Old 07-20-2013, 01:56 AM   #916
ontic
Oddometer: 1,070
Originally Posted by SOLO LOBO View Post
The tech told me the stiction is common to these forks and suggested replacing the seals with one from from HKC, which are apparently very low drag seals. He also thought the springs may be too soft as well.
HKC? Google let me down.
I ended up getting a few sets of the OEM blue seals a while ago, but haven't swapped them in yet. Don't tell me they are sticky junk...
I do still get a little more stiction than I was hoping for.
One day when I feel rich I will buy a fork rebuild kit with all the bushes.
Hope you are having a good time!
1974 R90/6
1981 R80G/S
1994 XLR250R
ontic is offline   Reply With Quote
Old 07-20-2013, 07:28 AM   #917
Solo Lobo OP
airhead or nothing
Solo Lobo's Avatar
Oddometer: 9,055
Sorry, SFK.
Jenna and others don't have the stiction issues, so I am hoping it is easily solvable!
"punk rocks what it's all about" - J. Strummer
R65LazaruS
So I sold my GS and went shopping for a G/S!
Solo Lobo is offline   Reply With Quote
Old 07-20-2013, 07:52 AM   #918
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,577
Originally Posted by solo lobo View Post
sorry, sfk.
Actually SKF
I just ordered some last night along with a set of bushings and fork oil to rebuild my forks on my next trip up to Seattle. Hopefully that'll give me a good non-stictiony baseline I can start tuning from.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 07-20-2013, 09:02 AM   #919
Dmaster
Dmaster's Avatar
Oddometer: 257
Originally Posted by Airhead Wrangler View Post
Actually SKF
As far as i know there are no SKF seals for the WP50 Extreme forks,... which sizes did you order?
Dmaster is offline   Reply With Quote
Old 07-20-2013, 09:21 AM   #920
Airhead Wrangler
Adios Mexico
Oddometer: 6,577
Sorry, I wasn't clear there. I have WP 4860 USDs.
Old 07-20-2013, 09:27 AM   #921
Prutser
Prutser's Avatar
Oddometer: 1,030
Thats what I said in the other thread Solo Lobo posted in first.
@ Dmaster : Airhead Wrangler has the same 48mm forks I have. So the SKF are no problem for that one.
@ AW Don't order the HD kit !!! They are to tight !!!
BMW R100'91/R80'93/R75/6 R80ST'83/R65GS'87/GasGasTXT300/DouglasW20-1920
Ride Report 2012
Prutser is offline   Reply With Quote
Old 07-20-2013, 09:27 AM   #922
Airhead Wrangler
Adios Mexico
Oddometer: 6,577
What's the HD kit?
I ordered these:
"Fork Bushings for 48mm WP, KTM & Husaberg by Innteck SKF"
and these:
"Fork Seals for 48mm WP, KTM & Husaberg by SKF"
(sorry for the thread noise, solo)
Airhead Wrangler screwed with this post 07-20-2013 at 09:36 AM
Old 07-20-2013, 09:34 AM   #923
Prutser
Prutser's Avatar
Oddometer: 1,030
What's the HD kit?
In some sizes they make heavy duty kits. Than the dust seal is tighter than the normal kit.
They advice those for wet conditions. But they have more stiction again.
Ride Report 2012
Old 07-20-2013, 01:43 PM   #924
Solo Lobo OP
airhead or nothing
Solo Lobo's Avatar
Oddometer: 9,055
Just got home from Salem... the pattering or bouncing I am feeling while riding slab is the forks not moving in reaction to small bumps due to the stiction.
Hyperpro messed with the settings on my Ohlins and I was cruising 70-75mph all the way home with no real headshake issues.
To be clear, Alex from Konflict didn't rebuild my forls nor replace the bushings.
I asked him to inspect the parts and adjust the valving. Clearly there is more work needed.
He did say something about stiction when he gave these back to me, but can't remember what it was...
R65LazaruS
Old 07-25-2013, 11:56 AM   #925
Solo Lobo OP
airhead or nothing
Solo Lobo's Avatar
Oddometer: 9,055
Just caught up with Alex, and he is doing me a big favor by fitting me in next week. My forks will get new seals, wipers, bushs and fluid.
I'll report back one ASAP.
R65LazaruS
Old 07-26-2013, 11:38 PM   #926
elmontanero
Practicing...
elmontanero's Avatar
Oddometer: 1,875
Any idea what they did? My YSS is 'weavy' on the front end. Especially when there's gear in the panniers.
"And if we have food and covering, with these we shall be content."
elmontanero is online now   Reply With Quote
Old 07-27-2013, 08:41 AM   #927
Solo Lobo OP
airhead or nothing
Solo Lobo's Avatar
Oddometer: 9,055
The suspension tech basically grabbed the rear rack while the other guy held the handlebars (so the bike didn't fall over) and moved the rear up and down to demonstrate how much travel was used with just the weight of the bike with panniers (too much) then moved it up and down with light pressure (demonstrating the lack of low speed damping) and the up and down much harder showing the high speed damping was working.
He adjusted the comp and rebound repeating that test until he was happy.
I'm going to re-measure the sag with the panniers on, as I am pretty sure every other time they were off. The add pre-load to adjust back to spec
R65LazaruS
Old 07-28-2013, 09:05 AM   #928
elmontanero
Practicing...
Oddometer: 1,875
Gotcha... thanks. Nothing like having a hand do that sort of work especially if they know what they're doing. My suspension unladen is butter and very neutral. You can push down and front and back are nicely in sync. Not much for off road.. but the bike isn't used that way as much as it should be.
Laden it's rubbish on the move.
Old 07-28-2013, 10:52 AM   #929
Solo Lobo OP
airhead or nothing
Solo Lobo's Avatar
Oddometer: 9,055
I do miss the hydraulix pre-load adjuster that is available on the R100GS Ohlins... that made luggage/no luggage adustments easier.
I think I've seen on offered that may fit my G/S Ohlins and am going to investigate. Anyone esle know?
R65LazaruS
Old 07-28-2013, 11:41 AM   #930
Prutser
Prutser's Avatar
Oddometer: 1,030
If you put one on solo make sure your spring can handle the extra pre-load. !!!
Ride Report 2012
Times are GMT -7.   It's 08:36 PM.
