Old 08-09-2013, 11:30 AM   #316
ktmmitch
Oddometer: 662
LC4-50 #1 Motor
Whilst waiting to machine the new piston data tomorrow,I took the opportunity to engrave our 690 barrel to show the difference of our new project with the stock motor,as from the outside it will look identical to the stock engine.
I know it's a bit of window dressing,but could'nt resist trying out the new engraving software on our CNC mill.
ktmmitch is offline   Reply With Quote
Old 08-09-2013, 11:59 AM   #317
snowhawk jockey
Slack Jaw Gaper
snowhawk jockey's Avatar
Location: The other Center of the Universe: Bend, Oregon
Oddometer: 1,122
Nice work on the engraving! The cylinder MUST show there's a difference in your engineering vs. stock.
snowhawk jockey is offline   Reply With Quote
Old 08-10-2013, 03:10 PM   #318
ktmmitch
Oddometer: 662
Piston completedSome pictures taken today when we CNC machined our first prototype pi
We finished CNC machining our prototype piston today for the LC4-50 motor,next job is to check all valve clearances and squish,then fire it up!!!!!!!!!!!
Old 08-11-2013, 12:38 AM   #319
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,143
I like seeing these before and after shots...
DR650 Wiki
NordieBoy is offline   Reply With Quote
Old 08-11-2013, 05:35 AM   #320
Pyndon
Pyndon's Avatar
Oddometer: 2,544
Originally Posted by ktmmitch View Post
Hey John, great to see some pictures of the progress, engineering from home at it's best, I love to see this!
A few questions I would have coming from a background of tuning supermono, single cylinder road racing engines would be: (and I'm sure you have considered them all but it'd be nice to know the thought process you have been through on them)
1) What are your thoughts on flame propagation and cylinder efficiency with such a complicated piston top? Obviously a flat top piston and well shaped combustion chamber helps with turbulence and combustion rate, but here you certainly don't have that. What did cosworth have to say about this, I mean they have the experience in this field so I'd be interested to hear what their thoughts were?
2) Reducing the valve shrouding on a piston helps to get gasses in and out faster which is particularly important when you have an over square engine, obviously you are fully shrouded during cross over points so you must have your cam design pretty mature? Interested to see your cam profiling and overlaps chosen for the 450 project and will this be different for the different options of engine?
3) Finally, how did you avoid piston distortion during welding and do you intend to heat treat the piston again before using it? Appreciate it's only for demonstration and measurement purposes but still, thought I'd ask.
4) Valve and port sizing is pretty important too, do you have a plan to reduce the port volumes or valve sizes in the future to try and get the gas speed up a little?
5) Balancing? Extra piston weight really does screw with the balancing, will the Cosworth piston weight the same as stock or are you going to get everything balanced?
My intention was not to overload you with questions, just genuinely interested as I'm sure the other engineers amongst us will be.
On the down-drafted CRF450 motors that I used to build, even with a raised piston, we still had to achieve a relatively flat top and put a load of work into the combustion chamber to make this possible. Granted, we were always looking for around 70rwhp from a 450 and I know that's not the goal here.
I for one am really interested to see this project unfold and succeed, probably less for the end result for me personally (if I am honest) but more for the journey that that the guys are going through. The shear determination, lessons learnt along the way and the fun and excitement of a project such as this will make it all worthwhile. I also hope that I get the opportunity to ride the bike one day as I think it'll be a unique little fella. Good luck with it all.
Crack on!
Lyndon Poskitt Racing
Currently racing my way around the world at: www.facebook.com/LyndonPoskittRacing
Blogging at: www.racestoplaces.com
My Dakar Rally Experience
and blog www.LyndonPoskittRacing.com
My KTM 950 Story
Pyndon is offline   Reply With Quote
Old 08-11-2013, 08:31 AM   #321
ktmmitch
Oddometer: 662
Crack on!
Bloody hell Lyndon,it's a good job I'm on holiday this week so I have time to answer all those questions!!!
In response,here is the best I can explain .........
1.Cosworth understood that our brief was to try and keep the cylinder head standard,so that we can hopefully supply a customer 450 kit,which will consist of a short-stroke crank,and new piston,therefore making the kit as simple(and cheap) as possible.To this end,we realise we have compromised the gas flow,as they had to design such a high intruder into the combustion chamber,in order to get the compression back to standard,due to the fact we are only now sweeping 450cc instead of 654cc into the same head.This wont become apparent until we build and run the motor,but we will have to cross that bridge when we come to it.
2.Initially we will try the std cam & 690 rally cam,but have offers of cam design help from outside if we need it.
3.We annealed the piston after welding and will stress-relieve it after machining,it did distort slightly,as the gudgeon pin was very tight going in,so we reamed it back to 20mm diameter.It is something we will have to live with for the prototype engine.
4.Cosworth engineers did suggest the reduction in valve & port size to get more efficiency,but again, we want to keep the head standard, for simplicity.
5.The new production 450ccCosworth piston will be slightly heavier than the OEM version.The other 2 versions(stock comp & hi-comp 690cc) will be OEM weight.
Like you say,we are on a journey,not quite sure of the result,but we are definitely going to give it our best shot at making a "clubman" Dakar-spec 450 Rally bike, that is affordable and uber-reliable.We realised that from Day 1 it would never have 450RR power,but that is what we are prepared to swap for reliability and expense.
It will be great to get it on the road and trail ride it soon,come down and try it out.
Old 08-11-2013, 11:42 AM   #322
Pyndon
Pyndon's Avatar
Oddometer: 2,544
John, thanks for the comprehensive response, this is as I'd thought but just thought I'd ask. Given that you are just down the road, I'd love to come down for a ride on it or even help with any niggles if I can.
I am sick today.....hence the only reason I have time to post!! Should be out training / riding really.
Thanks again, see you soon. Lyndon
My KTM 950 Story
Old 08-11-2013, 01:21 PM   #323
ktmmitch
Oddometer: 662
It must have been the fish,chips,mushy peas & fanta that tipped you over the edge!!!!!!!!!!!!!!!!
A racer's diet if ever I saw it.......
Old 08-12-2013, 01:22 AM   #324
Pyndon
Pyndon's Avatar
Oddometer: 2,544
It started about 4 hours after that!
My KTM 950 Story
Old 08-12-2013, 03:46 AM   #325
gladiator
Oddometer: 62
This really is mouth-watering stuff. Thanks guys
gladiator is offline   Reply With Quote
Old 08-20-2013, 03:01 PM   #326
ktmmitch
Oddometer: 662
Together at last !!!!!
I had a great surprise today when arriving at Torque Racing HQ, as Martin had fitted the new piston to the waiting bottom end of the project 450 motor, then finished it off with the rebuilt head.
All turned over well, plenty of valve clearance and nice compression.I was very impressed to see it all come together after many months of hard work, given the huge personal setbacks we have all had over the last year.
I am extremely glad it has got this far, and much credit goes to Martin at Torque Racing, Dan Coxall at Cosworth, Derrick Edmondson & Jonah at Edmondson Racing for their support in all aspects of this project.
It is at landmark times like this that our absent friends, Gordon & Wes, are most missed, as they would both have had a lot to say about the idea, as they were both involved in it's conception.
The next stage is to get it into a bike when we return fron Transanatolia Rallye in Turkey for trail testing.
Old 08-21-2013, 12:38 AM   #327
garfey
Scruffy Adventurer
garfey's Avatar
Oddometer: 5,116
Fingers crossed!
So many bikes, so little time (and money)
garfey is offline   Reply With Quote
Old 08-24-2013, 07:21 AM   #328
JMo (& piglet) OP
Gone a bit Baja
JMo (& piglet)'s Avatar
Oddometer: 4,205
News hot off the press!!!
Just spoken to John at Rally Raid this afternoon and Martin & Donna from Torque Racing have not only fired up the LC4-50 engine, but Donna has test ridden it in her 690 race bike - it's alive!!!
More info (and photos and video) from John and Co. soon!
Woop! Jx
JMo (& piglet) is offline   Reply With Quote
Old 08-24-2013, 07:25 AM   #329
GalacticGS
1200 GS Rider
GalacticGS's Avatar
Oddometer: 2,310
Congrats on achieving that next big step!!!
Larry
2006 R1200GS; 2009 Husaberg Rally 570; 2011 Husaberg FE570
www.galacticgs.com
"Speak to me of summer, long winters longer than time can remember;
Setting up of other roads, travel on in old accustomed ways."
GalacticGS is offline   Reply With Quote
Old 08-24-2013, 08:30 AM   #330
Yellow Pig
Allergic to Asphalt!
Yellow Pig's Avatar
Oddometer: 7,555
Woop! Jx
Very cool!
Times are GMT -7.   It's 03:48 AM.
