Old 07-15-2013, 11:46 AM   #16
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,695
That does make sense, but I do see the same issues with county maintained roads.
Old 07-15-2013, 06:39 PM   #17
philthyphil OP
Nomad
philthyphil's Avatar
Oddometer: 110
Originally Posted by Albie View Post
Oh, and the 100K does show some roads that CN doesn't.
Does the 100k have similar zoom properties as city navigator? Meaning you can see smaller roads at certain zoom levels so is it the same between the two? I could care less about using this software for voice directions or city driving, other than just passing through. This tool will be used looking for roads outside of these areas so I am curious which is better for that, having the most accurate/complete roads.
I'm basically looking to get lost while knowing exactly where I am so I can wander and end up exactly where I want.
09 FLSTSB - 05 KLR 650 - 04 KTM 450 SX - 00 Bandit...
And some old Landcruiser's
Previous Rides: '88 Virago (5k), '04 VTX 1300 (20k), '07 FLSTSC (20k), '10 FLHR (7k)
philthyphil is online now   Reply With Quote
Old 07-23-2013, 07:29 PM   #18
philthyphil OP
Nomad
Oddometer: 110
In an effort to stay out of the overwhelming 600 page Montana thread, I'll continue to post my questions here regarding my Montana 600 and map install/use...
I purchased, recieved, and successfully installed the CNNA both on my machine and on my blank 8gb SD card! I'm terrible with technology so this was a big success and I'm proud. Problem is I've been unsuccuessful in bringing CNNA up on my device. I have it uploaded to the card, and the card loaded in the device (physicallly) but I can't seem to see it. I also have the SW 24k maps but it is loaded directly on my device as opposed to the SD card, but I can't find it on the list of map options either. What perplexes me is the SW 24k map shows up on the map even though I don't have it "turned on". How do I turn on the CNNA so I can see it on the device? Thanks.
Old 07-24-2013, 04:17 AM   #19
philthyphil OP
Nomad
Oddometer: 110
Apparently the answer to the riddle is to just shut the device on and off a couple times and play with the SD card...
Old 07-24-2013, 07:12 AM   #20
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,181
So, after re-starting the unit, you can see your maps in the available choices? FYI, I think CNNA takes priority over other map sets, so if you really want to use a different one, like a Topo 24, then you have to go into map selection and disable CNNA.
Old 07-24-2013, 09:37 AM   #21
philthyphil OP
Nomad
Oddometer: 110
Honestly, I didn't even look under the map choices, I just noticed that I had the background on the map. I also cleared the curent track...
Old 04-19-2014, 11:08 AM   #22
FiveG
Oddometer: 150
Map Download
The Montana has enough internal memory to handle City Navigator. Is it better to download the map to the Montana's internal memory, or to an SD card?
I hope you succeed, but no matter what happens, Godzilla will win.
"Steve Martin," Godzilla (1985)
FiveG is offline   Reply With Quote
Old 04-19-2014, 01:33 PM   #23
philthyphil OP
Nomad
Oddometer: 110
Better? I certainly don't know. I can only tell you I put it on my SD in case I got a new unit or mine died for some reason... Aldo transferable if I got multiple units.
HTML code is Off
Times are GMT -7.   It's 07:52 AM.
