Old 08-24-2013, 06:30 AM   #1
Chuckracer OP
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,111
Crash Bars *grrrr*
Anybody who has successfully re-installed these crash bars more than once and NOT stripped or cross-threaded the shit out of at least one of the front bolts is a God to me. Unbelievable. What a crappy set-up.
2005.5 KTM 950 Adventure
2005 Ducati ST3
Chuckracer is offline   Reply With Quote
Old 08-24-2013, 06:46 AM   #2
JK1
JK1's Avatar
Oddometer: 113
Leave them off simples.
Current KTM 950 Adventure S 03
Old Suzuki TS50, Aprilia Chesterfield RS125 , Honda NC30, Cagiva Elefant 750
JK1 is offline   Reply With Quote
Old 08-24-2013, 06:50 AM   #3
Chuckracer OP
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,111
I fall down too often.
2005 Ducati ST3
Old 08-24-2013, 06:51 AM   #4
Alblue
Oddometer: 35
CR,
You back on a KTM....I got a Madstad set-up for ya.
Studs in the front solve the stripping problem, not the aggravation.
Al
Alblue is offline   Reply With Quote
Old 08-24-2013, 06:55 AM   #5
Chuckracer OP
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,111
Hi Al, how'd the Madstaad set-up work for you? Yeah, as of two weeks ago I'm back on a 950 and couldn't be happier! Well, once I drill and helicoil these bolt holes and change over to a stud mount set-up.
2005 Ducati ST3
Old 08-24-2013, 06:57 AM   #6
O.C.F.RIDER
Loose nut behind h/bars
O.C.F.RIDER's Avatar
Oddometer: 4,881
Stripped one side on my 950, but only after having them off/on MANY times.
God? Not even close.
Lucky? That's more like it.
CW
http://www.theshining.info/
KTM 950 Adv. "S"...'06 KTM 525 EXC...
'76 MV Agusta 750 America S...'84 Honda VF1000...
'75 Kawi 900 Z1...'90 Kawi ZX11...'03 Kawi ZRX 1200...'01 VOR 400E
O.C.F.RIDER is offline   Reply With Quote
Old 08-24-2013, 06:57 AM   #7
gearheadE30
gearheadE30's Avatar
Oddometer: 851
Originally Posted by Alblue View Post
CR,
Al
This. Or if studs aren't readily available, buy a long bolt and cut the head off if you're in a pinch. Makes it a LOT easier. I also thread the front bolts first, then the lower tank mounts (which I have enlarged the holes on, and use a nut and washer due to tank warping) leaving everything loose, then loosely bolt the crossbar between the guards, then the rear hook things, then tighten it all down. It doesn't take too long. This is on a slightly bent SW Motech setup.
2005.5 KTM 950 Adventure and 2012 KTM 200 XC-W
1991 BMW 318is turbo track car
1989 Chevrolet Caprice Classic Wagon sleeper tow car
1992 Subaru SVX daily
3 Months Exploring the US on a 950
gearheadE30 is offline   Reply With Quote
Old 08-24-2013, 06:58 AM   #8
Chuckracer OP
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,111
Could be I'm just a hack...
2005 Ducati ST3
Old 08-24-2013, 08:17 AM   #9
Alblue
Oddometer: 35
Hack-something that hangs off the side of a Motorcycle
Never even opened the boxes! Bolted on an Aeroflow for big roads and remove for the fun roads. Just had corrado113 make me a lined bag to carry it in.
Nice to see you back in the fold
Al
Old 08-24-2013, 08:53 AM   #10
Orangecicle
Orangecicle's Avatar
Oddometer: 2,459
Chuck: http://www.advrider.com/forums/showthread.php?t=626041
Makes live very easy. I never fully take off my crashbars anymore. I just undo the frame clamp and the lower mount and then rotate the bars forward. There is enough room to then pull the faring and the tanks. Here's a good example:
We rotated the crash bars, pulled the faring and tanks, and then tuned the bike with the crashbars on. Simple.
Facebook Page: https://www.facebook.com/brad.horn.9
Orangecicle is offline   Reply With Quote
Old 08-24-2013, 09:40 AM   #11
Yellow Pig
Allergic to Asphalt!
Yellow Pig's Avatar
Oddometer: 7,369
What front fender is that? Look good.
Old 08-24-2013, 01:15 PM   #12
Orangecicle
Oddometer: 2,459
PoliSport Supermotard: http://www.ebay.com/itm/Polisport-Su...e8cff4&vxp=mtr
Old 08-24-2013, 02:38 PM   #13
EdGear
Edventurer
EdGear's Avatar
Oddometer: 553
There are several posts on putting studs by the oil tank cover.
I summarized them here
http://www.advrider.com/forums/showp...postcount=2881
If you look at the link I took a slightly different approach.
On the reinstall keep everything loose until you get every bolt/nut thread started.
Loosen the top two gas tank bolts. This allows the tanks to move up a bit to get the lower tank mount bolts through.
2010 KTM 690 Enduro R
2006 KTM 950 Adventure S
2002 KTM 400/453 EXC
EdGear is offline   Reply With Quote
Old 08-24-2013, 08:33 PM   #14
SauceSquatch
SauceSquatch's Avatar
Oddometer: 257
I was so fed up with taking off and putting on the crashbars and then I left them off for a week, sure enough I go down in the rain and narf-up my side AND my shoulder.
I actually got slightly longer bolts, ditched the clips and the reinstall has gotten much better. But still... The part of the oil change I loath.
2010 KTM 990 Adventure
2006 DRZ
1978 Harley FX cut down
SauceSquatch is offline   Reply With Quote
Old 08-25-2013, 06:34 PM   #15
Chuckracer OP
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,111
Good summary - Thanks Ed!
2005 Ducati ST3
Times are GMT -7.   It's 01:36 PM.
