Old 07-30-2013, 05:14 PM   #1
brooks OP
Oddometer: 323
Eek clutch slave help!
Inmates,
Riding across the country with my son, we are on why 50 outside gunnison and my clutch fluid is disappearing making my clutch hard to shift. Fluid is disappearing from the reservoir and the clutch slave is not leaking. Any suggestions??? I bought some mineral oil from a bicycle shop and filled it and bled it but we still have a long way to go! Thanks!
Brooks
brooks is offline   Reply With Quote
Old 07-30-2013, 06:14 PM   #2
MortimerSickle
Semi-Adventurer
MortimerSickle's Avatar
Oddometer: 12,138
Take another look at the master to be sure it is not wet.
Not always as obvious as it would seem.
I miss round headlights.
"When I was a young man, I liked to race my horse...." -
G.H.W.S. 1878-1962
MortimerSickle is offline   Reply With Quote
Old 07-30-2013, 06:48 PM   #3
BigWan
The Cripple Maker
BigWan's Avatar
Oddometer: 345
I don't know much about disappearing fluid. It's probably leaking from behind the slave and blending in with your chain oil.
In a pinch, I've had some success removing the slave. Taking out the spring clip. Remove the piston and clean it all up. Then rotate the o-ring 180, reassemble and bleed. It might hold a while.
BigWan is offline   Reply With Quote
Old 07-30-2013, 08:52 PM   #4
ABuck99
0.0
ABuck99's Avatar
Oddometer: 582
What year bike how any miles?
If you're loosing fluid chances are good the o-ring inside the slave is failing. You can continue to dump fluid in but it won't last long. How much time left on your trip? . PM me, I can overnight you a an Oberon slave and a bleeder kit .
KTM: 06 KTM950S & 10 KTM450EXC
ABuck99 is online now   Reply With Quote
Old 07-30-2013, 11:17 PM   #5
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,884
Here is the knowledge
http://advrider.com/forums/showthread.php?t=756603
http://advrider.com/forums/showthread.php?t=655984
http://advrider.com/forums/showthread.php?t=171986
Cheers.
Old 07-30-2013, 11:35 PM   #6
MortimerSickle
Semi-Adventurer
Oddometer: 12,138
http://www.amazon.com/021-Viton-O-Ri.../dp/B0051Y1U7W
G.H.W.S. 1878-1962
Old 07-30-2013, 11:49 PM   #7
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,884
Originally Posted by MortimerSickle View Post
In my experience, when the oring gets bad, the cylinder is probably scored/pitted so replacing orings doesn't cure much. You probably need to look into your cylinder refurbishment.
Cheers.
Old 07-30-2013, 11:54 PM   #8
MortimerSickle
Semi-Adventurer
Oddometer: 12,138
Cheers.
Mine looks good, and works well with the replacement o-ring.
Maybe I am just lucky.
G.H.W.S. 1878-1962
Old 07-31-2013, 04:05 PM   #9
brooks OP
Oddometer: 323
Thumb
Everyone is so awesome on here, someone even offered to overnight one!!!! I limped it to Gunnison CO and cleaned and replaced the oring with a .22 cent oring from car quest. It was pretty grimey in there! I have a new one being shipped already to my stop in Phoenix and I will carry it with me until the other one goes. The oring on the piston was pretty flattened and 150 miles later the cheap oring is holding strong. Thanks so much for the help onward to Durango on the million dollar highway!
Brooks
Times are GMT -7.   It's 04:15 PM.
