Old 08-18-2013, 02:23 PM   #1
Cycletech OP
Cycletech's Avatar
Oddometer: 561
Eek 950A with a blown headgasket? Update: Used engine going in
So before I get into this any further, I need some sage advice. A few months ago during an 800 mile day my 05 950 started blowing coolant. I didn't realize it at first, only when I got stuck trying to make my way around Atlanta and the temp started climbing did I know something was up.
I nursed it through that trip keeping the revs down and adding coolant each morning; made it back to RVA without any other issues.
So... I was really hoping a radiator cap is all she needed.. new cap and the same problem; blows coolant from the overflow, into the bottle, then all over my leg. Nursed it through another (shorter) trip, but now she's coming apart for repair.
I'm assuming I have a weak head gasket, but I won't know for sure until I pull it apart. So before I pull the heads - Any words of wisdom? If the heads come off new rings and valves will go back in. Does Kibblewhite make valves and guides for the 950?
TIA
Cycletech screwed with this post 08-21-2013 at 09:01 AM
Cycletech is offline   Reply With Quote
Old 08-18-2013, 03:34 PM   #2
Orangecicle
On a "Quest"
Orangecicle's Avatar
Oddometer: 3,132
Start simple and cheap. Put a new radiator cap on it. If that doesn't work, go from there.
I had an oil leak on the inner clutch cover that caused water to pump into the oil. It was a minor thing, but I ended up doing the top end to find it. New head gaskets require a resurfacing of the heads to do it properly. It can be done without replacing rings if you are careful and leave the piston heads in the cylinders. Some mechanics just pull the cylinders off of the pistons, and then you need new rings. Replace chains, chain guides, and tensioners while you are in there. Some of your plastic chain guides will be worn.
Orangecicle is offline   Reply With Quote
Old 08-18-2013, 03:53 PM   #3
Motomedic
Motomedic's Avatar
Oddometer: 2,503
Orangecicle, why would you think that new head gaskets REQUIRE resurfacing of the heads, and why would you think that removing the piston/rings from the cylinders then REQUIREs ring replacement?
As for the OP's question, a compression and/or leakdown test will tell you if you have a blown head gasket, but I'd be sure the water pump seals have not let go, and that the cooling system's integrity has not been compromised first. A leak will allow the system to depressurize, not to mention things like a bubble forming in the rear head due to low levels. Due to the design of the engine, if the coolant level drops low enough, an air pocket is formed in the rear head, which when it gets hot enough, expands and pushes fluid out of the radiator.
Run the bike for a few minutes then pull the outer clutch cover. Got milkshake? Rebuild the water pump. Also, check the oil filter. Wavy pleats could mean water contamination in the oil.
Feike
I don't have to agree with you to like you or respect you. -Anthony Bourdain
Motomedic is offline   Reply With Quote
Old 08-18-2013, 04:05 PM   #4
gearheadE30
gearheadE30's Avatar
Oddometer: 967
New rings are only needed if the old ones are worn; you can check ring gap for that. That said, if you have high mileage, it's usually a good idea to replace them because they can lose their tension after (quite) a while. The heads/jugs don't need to be resurfaced unless something is warped or has some fairly severe surface damage to it. I think people have a little bit of a misconception when it comes to how delicate a head gasket is, and how perfect everything actually needs to be, this coming from experience as being a mechanic.
2005.5 KTM 950 Adventure and 2012 KTM 200 XC-W
1991 BMW 318is turbo track car
1989 Chevrolet Caprice Classic Wagon sleeper tow car
1992 Subaru SVX daily
3 Months Exploring the US on a 950
gearheadE30 is offline   Reply With Quote
Old 08-18-2013, 04:17 PM   #5
renogeorge
Oddometer: 1,425
How many miles on the bike? I also would look for cooling system problems. You tried the cap. I also find that the symptoms of a leaking water pump (much more common than head gasket failure) are best detected by removing the clutch cover. I'd bet a beer or 2 that the WP is the problem....
KTMs--300, 518, 990
renogeorge is offline   Reply With Quote
Old 08-18-2013, 05:06 PM   #6
Orangecicle
On a "Quest"
Oddometer: 3,132
First, I said, "New head gaskets require a resurfacing of the heads to do it properly." I stand behind that. If you remove the heads, you will have indentations in the aluminum where the old head gaskets cut into the aluminum. The right thing to do is to just "lightly" resurface those heads. It can be done in any motorcycle shop. Just a light resurfacing to get rid of that indentation is appropriate.
I didn't say that. I said, "Some mechanics just pull the cylinders off of the pistons, and then you need new rings." I stand behind that as well. If you leave the pistons in the cylinders, you can get by without changing the rings. You pull the cylinders (leaving the pistons) and then remove the allen bolts holding the head on. From there, you can change head gaskets without changing rings. If you pull the cylinders off of the pistons by yanking the cylinders off of the pistons (a common mistake), then you need new rings. The bottom edge of the cylinders are sharp and can damage the rings. This I know because I had to buy new rings after a mechanic pulled my cylinders off the wrong way:
Old 08-18-2013, 06:33 PM   #7
Cycletech OP
Cycletech's Avatar
Oddometer: 561
Guys, explain to me how the water pump can over-pressurize the cooling system and blow coolant out the overflow. The bike isn't overheating, just blowing coolant. Mileage is just under 45,000.
What about a Super Duke engine? Drop in and go with some jetting tweaks?
Old 08-18-2013, 06:44 PM   #8
renogeorge
Oddometer: 1,425
I am trying to resist the urge to say "Right, change the motor out or pull the heads off before you check the WP". WP rebuilds are a well known maintenance item--and 45k miles would be a near record without a pump rebuild. Are you sure the bike is not overheating? You said bike was overheating on your 800 mile ride day. Checked for signs of water in the oil?
KTMs--300, 518, 990
Old 08-18-2013, 06:54 PM   #9
Cycletech OP
Cycletech's Avatar
Oddometer: 561
WP was done around 36'ish. No water in the oil, no oil in the water. It never overheated, just heated up higher than normal, maybe one bar more.
It's due for an overhaul, it's started puffing a little oil smoke when I open her up (or so my slower GS riding friends tell me ) before the coolant issue.
If I can get away with a SD engine I might go that route. Adding this up in my head with pistons, valves, gaskets, machine work, etc, has me coming close to the cost of a used engine.
Anywhere to look for a used engine other than fleabay? thx
Old 08-18-2013, 07:03 PM   #10
renogeorge
Oddometer: 1,425
Think I am beating a dead horse here, but....45k miles not typical for a rebuild. Water in oil is what you need to check. Best place is in the clutch cover. Could be a bad WP rebuild, scored shaft causing bad seal...
KTMs--300, 518, 990
Old 08-18-2013, 07:12 PM   #11
Cycletech OP
Cycletech's Avatar
Oddometer: 561
It's due for a rebuild, no question about that. Two different issues here that are getting mixed 1. engine needs overhaul 2. blowing coolant. I was putting off the overhaul until the 'off' season, but if the heads are coming off, the overhaul will happen.
I'll pull the clutch cover and check the pump before I go any further. If nothing else, we'll make sure the horse is dead.
Old 08-19-2013, 02:02 PM   #12
Cycletech OP
Cycletech's Avatar
Oddometer: 561
So here is my water pump shaft. No signs of the seal eating away at it.
No moisture hiding behind the clutch cover. Very small amount of water from the oil tank. Looked more like condensation than a cooling issue.
Any other ideas before I pull the heads?
I just wanna ride. My R50 isn't happy standing in for the KTM.
Old 08-19-2013, 06:05 PM   #13
Motomedic
Motomedic's Avatar
Oddometer: 2,503
Did you run the bike for a bit before pulling the outer clutch cover? Reason I ask is if you simply pulled it after the bike cooled down, the "milkshake" won't be there. the water separates back out of the oil and sits at the bottom of the sump.
How's the oil filter look? What about the oil itself?
Feike
Old 08-19-2013, 07:45 PM   #14
renogeorge
Oddometer: 1,425
Classic symptoms of a failed head gasket are bubbles in the coolant with motor running and cap off. Sweet smell of coolant in exhaust. If pump is good, flow should be good looking through the filler. Got time to do a compression check before you tear it down? I am sure it happens, but I don't recall hearing of an LC8 head gasket failure. Did you get it super hot?
My '07 has 35k miles on it. Runs good, no oil used. I won't even be thinking about a rebuild for a long time.
KTMs--300, 518, 990
Old 08-19-2013, 09:03 PM   #15
Motomedic
Motomedic's Avatar
Oddometer: 2,503
Another thought- better equipped auto shops can test your coolant for the presence of combustion gases. Might be worth a phone call or two.
Feike
Times are GMT -7.   It's 11:43 AM.
