Old 07-13-2013, 05:34 PM   #1
BMacW650 OP
BMacW650's Avatar
Oddometer: 751
990/950 Twin Hella (90mm) Lighting Project
This is a personal project of mine. However I have to pay for a batch water jet order. When I'm finished I will post some details and sell a couple sets to share the cost and recover some of the R&D cost.
UPDATES:
Lighting comparison:
http://www.advrider.com/forums/showp...0&postcount=31
Action shots:
http://www.advrider.com/forums/showp...3&postcount=70
http://www.advrider.com/forums/showp...0&postcount=88
Harness info , etc.
http://www.advrider.com/forums/showp...&postcount=103
http://www.advrider.com/forums/showp...&postcount=123
Kit Details:
http://www.advrider.com/forums/showp...&postcount=127
Lens protectors:
http://www.advrider.com/forums/showp...&postcount=141
http://www.advrider.com/forums/showp...&postcount=144
http://www.advrider.com/forums/showp...&postcount=146
LED running light:
http://www.advrider.com/forums/showp...&postcount=148
Final Version:
http://advrider.com/forums/showpost....&postcount=165
http://advrider.com/forums/showpost....&postcount=166
http://advrider.com/forums/showpost....&postcount=168
The finished project will have the following:
Twin Hella lamps (90mm Reflector Style High, 90mm Projector Style Low)
High beam will have Halogen Bulb.
Low beam will have HID
It will come with complete custom made wiring harness. (Just plug and play)
Kill switch to turn low beam completely off (for US models)
Individual relay for each lamp.
When High beam is ON, low beam will remain on (since the lamps are running from separate circuit connected the battery directly, there will be no load issue)
Custom bracket to mount the Hella lamps.
The bracket will be attached in similar way as the stock light housing.
You will be able to use the stock windscreen or any other after market windscreen made for the bike.
Working on a solution to have LED angel light as running light. (low priority)
The idea is not new. But I want to make exactly what I wanted. I've used Hella lights with HID conversion on my other bikes. So that's a priority for me to improve the overall lighting quality. And I believe I've managed to keep the cost WAY down compare to other comercial options.
I'm looking for about 10 people to get on board. The kit will not be exactly cheap, but that's because I'm using quality parts. Don't need any commitment, but I'd like to get an idea of how many people would be interested.
Just a few pictures of the project.
BMacW650 screwed with this post 04-29-2014 at 04:03 AM
BMacW650 is offline   Reply With Quote
Old 07-13-2013, 05:49 PM   #2
BMacW650 OP
BMacW650's Avatar
Oddometer: 751
Cost
Everything together will probably cost a bit over $300. This includes the HID kit + 2 Hella Lamps. ($135, price+shipping, I'm not a vendor, I have to pay for everything retail )
You can of course source your own Hella lights, HID conversion kit and/or make your own wiring harness. I can supply the light bracket and the face plate.
You can source your own harness here or make you own.
HL28109 - H4 to H9 High and H9 Low +$104.04
Hella 90mm High
Hella 90mm Low
Old 07-13-2013, 06:21 PM   #3
RoundOz
Plenty of seasoning
Oddometer: 1,014
Hmm
I read your plans with some interest. At this point my only upgrade would be to the super expensive TT setup. Unfortunately it is the shape of their fairing that mostly drives me (I like it better than any other fairing or screen on the market), as I have yet to read any good reviews of the lights' performance or seen photos of their pattern. Am I right in thinking your lights are the same Hellas?
2009 KTM Adventure
RoundOz is online now   Reply With Quote
Old 07-13-2013, 06:30 PM   #4
Pete640
I hate sand.......
Pete640's Avatar
Oddometer: 1,793
I'm interested.
Keep us updated!
Pete
Turtleshell5@icloud.com
For those who sit at home and dream-let them...Meoni
Pete640 is offline   Reply With Quote
Old 07-13-2013, 06:41 PM   #5
BMacW650 OP
BMacW650's Avatar
Oddometer: 751
Funny you said that. I've dumped close to a used set of those TT lights into developing mine. I actually really hate their looks.
On the lamps. They are exactly the same. Hella's Bi-Xeon lights are actually different than the Bi-Halogen lights. But for single beam light (these 90s are single beam), you are just paying for the Hella ballast. What I have is exactly the same lamp touratech sells. You can just put in your own HID bulb.
I know quite a bit about Hella lights. Actually the 90mm is an older design than the 60mm. But there isn't much room to fit those huge 60mm projectors.
For your research/project, you can use the following as reference.
http://www.fiero.nl/forum/Forum4/HTML/054226.html
ALSO, check out Lynx fairing, they use the same 90mm Hella and have HID kit you can buy. Both will give you a good idea of the quality of light.
Old 07-13-2013, 06:51 PM   #6
DesertSurfer
Tail sprayin
DesertSurfer's Avatar
Oddometer: 1,473
As PM'd previously... I'm definitely in!!! And I'll refer anyone else that I hear might want an upgrade like this. I'll be prepping my bike for the KTM Rally in Colorado, so I can point people who are going or show them the set up when I get there and at the CJD pre-rally with his permission too if ( if your quota isn't met).
Rock On!!!
'"This whole memory lapse is gett'in to me. Hopefully I think I'll outgrow it."
DesertSurfer is offline   Reply With Quote
Old 07-13-2013, 07:13 PM   #7
DutchVDub
Oddometer: 1,317
Could you just make it using standard H7 projector housings? I personally see no need for the HID's but the dual light setup would be nice and a set of H7 projectors should still be brighter and have a better pattern than the factory light.
2008 Honda Shadow 750 Spirit
2013 Victory Cross Country
DutchVDub is offline   Reply With Quote
Old 07-13-2013, 07:16 PM   #8
BMacW650 OP
BMacW650's Avatar
Oddometer: 751
Hella only sells H4 60mm and H9 90mm single beam projectors suitable for this application. I would've preferred the 60mm, but there is no room for both the high and low in 60mm (not enough depth), and I prefer the look of two 90mm.
I wouldn't go with another projector except hella, it's all about the optics (the type of bulbs h7/h4/h9 is not that relavant).
BMacW650 screwed with this post 07-13-2013 at 07:21 PM
Old 07-14-2013, 06:02 AM   #9
DutchVDub
Oddometer: 1,317
H9 would be fine as well, relatively inexpensive and easily found in any auto parts store. Keep me posted on this as you go. I'm very intrigued.
Old 07-14-2013, 07:46 AM   #10
zgfiredude
Oddometer: 865
I'm interested, and sub'd to this thread.....Nice work!
DRZ440E, KLX440R, DRZ250, KTM 950S Adv, F650GS, & F650GS Dakar
zgfiredude is offline   Reply With Quote
Old 07-14-2013, 09:05 AM   #11
SierraJeep
It's toast
SierraJeep's Avatar
Oddometer: 630
I may be interested in this. I have already changed mine to the Euro headlight shell and installed an HID light in the low beam, which has helped considerably over the stock US version. Additionally, I put the Euro headlight switch on mine (so I could shut off everything). Would this system still work with the Euro headlight switch, or would that mess up the 'plug and play' idea?
I ask only because my wiring skills are less than crappy.
Tod
2010 KTM 990 Adventure
2010 KTM 450 EXC
SierraJeep is offline   Reply With Quote
Old 07-14-2013, 11:25 AM   #12
BMacW650 OP
BMacW650's Avatar
Oddometer: 751
The only interface to the stock lighting wiring is the H4-3 plug (high, low, ground). The Euro switch controls the output directly there. So you will not need a separate kill switch for the low beam. If you look at the picture of the harness, only the yellow boxed terminals need to be connected to the bike.
The rest of the system operates the same way. Because my US model does not have a switch to completely shut off the low beam, I installed a switch inline from the low beam trigger to the relay that eventually goes to my HID low beam projector.
On top of that, I've made the harness such that the low beam will remain on when the high beam is switched on.
Old 07-15-2013, 06:55 AM   #13
BMacW650 OP
BMacW650's Avatar
Oddometer: 751
The wiring harness is finalized. I added a long 12 gauge ground wire so it will also reach the battery.
Since I'm making the harness from scratch. I will provide a shorter version of the harness if you already have some sort of fuse box installed up top.
Old 07-15-2013, 12:05 PM   #14
1Bonehead
Fearless of Falling
1Bonehead's Avatar
Oddometer: 1,113
Nice looking set-up
1Bonehead is offline   Reply With Quote
Old 07-15-2013, 03:21 PM   #15
DutchVDub
Oddometer: 1,317
I understand they're brighter, I just don't feel a need for it. I never found the only sealed beam lights on my 80's cars (and current Cherokee) to be to dim to see with at night. The super bright headlights actually f* with my night vision as creates too much of a contrast for me. Almost makes the darkness darker if that makes sense. I actually got rid of the HID's on my S4 and went to H7 projector e-codes for that reason. Plenty bright and a more diffuse/broad pattern to see with.
Times are GMT -7.   It's 02:40 AM.
