Old 06-28-2013, 08:33 AM   #151
craydds OP
craydds's Avatar
Oddometer: 1,156
mo' stuff
Foot pegs on:
Kick stand on:
pic:
nother pic:
pic:
ABC #12947
'75 R90S
craydds is offline   Reply With Quote
Old 06-28-2013, 08:42 AM   #152
craydds OP
craydds's Avatar
Oddometer: 1,156
test ride
Fired it up, rode it around the block:
Going to paint the old tank this weekend; working on polishing up the old plastics:
It is a running machine. Not yet ready for the desert, will get the plastics on this weekend, paint the tank. The carb is leaking out of the overflow tube - might be the float level or the needle/seat - easy fix either way.
ABC #12947
'75 R90S
Old 06-28-2013, 09:03 AM   #153
craydds OP
craydds's Avatar
Oddometer: 1,156
before and after
Old vs. new:
Took everything apart:
Cleaned it up:
Tiny motor, only 400 cc:
ABC #12947
'75 R90S
Old 06-28-2013, 02:38 PM   #154
Scootern29
Scootern29's Avatar
Oddometer: 494
It's looking real good Ray. Keep up the good work.
Scootern29 is online now   Reply With Quote
Old 07-09-2013, 06:19 AM   #155
craydds OP
craydds's Avatar
Oddometer: 1,156
desert ride
Took the bike out to the desert for a test ride on Sunday:
Got back to the house in one piece. Several adjustments were needed - brakes, shifter/rear brake lever positions, etc. Those bars had to go, too low when standing on the pegs. Put the old stock bars back on, tried to straighten them a bit. Got the side covers polished up and installed. Got a cool desert tank from Scootern29. Will get more pics later.
ABC #12947
'75 R90S
craydds screwed with this post 07-09-2013 at 06:39 PM Reason: a
Old 07-09-2013, 06:42 AM   #156
craydds OP
craydds's Avatar
Oddometer: 1,156
Air Balance Tubes
Forks:
Made some air balance tubes. Upper chambers balanced:
Fork tubes:
ABC #12947
'75 R90S
Old 07-19-2013, 05:47 AM   #157
craydds OP
craydds's Avatar
Oddometer: 1,156
desert tank
Got a Malcom Smith desert tank from Scootern29. I think it holds 11 gallons of fuel.
Ordered a grommet for the petcock, arrived today. Will get petcock installed then go for a desert ride. Should be able to ride all day long on one tank:
ABC #12947
'75 R90S
Old 07-19-2013, 10:58 AM   #158
JeffS77
cheap bastard
JeffS77's Avatar
Oddometer: 3,347
looks good .. are those the Fly Vintage bend bars ??
I have been running those on a few of my old bikes and they are damn comfy
JeffS77 is offline   Reply With Quote
Old 07-19-2013, 11:02 AM   #159
craydds OP
craydds's Avatar
Oddometer: 1,156
I think they are the stock YZ bars. They were on the bike when I bought it. I will look at those Fly Vinatage bars; might be something I'd like. These old bars are slightly bent - not too bad, it's rideable and I don't notice the tweaks. I just have a thing about bent handle bars.
ABC #12947
'75 R90S
Old 07-19-2013, 04:17 PM   #160
craydds OP
craydds's Avatar
Oddometer: 1,156
more work to come
Got the petcock on! Went for a desert ride.
Got an air box on order from vintage mx - http://www.vintagemx.us/cgi-bin/swapmeet.cgi - and new uni filter NU-2221ST air filters from Dennis Kirk. Always more work to be done.
Next big project: pull off the head and the cylinder and check the bottom end, it sounds like it is ready to grenade. Got a tip from my Yamaha shop about a local fellow who rebuilds the old 2-smokers; called him and he sounded enthusiastic, said to bring it over, said he can do ports and everything else. COOL.
ABC #12947
'75 R90S
Old 07-20-2013, 10:10 AM   #161
Scootern29
Scootern29's Avatar
Oddometer: 494
The tank looks like it cleaned up pretty well. With that much fuel you may have to ride over to 29 Palms for an Anchor Steam.
Old 07-20-2013, 01:10 PM   #162
craydds OP
craydds's Avatar
Oddometer: 1,156
That is a groovy tank. Thanks, Scott! Get those Anchor Steams in the fridge, here I come. Gonna go out to the garage now and pull off the head and cylinder - time to inspect the bottom end. Yeah, I know it sounds bass-ackwards, but I wanted to get the bike back together and ride it, now gotta pull the motor out and rebuild it (most likely). There is an unmistakable knock-knock-knock at low rpm, sounds like rod/crank is ready to grenade.
edit: Also, thanks for the tip on the air box. It should arrive soon, be a good time to install it with the motor out (I think). Will bug you for tips on air box installation.
ABC #12947
'75 R90S
craydds screwed with this post 07-20-2013 at 01:13 PM Reason: thanks
Old 07-20-2013, 03:10 PM   #163
Scootern29
Scootern29's Avatar
Oddometer: 494
Just an FYI. I picked up a comlete gasket set from DC Plastics for $50. Very good quality and fit.
www.dcvmx.com
You will need to undo the shock and maybe take the rear wheel off to get the airbox in.
Old 12-03-2013, 05:29 PM   #164
piniongear
Oddometer: 11
www.dcvmx.com
I just found this forum and have read the entire thread on restoring the YZ400.
Now since I just joined the forum yesterday, and this is my first post, I assume I am not entitled to post pics yet.
Anyway. I have a 1976 YZZ175 and after reading about the missing threads in his flywheel I removed the cover to look at mine.
I am not missing any threads, but am missing a flywheel!
Why did the 400 use a flywheel and the 175 just has a small rotor?
Anyone know?
pg
piniongear is offline   Reply With Quote
Old 12-03-2013, 05:41 PM   #165
stainlesscycle
stainlesscycle's Avatar
Oddometer: 2,247
Anyone know?
pg
internal rotor flywheel on 76 yz175, makes for a more zippy motor. the 73-75 mx/yz250 (+ many more) also had internal rotor (but they aren't interchangeable with yours..) . fortunately there are tons of options/ways to switch it to external if you want.
current bikes
stainlesscycle is online now   Reply With Quote
Times are GMT -7.   It's 11:07 AM.
