Old 07-04-2013, 05:38 PM   #1
tomasv OP
Check the Czech!
tomasv's Avatar
Oddometer: 308
Garmin Montana 650t rotating screen while riding
Hi guys,
I got a refurbished unit that was advertized as new. It came with a foil on the screen that I left there and went on my first trip - http://connect.garmin.com/profile/TomasVetr
However for most of the time, the screen was rotating 90 degrees or upside down the whole 4 days - almost impossible to use without stopping. While stationary it works just fine.
Anyone experienced something similar? Could it be there is dust under the foil I left on the screen or is there some settings that could help? I got no response for help form the seller - only auto reply that the unit was in like new condition and all claims should be made with Garmin directly.
I am using the powered holder together with a RAM mount.
Thx
Tomas
tomasv is offline   Reply With Quote
Old 07-04-2013, 08:23 PM   #2
RonKZ650
RonKZ650's Avatar
Oddometer: 252
Easy to go to setup, then go to the settings to lock the screen in landscape.
RonKZ650 is offline   Reply With Quote
Old 07-11-2013, 05:13 PM   #3
sintax
Oddometer: 495
I felt like an idiot with the same problem. I went through the screens and could not find a "lock screen" Turns out its there and I just could not read.
Works great now that i locked it.
sintax is offline   Reply With Quote
Old 07-15-2013, 01:08 PM   #4
tomasv OP
Check the Czech!
tomasv's Avatar
Oddometer: 308
Ron, thank you for the pointer - works great now!
But I still wonder - what is causing that? Is it dust on the screen, bike vibrations or something else? Anyone knows?
Old 07-15-2013, 04:44 PM   #5
maverik
Old Fart
maverik's Avatar
Oddometer: 39
The factory setting is auto orentation, which means as the GPS moves it tries to oreint the screen so the map is right side up for you, I had to lock the screen on my 600 too...
maverik is offline   Reply With Quote
Old 07-15-2013, 08:40 PM   #6
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,593
It's a sensor in the gps which interprets the bike leaning or accelerating as reason enough to switch orientation unless you lock it.
HTML code is Off
Times are GMT -7.   It's 05:06 AM.
