Go Back   ADVrider > Riding > Regional Forums > Australia
Old 08-18-2013, 08:04 PM   #13426
ER70S-2
ER70S-2's Avatar
Oddometer: 7,289
Originally Posted by Mushu View Post
Is this directed at me? I use my phone to access the forum so it looks normal without spaces between pictures, but since it obviously doesn't work for you guys using computers I will edit my post to comply.
Yes it was and thanks, that fixed it.
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 08-19-2013, 01:50 AM   #13427
kano650
more cowbell
kano650's Avatar
Oddometer: 217
Has anyone heard of the stock BST carb leaking gas from where the fuel inlet pipe connects to the carb on the DR? We had my mates carby off the other night to put a DJ kit in and since then it's been weeping gas ever so slightly. Not from the overflow though where you'd expect to see it, but from what looks like could be the float bowl gasket or inlet pipe. Bowl came off and gasket is all good. Overflow pipe isn't blocked so I can't work out why/how/where it could be leaking fuel?
Sent from my GT-I9505 using Tapatalk 2
kano650 is online now   Reply With Quote
Old 08-19-2013, 03:04 AM   #13428
grrant1058
Motorcyclist 24/7
grrant1058's Avatar
Oddometer: 354
That's heaps - at least 6 litres there! At 21 km per litre that should almost get me almost 135 km's.
And I haven't forgotten I still owe you 500 ml's of fuel.
Originally Posted by BygDaddee View Post
Looks like your carrying about as much fuel as the time you did when you ran out at Urbenville, hopefully there's someone around to help you out again.
grrant1058 is offline   Reply With Quote
Old 08-19-2013, 11:37 AM   #13429
B1
Carbon-based bipedal
B1's Avatar
Oddometer: 3,478
someone correct me if i'm wrong, isn't there a tiny rubber o-ring that can pop off the lower section of the float bowel if you aren't careful? or am i just getting confused with the one that definitely exists at the top of the carb when you take the plastic top off?
free enduro training vids for gumbies here
B1 is offline   Reply With Quote
Old 08-19-2013, 02:10 PM   #13430
kano650
more cowbell
kano650's Avatar
Oddometer: 217
Hey b1 nah there's no o-ring on that bottom section unfortunately, just the gasket. I've ordered a new float bowl gasket and needle and seat and for it but I'm still perplexed. If the needle and seat were shot it should be leaking from the over flow. That's why I'm thinking it must be the inlet pipe.
Old 08-19-2013, 03:18 PM   #13431
0405canvet
Oddometer: 454
The fuel line may have a pin hole leak or small split??
0405canvet is offline   Reply With Quote
Old 08-19-2013, 03:28 PM   #13432
ER70S-2
ER70S-2's Avatar
Oddometer: 7,289
That inlet is stuck in there tight, some guys have bent them trying to rotate for a larger tank. I wonder if that wicking Loctite would work in this application?
2013 WR250R
Old 08-19-2013, 03:32 PM   #13433
kano650
more cowbell
kano650's Avatar
Oddometer: 217
Yeah I'll change the hose as well while I've got the bike apart. It's odd that I can't see any fuel on the end of the hose as that'd be the obvious culprit.
Old 08-19-2013, 03:46 PM   #13434
kano650
more cowbell
kano650's Avatar
Oddometer: 217
I know I've twisted mine around to get everything out of the safari tank and that pipe is in there tight. That's why it seems unlikely to me that it could leak from here on my mates bike. I think I'll try and seal it off anyway with some loctite or jbweld just incase
Old 08-19-2013, 03:52 PM   #13435
ER70S-2
ER70S-2's Avatar
Oddometer: 7,289
Any chance you guys just got a small bit of debris on the float bowl o-ring? Might just need a quick hosing off.
2013 WR250R
Old 08-19-2013, 03:56 PM   #13436
kano650
more cowbell
kano650's Avatar
Oddometer: 217
Unlikely. We took the bowl off again to check it and it looked ok. Put it back on and half an hour later it started weeping out again
Old 08-21-2013, 12:51 PM   #13437
Lupine128
That's MR Band Aid!
Lupine128's Avatar
Oddometer: 1,005
I've put my MPE forks onto Boo's bike and so have a surplus DR front end.
Have a look at the for sale thread.
Complete front end including wheel, light, speedo and headlight surround.
Asking $650 for the lot and I'll toss in a free rear shock.
http://lupineandboogowandering.blogspot.com
Dropped from full Team F5 sponsorship due to family commitments.
Stupid family.
Lupine128 is offline   Reply With Quote
Old 08-23-2013, 03:26 AM   #13438
panhead_pete
Gone riding
Oddometer: 1,192
Does anyone know of a seat good for long days? Just got in from a 937km day and my ass hurts :) Hoping there is a better option.
Going to Japan? Im there and happy to help.
panhead_pete is offline   Reply With Quote
Old 08-23-2013, 04:12 AM   #13439
NZSHAKER
Oddometer: 162
I have an extra padded seat and my ass still hurts, so I got myself a airhawk and loved it.....
NZSHAKER is offline   Reply With Quote
Old 08-23-2013, 01:50 PM   #13440
Big Willy
two dementional
Big Willy's Avatar
Oddometer: 2,272
I find if you sit sidesaddle with your legs crossed, it can be very relaxing, especially with cruise control .
Airhawk or a nice thick sheepskin also fit the bill
He has a vairwee good fwiend in Wome you know
Big Willy is online now   Reply With Quote
Times are GMT -7.   It's 12:32 AM.
