Old 08-24-2013, 08:07 AM   #1
skandero OP
skandero's Avatar
Oddometer: 125
headlight problem(
Hi there!
I've got another problem on my ADV950: headlight is almost dead.
So, the situation is:
1) when I turn the key, both high/low beams are dead. No reaction on button.
2) when I press and hold the bypass light button, the high beam is activated as usual. Low beam is dead.
3) When I switch the main light button to "high beam" position, both high and low beam lights are activaded!
Shit. The fuse is good, tried to replace - no reaction. The wiring loom looks completely undamaged. Where should I search the problem. Looks like it's not a short circuit... Relay unit?
I have not enough equipment now, so, I'll be glad to get ideas for diagnostics of Tuesday.
skandero screwed with this post 08-24-2013 at 08:23 PM
skandero is offline   Reply With Quote
Old 08-24-2013, 08:32 AM   #2
6732cash
6732cash's Avatar
Oddometer: 163
Your not mistaking the low beam for the parking light.....in which case it could just be the dip beam bulb is blown
6732cash is offline   Reply With Quote
Old 08-24-2013, 09:49 AM   #3
skandero OP
skandero's Avatar
Oddometer: 125
No, the head lights are dead.
Old 08-24-2013, 11:31 AM   #4
Boatman
Upward and onward!!
Boatman's Avatar
Oddometer: 10,459
Possible you have a broken filament inside the bulb and it's shorting the hi/lo together. My next step would be to test the feed with a test light at the bulb connector.
08 KTM 950 SE, 09 KTM 950 SE, 04 KTM 950 ADV, 10 Husaberg FE390, 66 Kawasaki B8S Super 150
Hi/low beam conversions for: Trail Tech, Baja Designs
Boatman is offline   Reply With Quote
Old 08-24-2013, 08:28 PM   #5
skandero OP
skandero's Avatar
Oddometer: 125
But how can it be possible? The hi/low bulbs are separated and there is one thread in each bulb... And both bulbs are working, when the bypass trigger and hi beam switch are activated togeter...
Solution is:
Dirt in the off/parking/drive light switch. Driving light position was corroded and covered with dust after last offroad ride. Simple solution.
skandero screwed with this post 08-24-2013 at 10:41 PM
Old 08-25-2013, 05:01 AM   #6
Boatman
Upward and onward!!
Boatman's Avatar
Oddometer: 10,459
Solution is:
Missed that you aren't in the US. Our headlight is different and uses a dual filament H4 single bulb.
Glad you got it sorted out.
Times are GMT -7.   It's 09:34 PM.
