Old 08-15-2013, 08:16 AM   #16
xTomKx
xTomKx's Avatar
Oddometer: 195
Originally Posted by Mr_Snips View Post
Burning some oil has a lot to do with how the bike broke itself in. How tight or loose the rings seated. I assume you are running rotella t6 which burns a little in my bike too. Normally i run 15w60 out here in the desert with motul 300v but i was in a pinch and it needed changed bad so i through rotella back in it for my ride friday.
Yes, I went with rotella t6 at my first oil change. I run that stuff in all my other bikes without any issues but I'm thinking it may be too thin for the v-twin.
Most of my friends have sportbikes and we ride twisties so I have to keep the rpm up. 5-8k rpm range most of the time. Saying that I expect some oil usage. My 990 doesn't run any hotter than sportbikes.
2012 KTM 990A, 2006 KTM 250 2s, and many other toys
xTomKx is offline   Reply With Quote
Old 08-15-2013, 08:17 AM   #17
two trackin fool OP
two trackin fool's Avatar
Oddometer: 1,276
Yes I did read the Owners Manual . Also into the Service Manual often looking around .
I was trying to get a GOOD cold base line for future use and for a fill mark after oil change .
I have since givin up on that .
Stay Patient and Trust your Journey
two trackin fool is offline   Reply With Quote
Old 05-28-2014, 09:31 PM   #18
two trackin fool OP
Oddometer: 1,276
This is really bothering me
Ok I currently have Bel-Ray 10w50 in the girl . Still using oil . If its is the nature so be it just hard to believe .
I have been running the oil level halfway between add & full when cold which puts me at the full mark when checked hot .
Just added oil today seems to use it when I do some super slab time .
Do any of you notice air pressure in the oil tank when hot check ?
Old 05-29-2014, 06:25 AM   #19
xTomKx
xTomKx's Avatar
Oddometer: 195
I never noticed any pressure in the oil tank.
How many miles on your bike?
Old 05-29-2014, 06:31 AM   #20
xTomKx
xTomKx's Avatar
Oddometer: 195
Also, My daily driver is an audi and it's typical for them to use a little oil being that it is german and has a turbo. What I noticed is that the amount it uses depends on the oil I use. Saying that maybe you should try different oil.
Or maybe you ride her too easy and she's not broken in yet?
Old 05-29-2014, 07:36 AM   #21
NeptuneTriton
Oddometer: 214
Talking Checking Oil Level KTM 990 - Oil Usage
I too had trouble getting a consistent reading when checking the oil, but than I figured it out. It was super frustrating because it seemed like the oil readings were all over the place all the time!
1.) Run the bike until it's hot. I don't mean let the bike sit and idle on the center stand for 5 mins, I mean get on it and ride it until it's hot. Or, just check after a ride.
2.) Park the bike and place on center stand. Now go take your helmet, jacket, and gloves off. Go to the garage and grab a rag. This should take you a few minutes. NOW is the time to check the oil level. If you immediately jump off the bike and try checking the oil, you'll probably feel a vacuum pressure when unscrewing the dipstick. You'll probably get really high readings and maybe even a foamy oil residue on the stick. You have to give the bike a couple minutes to settle, with the engine hot, then check the oil. I get very consistent readings doing it this way.
I have just under 5,000 total miles on mine and it does use a little oil. My understanding after doing some research is that these bikes will do that until fully broken in.
NeptuneTriton is offline   Reply With Quote
Old 05-29-2014, 08:40 AM   #22
bajamcguide
Oddometer: 78
Some bikes lose oil via a bad balance shaft seal located in the cover on the left hand side. my 04 950 ADV. used about a 1/2 quart between oil changes at 3 to 4000 miles. My 07 990 SD did not use any oil. My 2011 990 SMR uses more than my 950 ADV. I think that just the way it is.
bajamcguide is offline   Reply With Quote
Old 05-29-2014, 09:26 AM   #23
Bighat
Oddometer: 38
I have pressure in my tank as well when its hot....To check, park bike on center stand, start bike when cold, let it warm to 4 bars, turn off motor, let sit for one to two minutes, check oil...I always get the same reading this way, my bike does not use any oil...
Bighat is offline   Reply With Quote
Old 05-29-2014, 09:36 AM   #24
gearheadE30
gearheadE30's Avatar
Oddometer: 877
50k miles and it barely uses any oil... guess I'm one of the lucky ones?
2005.5 KTM 950 Adventure and 2012 KTM 200 XC-W
1991 BMW 318is turbo track car
1989 Chevrolet Caprice Classic Wagon sleeper tow car
1992 Subaru SVX daily
3 Months Exploring the US on a 950
gearheadE30 is offline   Reply With Quote
Old 05-29-2014, 11:18 AM   #25
GJ990
GJ990's Avatar
Oddometer: 314
2013 with 11500 miles on the clock. Goes from the top of the dip stick to the bottom in between oil changes (5000 miles).
990 Baja
GJ990 is online now   Reply With Quote
Old 05-29-2014, 11:39 AM   #26
EastSideSM
Isn't that dangerous?
Oddometer: 1,490
Yup, my 950 SM has about 45,000 miles and it has always used a bit of oil between changes, usually at least half a quart. It is the most oil I have seen any of my bikes consume. My suzukis and hondas never burned a drop. Oh well. This also happens to be the most fun bike I have ever owned, so 'i deal with it.
EastSideSM: '06 950SM Black
EastSideSM is offline   Reply With Quote
Old 05-29-2014, 11:41 AM   #27
Mikef5000
Oddometer: 2,030
40k miles on my 2008, and no noticeable oil consumption between (~3000 mi.) oil changes. I use synthetic, but brand doesn't matter to me. I just try to get as close to 10w50 as I can find when I need it.
2008 990 Adventure
2008 WR250R
www.Mikef5000.com
Mikef5000 is offline   Reply With Quote
Old 05-29-2014, 09:43 PM   #28
two trackin fool OP
Oddometer: 1,276
Just about to roll 18,000 miles .
I check after I ride & top off before ~ pretty much got that figured out ! I can't believe how much the oil expands in this bike .
Neptune,
Not sure if it's Vacuum or pressure actually I need to check that .
My concern I guess is I ran the valves over the winter and had a lot oil residue in one TB .
Last season I also had a hell of a time figuring out the proper oil check method . I seem to have that down now .
I can't believe the expansion rate of the oil . Then again this is the first dry sump system I have had too !
Old 05-29-2014, 09:57 PM   #29
dirtdiver
Oddometer: 2,039
My 08 has about 35K miles on it and burns about 1/2 liter between 6000 mile changes. I used delo 15-40 diesel oil for about 10k miles with no bad noticeable effect.
One thing that I really recommend, and have done myself, is the easy oil change modification to a tube to the oil drain plug on the bottom of the bike.
Now that I have that i can change the oil without removing the guards and the tanks - I tend to do it more often and therefore get less stressed about adding oil in between oil changes.
Other than 2 water pumps my bike has been great. Oh a fuel pump too. oh and some break pads and tires.
04 CRF230F
08 KTM990 ADV/ABS Black
09 KTM 530 EXC
2014 KTM 500EXC
dirtdiver is offline   Reply With Quote
Old 05-29-2014, 11:08 PM   #30
srad600
srad600's Avatar
Oddometer: 659
I've got a '12 Std. with just about 40K miles on it and she used oil up until the break in period was over, and hasn't used any since. Exactly what I put in is what I take out at oil change time. I did use the "hard" break in method to try and get the rings to seal better, so far I'm a believer.
BAJA 2014 - 990s
srad600 is offline   Reply With Quote
Times are GMT -7.   It's 01:22 PM.
