Old 09-27-2011, 11:59 PM   #1
Vicks OP
I love sand !!!
Vicks's Avatar
Oddometer: 3,128
Low fuel level sensor - leaking
Hey guys,
After i did a refresh of my '07 990S at 25,000kms i have a leaking fuel level sensor. The sensor seems to be pressed into the body which has the mounting holes. I had only taken it out while heat shielding my tanks. Now after i fitted it back with the O-ring in place, loctited and properly torqued the screws, it starts weeping once i fill it with gas. Initially the leak was bad, like dripping and then i removed it and coated the sensor mount body with some PVC pipe adhesive from the inside (which does not mix with petrol - i have tested this adequately) and the leak reduced to a weep, but it still is there. Any solutions other than replacing the damn sensor ?
cheers
GO !!! Berglund brothers #148 #149
GO !!! CS Santosh #59
Vicks is offline   Reply With Quote
Old 09-28-2011, 01:50 PM   #2
DSM8
Where fun goes to die....
DSM8's Avatar
Oddometer: 3,756
The is a permanent solution but cheaper than a new unit.
Epoxy in the sensor from the back.
Just make sure to prep the surface really well, sand it to give some tooth for the epoxy.
Just a KLR solution to a KTM problem.
DSM8 - A different kind of mean
SQL > SELECT finger FROM hand WHERE id=3
http://share.findmespot.com/shared/f...d5LbKWMz6cHxaH
DSM8 is offline   Reply With Quote
Old 09-28-2011, 04:30 PM   #3
geometrician
let's keep going...
geometrician's Avatar
Oddometer: 1,026
Hylomar
You want some Hylomar, you do... best stuff in the world, water, oil, gasoline, solvent, coolant resistant, non-hardening...
Here ya go
Britt
'06 KTM 950 Adv 'S'
'03 KTM 250 EXC
'87 KLR650 - <200K miles "Like the Energizer Bunny, just keeps going & going..."
geometrician is offline   Reply With Quote
Old 09-28-2011, 06:30 PM   #4
v8toilet
Nothing to see here.
v8toilet's Avatar
Oddometer: 1,713
Hylomar +1
v8toilet is offline   Reply With Quote
Old 09-29-2011, 02:11 AM   #5
Vicks OP
I love sand !!!
Vicks's Avatar
Oddometer: 3,128
I tested some Metal epoxy and it holds up well immersed in petrol. The Hylomar seems to be good but I seriously doubt if I’ll find it here, but I’ll go look for it. Somehow I have a feeling I’ll end up with the metal epoxy. Thanks for the “rough up the surface” hint.
Old 09-29-2011, 10:50 AM   #6
geometrician
let's keep going...
Oddometer: 1,026
Thumb Be Prepared
I carry Hylomar in my tool kit as well as steel epoxy
order some up for next time, could be another rider you'll save some day with it, I know I got a lot of miles out of a tube and fixed a lot of things trail-side
Britt
'06 KTM 950 Adv 'S'
'03 KTM 250 EXC
Old 08-12-2013, 08:42 AM   #7
Orangecicle
Orangecicle's Avatar
Oddometer: 2,460
I was wondering why my 950 smelled of gas when parked. Now I know. I have the same leak. New sensor ordered. It seems more safe than the alternative.
Facebook Page: https://www.facebook.com/brad.horn.9
Orangecicle is offline   Reply With Quote
Old 08-12-2013, 11:40 AM   #8
Vicks OP
I love sand !!!
Vicks's Avatar
Oddometer: 3,128
I roughened the surface before applying metal epoxy and 10k+ kms later, it is still good. So, don't discount a KLR solution to a KTM problem.
Old 08-12-2013, 04:12 PM   #9
triplenickel
triplenickel's Avatar
Oddometer: 2,427
Hylomar and make sure your tank is venting properly.
07 SE
PG007
Times are GMT -7.   It's 12:22 PM.
