oddometer: 8,554
I thought there was a plan-b if the bungee didn't work before trying bleeding (plan-c). Removing the master cyl off the bike and hanging the whole assembly from garage rafter. Then retry the bungee. Something about the way the hose routes when on the bike causes air to get trapped. I forget the details (it's on ktmtalk) as I've never needed to do it, the zip-tie around the lever/grip has always worked 100% for me on the bike.
Old 07-02-2013, 09:22 AM   #10
Navin
Navin's Avatar
Oddometer: 7,814
Brembo mastered bikes should be parked with the bars to full left steering lock too.
Old 07-02-2013, 10:23 AM   #11
Makwa OP
Makwa's Avatar
Oddometer: 75
This.... worked like a champ
I will definately do this. Hopefully it will not sit long anymore but one can never tell.
Thanks for the suggestions fellas!
Old 07-02-2013, 10:28 AM   #12
Navin
Navin's Avatar
Oddometer: 7,814
Bravo. I usually start the day with a good back bleed or two on both front and rear calipers on my Brembo braked bikes. Good to do right before starting them up.
Old 07-14-2013, 06:45 AM   #13
Young-Gun
KTM Tragic
Young-Gun's Avatar
Oddometer: 958
It worked!!!!
Ryan
Times are GMT -7.   It's 10:51 AM.
