Old 08-20-2013, 05:11 PM   #46
Dirtnrocks
Oddometer: 43
Acerbis tank
I fitted the 6 gal tank a few weeks ago. Its the most ill fitting tank and bag of hardware I've ever dealt with. The tank does fit down on the pucks although loosely. None of the hardware brackets fit. I was able to bend the body/seat shroud pieces enough to get the bolts in. None the front brackets came close to lining up with the holes in the tank. I fabricated my own "L" brackets for the right side that attches the tank to the coolant overflow tank bracket. I left the radiator side alone, no attachment to fuel tank, for all the reasons listed by the thread author. Tank is bolted at front on the right and the rear under the seat. Its solid and stays put. I thought about making a "tanker bracket" as mentioned but haven't gotten around to it.
Dirtnrocks is offline   Reply With Quote
Old 08-21-2013, 10:26 AM   #47
trasko
trasko's Avatar
Oddometer: 283
This is my exact experience from 4 years ago. Shitty mounting setup.
I've since drilled out and increased the size of the bolts for the main tank bolt position in the rear since the PO f-ed those up crossing-threading them 1 or 10 too many times.
The slop in the system after the years and drops tells me a bracket up front makes sense but not to the radiator. I'll fab something someday.
At least you can know that I've gone 4 years and maybe 20 good drops on it as-is and it's still going.
trasko is offline   Reply With Quote
Old 08-21-2013, 11:18 AM   #48
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Very nice job on the "transformo" build! Here is another KLR build you find interesting. Gas Guy has a different focus than you ... but still some good ideas!
http://www.advrider.com/forums/showthread.php?t=828655
Old 08-21-2013, 10:44 PM   #49
Mondo-Hondo OP
Delusional
Oddometer: 60
More Rear
That's good to know. I'd also say that whatever gets fabbed up for a tank support needs to allow the tank to float a bit. The pucks and rear mount are designed to float, and it's never a good idea to mount something with a mix of floating and rigid connections.
Thanks for the link. And I'll make GAS GUY happy and definitely update my thoughts on the wr250r. I've ridden it briefly and really liked it, but didn't get a chance to do any highway on it.
Now on to the build... I got some more done on the rack. I decided to do it the hard way (for me, anyway) and embed the aft mounting bosses into a cross tube rather than tacking them on to the side of a tube. Looks nicer, but trickier to get everything lined up. Here's a shot of turning some bosses on the old CNC Hardinge chucking lathe. If anyone's curious, the CNC control was made in 1977. It's an interesting beast to program, but does the job quite well:
And here they are in fit up:
And a few more tubes and everything welded up. I must have gotten the weld sequence correct because I tacked it on the bike (disconnected the battery just to be safe) and fully welded it off the bike. Slipped right back on like a glove.
Still need to add the turn signal bosses and then powdercoat the thing if I can find something bigger than the toaster oven I usually use to powdercoat small parts.
Everything is not enough, nothing is too much to bear. Where you've been is good and gone, all you keep's the getting there. ~Townes Van Zandt
Writing stuff -www.wiley-davis.com
Making stuff - www.hondogarage.com
Mondo-Hondo is offline   Reply With Quote
Old 08-22-2013, 07:20 AM   #50
sandalscout
blah blah blah
sandalscout's Avatar
Oddometer: 2,143
Nice work, looks great, and much nicer than the stock rack!
My KLR650
Matt's Trippin' in Peru
sandalscout is online now   Reply With Quote
Old 08-22-2013, 01:52 PM   #51
DPelletier
Oddometer: 193
nice rack! hmmm; that doesn't sound right somehow!
Dave
DPelletier is offline   Reply With Quote
Old 08-22-2013, 07:28 PM   #52
Mondo-Hondo OP
Delusional
Oddometer: 60
My riding gear
So the bike is almost done (for this trip, anyway) but what about the rider? I'd mentioned earlier that I was having trouble figuring out my pants situation. Another inmate suggested that I wear some. I'm taking that advice. But what to wear? Well, i think I've got it all figured.
Naturally, if it were just a Baja trip, I could gear up with some motocross stuff and a rain jacket and call it good. I could probably do that regardless, but where's the fun in that? So for all who never even knew they wanted to know, here is what I'm wearing (though not right at this moment):
  • Icon Stryker Rig pressure suit
  • O'neil retro jersey (because it's wonderfully obnoxious and has lots of holes in it)
  • Aerostitch Fallstaff jacket I bought from the ADV flea market
  • Klim tactical pants
  • Filson Double Tin work pants
  • Some O'neil motocross boots that I bought to race the San Felipe 250 a couple of years ago (something of a lark…on a bone stock Yamaha Blaster quad, no less)
  • Gmax dual sport helmet (cheap and I haven't had any snap issues like some)
  • I've got some mesh gloves but need to figure something out for cooler days
I love the icon pressure suit. It's not too hot, easy on/off and isn't terribly bulky.
The aerostitch and the filsons are an experiment. I like the look. And I figure if it doesn't work out I can sell the jacket and use the pants around the shop in the winter.
I took the armor out of the jacket and pretty much always wear the stryker and a jersey. When it's not hot or I'm on the highway I'll throw the jacket on over that.
Any recommendations for some knee pads that don't have shin guards built in?
Old 08-23-2013, 10:09 AM   #53
DPelletier
Oddometer: 193
No, but some of the cheaper sets are very thin. Having trouble fitting them in your boots? I would worry that the knee pad would move off my knee after first contact without the shinguard in the boot holding it in place.
...I know, I didn't answer your question.
Dave
Old 08-23-2013, 10:55 AM   #54
Mondo-Hondo OP
Delusional
Oddometer: 60
Dave
I can probably make them work inside the boot. Gets a bit tight with the pants in there as well. I've never used kneepads before. But if that's how they're supposed to work then I'll give the long ones another chance.
Old 08-23-2013, 11:50 AM   #55
Adv Grifter
Oddometer: 6,128
Isn't it just a "Baja Trip"? Are you crossing to the mainland and heading further South? Different considerations in that case. If going as far as S. America ... then things really change.
Seems to me you've chosen some great items ... and you've thought it out very well.
If the pressure suit works, they offer great protection. Too hot for me. I'm assuming it's the TOP only?
The KLIM pants should be good in heat. I like padded shorts under and knee pads. Stock foam on most is crap. I replaced with the good stuff. I wear regular Moto style pants (nearly identical to KLIM) and in cold just slip a pair of inexpensive rain pants over them. Works good (cuts wind) down into low 50's. Colder than that, you'll need to layer up. Hot weather base gear helps both in hot and cold.
The Falstaff is great if you have room to stow it for hot weather. That is what I did. With all armor out it should roll up fairly small. Life saver at night or cold/rain.
Knee pads are personal. I've custom made mine, starting with standard Moto knee pads, replacing crap foam with high quality impact foam. I retained the plastic shell and strap, just relined inside with better foam. Mine DO have shin guards and tuck into boot tops. Comfy. (I have one Titanium leg... must protect shin)
Not familiar with Filsons. I assume it's One or the other? I'd go with Klim pants ... and just have something to put on over them. (rainpants). Be sure to pack a pair of walking shorts ... or better yet ... nice no wrinkle pants. Ever notice Mexican men don't wear shorts in "real" Mexico?
Don't be a Gringo mark ... wear long pants whenever possible. Fit in, look respectable. Shorts are for the beach only ... and women.
I've done several Baja runs since 2006. Two of these trips crossed over to Mainland Mexico as well. We didn't do super technical Baja routes, but several sections of the old Baja 1000 course, stopping and moteling along the way (Ensenada, Bahia de Los Angeles, San Franciscito, San Ignacio, Mulege', Loreto, Scorpion Bay, La Paz, Los Cabos)
Surfing.
I first Surfed Baja as a kid late 60's. We loaded our Honda 50's in the Van with the boards! There are a few Ride Reports where guys carried "real" boards on the bike. Might be a possibility? Not sure an inflatable board is ideal?
http://en.wordpress.com/tag/surf-baja/
Good luck, have a safe trip! Surf should be coming up in October or so.
Old 08-23-2013, 12:42 PM   #56
Mondo-Hondo OP
Delusional
Oddometer: 60
A south America trip is definitely in the future. I've spent several months backpacking and hitchhiking down there. Told myself the entire time I should have had a motorcycle or a bicycle :) But I meant that this particular trip is more than just Baja because me and the bike live in Bozeman, Montana so I'll be riding the bike down to San Diego to meet up with my friend there before heading into Mexico. Said friend is letting me store my bike in San Diego and we plan on doing 3 or 4 short trips this winter. But the ride down will be something of an adventure as well. I've decide to take as much as possible of the UTBDR down. I'd like to do the whole thing but I've only got 6 days to get to San Diego, so we'll see. I make no promises other than to give it a healthy go. I get kind of bored if I'm not riding at least ten hours a day, and I love night riding (this holds true on long mountain bike and road bike tours anyway), so maybe it's possible. It always seems we roll into a camp at six in the evening, eat and then get a second wind, saying you know, why not get a few more hours in? I'll cut over somewhere near I-40 and over into Joshua Tree then down through Indio and S22 over through Borrego Springs (final destination is actually Anza). So if anyone has recommendations for the bottom of the UTBDR over to Salton Sea, I'm all ears.
It's just a top but it has the elbow pads as well (not just a vest). I like the heat so I can get away with it. With a vented jersey over it and a t-shirt under I feel comfortable in 90ish-degrees (dry heat, hottest we've had up here) while moving.
The Klims are just the padded underpants. The Filsons are heavy-duty waxed cotton work pants which i wear over the Klims. I have some motocross pants in San Diego which I might bring with to baja, but the Filsons are water resistant. As for shorts, I only wear them in the water or on a bicycle.
Surfing.
Baja is my favorite place on the planet. I've driven all over it but have only ridden motorcycles in and around San Felipe. So I'm really looking forward to being able to explore it by motorcycle. As for the surfing, yeah, the inflatable isn't ideal, but rolls up into checkable luggage size...not bad for a 10' board. Saying it's got a soft rail would be generous, but they're still fun. We use them on whitewater up here. I do have a fish in San Diego which would be suitable for a rack carry. Planning a moto surf trip to Scorpion Bay in December so maybe I'll have to to make a board rack.
Old 08-23-2013, 01:20 PM   #57
Adv Grifter
Oddometer: 6,128
If you're a bicycle guy then your fitness will be tip top! ... and dealing with heat should not be a problem!
Temps in Baja on the Gulf side will be over 100 until maybe mid October. This varies year to year. Can sometimes stay HOT into November. Other times, cools down by Oct. 1st. So who knows? I've been snowed on in and around Mike's Sky Ranch twice in ... MARCH! But temps are usually good in November further South.
You may luck out and find a Gringo who will sell you a board down there. Lots of those SoCal boys bring more than one board down ... or just borrow it?
Old 08-23-2013, 11:41 PM   #58
RandoCommando
Wannabe
RandoCommando's Avatar
Oddometer: 1,394
I have military knee pads that don't have shin guards attached.
1999 KLR 650 (her name is KLaRissa) DOOHICKEY DONE!
2013 BMW F800GS (her name is FranGelicaS)
Please. Ride careful, ride safe, ride defensively! This thread should be mandatory reading!
MySPOT
RandoCommando is offline   Reply With Quote
Old 08-24-2013, 09:49 AM   #59
Kawidad
Kawidad's Avatar
Oddometer: 4,755
Check out the old Mormon trail through the Nevada wildlife refuge. It crosses the southern part of the state, so in theory you can cross the southern part of Nevada without more than crossing pavement. If you're creative, you can bypass Lost Wages via dirt power line roads, cross into Commiefornia around Primm. Then around Primm, you get into the Mojave Reserve there are power line roads and Jeep roads that will take you the direction you want to go.
Quis custodiet ipsos custodes? - Juvenal
(Who watches the watchers)
Kawidad is offline   Reply With Quote
Old 08-26-2013, 08:02 AM   #60
Mondo-Hondo OP
Delusional
Oddometer: 60
Route Planning Bozeman to San Diego
So I'll be jumping on to the GDR south of Bozeman near Henry's Lake into Wyoming, then I've got a cut across from pinedale to bear Lake to pick up the UTBDR. From there I need to get to St George to visit some family, then over into Nevada/California to Anza.
I'm looking for route suggestions between the end of the UTBDR and St. George, and St George to Anza.
On the map below, the green path near the top is the GDR. The purple segment is my Google-Earth-derived connection between the GDR and the UTBDR. It looks rideable but if anyone knows otherwise, I'd love to hear about it. The red segment at the bottom is all road. If there's a more entertaining way to do that section, again, let me know.
Mondo-Hondo screwed with this post 08-26-2013 at 08:11 AM
Times are GMT -7.   It's 07:47 PM.
