Old 01-31-2010, 02:03 PM   #1
Motorman OP
Motorman's Avatar
Oddometer: 496
Headlight Replacement Bulb For R100GSPD??
A bit of research shows that a good replacement for the stock H4 headlight bulb may be the 70/65W Osram Plus 50, or the 85/80W Osram Plus 50.
What have you tried and what worked best for you???
Thanks a ton.
Motorman is offline   Reply With Quote
Old 01-31-2010, 03:23 PM   #2
opposedcyljunkie
Heavyweight Boxer
opposedcyljunkie's Avatar
Oddometer: 4,776
I use the PIAA 14561 H4 Plasma Ion bulb. A bit yellowish at 2500K but good for foul weather. Wattage is the usual 60/55w but is claimed to throw the equivalent of 110/100w.
OCJ
92 R100GS-PD Euro
01 Vespa PX150E - sold
05 Yamaha Fazer FZS-1000
07 R1200GS
opposedcyljunkie is offline   Reply With Quote
Old 01-31-2010, 03:32 PM   #3
zDollar Bill
Eat, Sleep, Ride, Repeat
zDollar Bill's Avatar
Oddometer: 972
I really liked my gold tinted bulb, but got a ticket from the MN State Patrol. Now I am changing almost everything to HID. I now look forward to night driving because I can see so much. Went with the 6000k 55w through ddmtunning.com , Good Luck...
Here is a past thread about HID lighting http://www.advrider.com/forums/showthread.php?t=450283
zDollar Bill is offline   Reply With Quote
Old 02-01-2010, 04:44 AM   #4
dfc
Reluctant Cannonball
dfc's Avatar
Oddometer: 2,768
Thanks a ton.
http://www.amazon.com/PIAA-10904-H4-...5028068&sr=8-1
other places have them, I liked the 2 for under 50.00 pricing
'twas ever thus
dfc is offline   Reply With Quote
Old 02-01-2010, 07:13 AM   #5
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,811
I've just fitted a 90% brighter bulb...made absoulutly f**k all difference It would be nice to find a better solution than my current spotlight setup.
Rob Farmer is offline   Reply With Quote
Old 02-01-2010, 07:39 AM   #6
opposedcyljunkie
Heavyweight Boxer
Oddometer: 4,776
Rob, you meant there was no difference? I imagine just changing out the bulb would be a disappointment. I had to get a relayed H4 wiring harness from Eastern Beaver to "see the light".
OCJ
92 R100GS-PD Euro
07 R1200GS
Old 02-01-2010, 11:33 AM   #7
SUVslayer
SUVslayer's Avatar
Oddometer: 851
I'll have to look into this. I'm with Rob Farmer - I've tried a few different bulbs and really it's all shit and (not so bright) shinola. Thanks for the tip!
SUVslayer is offline   Reply With Quote
Old 02-01-2010, 12:25 PM   #8
Infracaninophile
Finding My Way..
Infracaninophile's Avatar
Oddometer: 7,515
I solved the bulb problem: I don't ride in the dark. Where I live, unless it's an absolute emergency, riding at night means a much higher chance of plowing into a deer, elk, or worse. I try to avoid if possible.
T.
Infracaninophile is offline   Reply With Quote
Old 02-02-2010, 08:21 PM   #9
mphoppe
Hops
mphoppe's Avatar
Oddometer: 577
Try the Hi/lo H4 auto setup (2 bulbs, relay, 2 ballasts, etc) from autohidguy on fleabay. I did the conversion on my KLR and it was great...bypasses total stock harness except for high/low switching relay. Going to get another set up for my newly acquired '95 R100GS. Put SLIM ballasts in the ordering notes...
Mike
2006 1150 GS Adventure
2006 CRF 250X
2010 KTM 690R
1995 R100GS (sold)
2007 XR650R as new, for sale
2001 XR650R Desert Bike
2006 KLR 650 Commuter (Sold)
2004 XR650R (sold)
2002 XR650R (sold)
Pro Racing Photos http://mikephotos.smugmug.com/
mphoppe is offline   Reply With Quote
Old 02-03-2010, 04:15 AM   #10
Beemerboff
Oddometer: 2,335
I think the plus 90% refers to price , I couldn't tell the difference in the light either.
Adelaide Hills, Australia. 93 R100 GS, 77 R75/7 ,70 BSA B44VS, , 86 R80 G/S PD, 95 BMW Funduro F650 ST
Beemerboff is online now   Reply With Quote
Old 02-03-2010, 06:02 AM   #11
duckman
co conspirator
duckman's Avatar
Oddometer: 969
PIAA H4 Xtreme White Plus XTRA Antivibration replacement light bulb, 60/55watt=110/100watt
2006 Triumph Scrambler
2003 Suzuki Sv1000 N
1987 Ducati 750 Paso
and no do rags
"who's a retard now"
duckman screwed with this post 02-03-2010 at 06:07 AM
duckman is offline   Reply With Quote
Old 07-26-2013, 01:40 PM   #12
jimbee
Airhead Intermediate
jimbee's Avatar
Oddometer: 334
I need to replace my headlight bulb on my 93 GS, but it has been a few years since I was inside the fairing and can't how much you NEED to strip down to just swap the headlamp bulb? Is it chinese fingers or is it just easiest to pull of windshield and one side blinker and fairing?
R100GS for going far, FZ1 for going fast, TE250 for getting dirty, and DR650 for when one of the others needs work
jimbee is offline   Reply With Quote
Old 07-28-2013, 08:32 PM   #13
Plaka
Brevis illi vita est
Oddometer: 4,609
Yup. And +80% for hype. They put a coating on the bulb which filters blue (I believe). Their line is that the resulting light color gives you the visibility of a higher wattage bulb. "optical equivalent, blah, blah..."
Not.
I'm running a 100/130 watt H4 w/ the standard /7 reflector, phenolic bulb holder with heatsink, gutted headlight bucket and relays on fat marine wire with their own fuses. Does light up your world.
Old 07-28-2013, 10:00 PM   #14
Steve in NZ
scared/cheap
Steve in NZ's Avatar
Oddometer: 1,045
great lights
leave the standard bulb in. I had a bigger bulb and helped shag the on/off switch. try these http://www.visionxwholesale.com/2-so...e-atv-package/
the kit supplies the whole shooting match. I got the euros.
bloody great. 10 watts each a side .75 amps email me if ya want pics of them fitted bellsj@xtra.co.nz
Cheers Steve
bike = the purple pig
Steve in NZ is offline   Reply With Quote
Old 07-28-2013, 10:40 PM   #15
Plaka
Oddometer: 4,609
Fitting big bulbs without relays and heavy wire will cook all sorts of things.
The LEDs are nice, but at 900 lumens they put out less than a 55 watt halogen. For $35 you can get some cheap halogen driving lights that will do the same thing. Of course the LED draw very little juice so you can run more of them. But they are very expensive so that get to be a very expensive proposition, fast.
These give 8200 lumens from 90 watts. That's two and a half times what my 130watt high beam puts out. (3250 lumens)
http://store.arbusa.com/ARB-Intensit...2S-P22767.aspx
http://www.danielsternlighting.com/t...ulb_types.html
Times are GMT -7.   It's 07:41 AM.
