Old 07-21-2013, 01:40 PM   #16
Anorak
Woolf Barnato
Anorak's Avatar
Oddometer: 34,283
Originally Posted by El Gato View Post
Love the look. FWIW - I did the euro LED swap on my '12 GSA, and no software update was required. It was a straight plug 'n play and they worked perfectly out of the box. Not sure why BMW felt the need to complicate matters on the new LC.
Because they're BMW.
'Gonna get me a six pack...push people off the highway!'
"they live off the carrion of our mutual distrust and bribe us with symbols that equate hatred with manhood."
"I mean at the end of the day, I was addicted to Starting Fluid for Christ's sake!"
"Yeah, that guy sure is terrible at touching moms"
Anorak is offline   Reply With Quote
Old 07-21-2013, 05:10 PM   #17
paco fernandez
Mexico
paco fernandez's Avatar
Oddometer: 64
You don't need a software update, just need a cable that comes with a resistor, it is oem equipment, ask you dealer for it, you bike will never alert you about lamp failure.
Enviado desde mi iPad con Tapatalk HD
paco fernandez is offline   Reply With Quote
Old 07-21-2013, 05:28 PM   #18
JetSpeed
Naviator
JetSpeed's Avatar
Oddometer: 3,439
Thumb
The $26 cable that you speak of is part # 71607711284 which is for pre-08 models that did not have the LED Turn Indicator selection in the ISTA/P menu.
Although the cable would be one way to make the system work, ideally the software update would be the way to go in my opinion.
Pull chocks.
JetSpeed is offline   Reply With Quote
Old 07-21-2013, 06:29 PM   #19
Crilly
Oddometer: 789
I heard that it is not the size of the LEDs, but the length of the front stems. Our DOT wants the front lights wider. And yes I had them on my 2010 GS and I have them on my wet head. Also waiting for the down load.
Crilly is offline   Reply With Quote
Old 07-21-2013, 08:22 PM   #20
EJ_92606
Rider
EJ_92606's Avatar
Oddometer: 1,779
So 4 $26 cables required? No thanks, I'll wait for the software update.
EJ_92606 is offline   Reply With Quote
Old 07-21-2013, 08:43 PM   #21
oz97tj OP
oz97tj's Avatar
Oddometer: 831
No, it's not a cable and resistor issue. The computer in the new bike controls the blinkers. The Euro bikes don't have a resistor to function. It's handled by the computer.
In theory, a very cheap resistor could likely be spliced in line and probably fix the issue, but a resistor is nothing more than something turning the electricity into heat. It's old tech. Recent BMWs do have the ability to fix the issue of the lamp warning via the computer update, but the software hasn't been made available for the GSW yet. It's nothing more than changing the option in the computer.
'15 KTM 500 EXC / '13 BMW 1200 GSW / '05 Honda ST1300 / '04 Husqvarna TE510
oz97tj is offline   Reply With Quote
Old 07-23-2013, 10:36 AM   #22
chewnaut
Rob
chewnaut's Avatar
Oddometer: 77
I say; Blame it all on that worthless piece of shit.
tact much
chewnaut is offline   Reply With Quote
Old 07-23-2013, 10:02 PM   #23
EJ_92606
Rider
EJ_92606's Avatar
Oddometer: 1,779
Anyone that has upgraded to the LEDs on their GSW want to sell me their stock rear turn signals?
'13 R1200 GSW
Old 07-26-2014, 05:45 PM   #24
wandrew
Oddometer: 2
Did BMW eventually update the software on the LC GS's to make BMW (or other) LED turn signals plug and play without warnings?
wandrew is offline   Reply With Quote
Old 07-27-2014, 09:51 AM   #25
wandrew
Oddometer: 2
Thanks for that!
I'm going to replace the stock US turn signals. The front ones flap around in the wind, not in keeping with the quality of the rest of the bike. The stalks also pull out far too easily (like when I remove the cover from the bike or bump them whilst cleaning), and to pop them back in you have to remove the torx bolt, rotate through 90 degrees, insert in keyhole, rotate 90 degrees, replace the torx bolt... its a PITA!
2014 R1200GS
Old 07-28-2014, 12:27 PM   #26
Aviatordoc
BMW K12S rider
Aviatordoc's Avatar
Oddometer: 405
Originally Posted by wandrew View Post
Thanks for that!
^^ completely agree. What a POS on an otherwise well put together bike.
______________
2015 Husqvarna 501S
2014 BMW GS Adventure
2011 Suzuki DR 650SE
2007 BMW K1200S
Aviatordoc is online now   Reply With Quote
Old 07-28-2014, 12:55 PM   #27
EJ_92606
Rider
EJ_92606's Avatar
Oddometer: 1,779
Unfortunate DOT regulation. The rest of the world either gets LED or halogen with shorter stalks. The part number for front signals outside the US is the same as our rear signals, so I got an extra set from a friend that upgraded to LED and installed them on the
front...very simple install and looks great.
'13 R1200 GSW
Times are GMT -7.   It's 03:37 AM.
