Old 08-23-2013, 03:26 AM   #1
Howz OP
Howz's Avatar
Oddometer: 16
950 engine noise etc
I have recently acquired a 2004 950 Adventure with a little over 25,000 miles, she has recently had a full KTM service including the valves, prior to this she was not used for about a year.
Sometimes when I start her from cold I can hear a loud clacking noise from the right hand side of the engine, this does not go away until she has been ridden for a while, sometimes when starting from cold there is no clacking noise?
Any ideas?
The other issue I have come across is that when I am trying to hold a steady speed of say 60, 70 or 80mph I can feel a very slight lurching back and forward?
Thanks for your help.
Howz is offline   Reply With Quote
Old 08-23-2013, 05:40 AM   #2
deepfreeze
Oddometer: 32
I would say that the most obvious reason is the oil pressure. 950 has camchain tensioner that works by oil pressure. If the pressure is low it will make clacking noise.
Reasons for a low oil pressure can be different, but the most usual is small amount of cooling liquid that has passed to oil trough the water pumps sealing. That will partially block the paper oilfilter and oil circulation.
There are other reasons too but that´s the most common. And relatively easy to fix.
http://www.advrider.com/forums/showthread.php?t=699703
check also
http://ktm950.info/
Check also that You have Your idle rpm right. Should be around 1400 - 1500. If too low it doesnt produce enough oil pressure.
regards,
sami
Any ideas?
deepfreeze screwed with this post 08-23-2013 at 05:48 AM
deepfreeze is offline   Reply With Quote
Old 08-23-2013, 07:47 AM   #3
DeepInIt
DeepInIt's Avatar
Oddometer: 1,368
Read through the Faq because a low mileage 04 probably has had little done to it and it could use a few upgrades. Go ahead and do the water pump, if stock, you have the worst version. Chain tensioners go bad and are easy to replace, do both at the same time. Find out if they cleaned your clutch oil jet during the service, particularly after sitting a year. Change your clutch fluid, i bet it is black, get aftermarket clutch slave if you never want to have problems. You can elminate the common problems and just go enjoy the bike.
DeepInIt is offline   Reply With Quote
Old 08-23-2013, 09:11 AM   #4
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,239
Totally normal. my '04 was a noisy motor, always was even with a lot of the so-called upgrades listed above done to it. My current '05 is amazingly quiet. It's just the nature of the beast.
Chuckracer is offline   Reply With Quote
Old 08-23-2013, 10:48 AM   #5
gearheadE30
gearheadE30's Avatar
Oddometer: 873
Lurching would be from jetting or from your drive chain being too loose. The latter is very common. Due to KTM's chain slider setup, excess chain slop isn't always immediately noticeable.
2005.5 KTM 950 Adventure and 2012 KTM 200 XC-W
1991 BMW 318is turbo track car
1989 Chevrolet Caprice Classic Wagon sleeper tow car
1992 Subaru SVX daily
3 Months Exploring the US on a 950
gearheadE30 is offline   Reply With Quote
Old 08-23-2013, 10:08 PM   #6
bomose
bomose's Avatar
Oddometer: 1,195
I have a 2004 with about 40k miles. I bought it used with 18k. I thought it was coming apart every time I started it up. They just have a lot of engine noise.As far as the lurching, check the TPS (throttle positioning sensor)to make sure it is within specs.Sometimes that can cause it.
http://ktm950.info/how/wotf/wotf.htm...PositionSensor
I prefer a short life with width to a narrow one with length-Avicenna
http://www.advrider.com/forums/showthread.php?t=810149 Ouray Adv
http://www.advrider.com/forums/showthread.php?t=800723 Cortez & Moab
http://www.advrider.com/forums/showt...=955211Chasing Dinosaurs
bomose screwed with this post 08-24-2013 at 11:56 AM
bomose is offline   Reply With Quote
Old 08-24-2013, 06:18 AM   #7
rossguzzi
990 Adv.
rossguzzi's Avatar
Oddometer: 965
The noise can be just old oil. I also find full synth oil makes the motor noisier. I use Castrol 4t and the oil stays in the cam chain tensioners longer. Quieter on start up.
As for the lurching, you may have to sort the carbs out. Do you know what jets are in it?
I would recomend getting a set of jets from one of the recomended sources around here, be carfull installing them, check the float level (precise) and check the carb vent hoses are venting in the right area. I also fitted a air damper (shield) around the front of the carbs (Rottwieler air filter) cause I had a bit of hunting at 100 kph. I think the air needs to be more still around the air filter area.
Good luck.
990 Adv 06, Aprilia Tuono 03 Racing gen 1
rossguzzi is offline   Reply With Quote
Old 08-24-2013, 06:28 AM   #8
Howz OP
Howz's Avatar
Oddometer: 16
Thanks for all the advice, the bike had a full Ktm service including a new battery and headstock bearings just before I got it at a cost of £856! It does have a Oberon clutch unit fitted and looks like it was loved at some point in its life! Not sure if the water pump or anything else has been done. With regards to the noise it seems strange that it only makes the noise when cold, I have just been running the bike outside and once it gets up to about 4 bars the noise disappears, at no point does the oil light come on. It's almost as though it is taking time to build up the cam chain pressure?
Old 08-24-2013, 06:32 AM   #9
Sumi
Sumi's Avatar
Oddometer: 1,796
If the oil light is not coming on (not even when the engine is shut off) -> the oil pressure sender has failed or got disconnected from the harness
The cam chain noise should not exist any longer than a couple of seconds, so it has to go away way before getting it up to 4 bars on the temp gauge.
Old 08-24-2013, 06:34 AM   #10
Howz OP
Howz's Avatar
Oddometer: 16
Originally Posted by Sumi View Post
If the oil light is not coming on (not even when the engine is shut off) -> the oil pressure sender has failed.
The cam chain noise should not exist any longer than a couple of seconds, so it has to go way before getting it up to 4 bars on the temp gauge.
Sorry, I meant the oil light does not come on when the engine is running, it comes on when the ignition is turned on and goes off when the engine is started.
And yes, noise does not go away until engine is warm, I.e. 4 bars..
Old 08-24-2013, 06:40 AM   #11
Sumi
Sumi's Avatar
Oddometer: 1,796
It can also be a little worn clutch pack, booster, or old style basket..
I don't know, but if it runs fine, and everything looks fine instead of some strange noises, I'd use it as is until she fells apart. I know - I know preventative maintenance.. but it just takes out the joy of the ride (the constant worries) and sometimes going in front of the problems won't make it cheaper.. Just my $0.02, but I'd ride it until some more serious symptoms.
But if you are on the paranoid side, and enjoy wrenching more than riding, then you can always strip down the engine, change some gaskets, retorque some bolts, etc.. just to find out everything was alright
Old 08-24-2013, 06:54 AM   #12
O.C.F.RIDER
Loose nut behind h/bars
O.C.F.RIDER's Avatar
Oddometer: 4,881
My 2004 "S" sounds like a tin can full of big rocks.
Just turned over 55,000 miles yesterday.
Sounded like shit since about 5,000 miles
Still running the ORIGINAL water pump.
Go figure.
CW
http://www.theshining.info/
KTM 950 Adv. "S"...'06 KTM 525 EXC...
'76 MV Agusta 750 America S...'84 Honda VF1000...
'75 Kawi 900 Z1...'90 Kawi ZX11...'03 Kawi ZRX 1200...'01 VOR 400E
O.C.F.RIDER is offline   Reply With Quote
Old 08-24-2013, 07:17 AM   #13
Howz OP
Howz's Avatar
Oddometer: 16
Go figure.
CW
Yes, the best description I have heard so far is that it "sounds like a Dalek trying to have a wank in a dustbin!"
Old 08-25-2013, 06:12 AM   #14
Boatman
Upward and onward!!
Boatman's Avatar
Oddometer: 10,267
Go figure.
CW
Yes and Yes.
My 04' with just over 42k miles sounds like crap upon starting ,,,, sometimes. Sometimes it take a riding a few hundred yards to quite down and other times it's quiet upon startup. Oil new, old or different weights has no effect. I've also done all the "upgrades" with very little difference. Has been this way since I owned it with around 5000 miles.
08 KTM 950 SE, 09 KTM 950 SE, 04 KTM 950 ADV, 10 Husaberg FE390, 66 Kawasaki B8S Super 150
Hi/low beam conversions for: Trail Tech, Baja Designs
Boatman is offline   Reply With Quote
Old 08-25-2013, 07:36 AM   #15
Peanuts
Peanuts's Avatar
Oddometer: 1,592
Does the noise change if you slowly pull in the clutch lever?
Peanuts is offline   Reply With Quote
Times are GMT -7.   It's 05:59 PM.
