Old 08-26-2013, 04:31 PM   #916
kentnothstine
kentnothstine's Avatar
Oddometer: 615
Originally Posted by RoadRdr View Post
I have the tool and the stand I plan to use for the fairly small training motorcycles but it didn't occur to me until I was looking at my rear tire on my BMW GSA with the large center hole... I don't know how i can use this tool on my beemer.
Has anyone that bought the tool used it on the rear wheel of a BMW?
I don't have access to be able to weld or machine any kind of adapter.
I think I saw somebody make an adapter out of PVC pipe
2008 XT250(the new one for her to use)
2003 KLX400SR (the new one)
1997 Ural 650cc (SOLD)
Originally Posted by Thanantos View Post
Once your crotch gets wet it's all over.
kentnothstine is offline   Reply With Quote
Old 08-26-2013, 04:43 PM   #917
PineyMountainRacing
Oops....
PineyMountainRacing's Avatar
Oddometer: 2,399
Whatever you use for a shim doesn't have to be metal or be permanently attached to the tool. Put up a pic of your hub, I've never ridden a BMW, or paid any attention to what the hub looks like.
PineyMountainRacing is online now   Reply With Quote
Old 08-27-2013, 11:27 AM   #918
EvanADV
Big Bearded Boy
EvanADV's Avatar
Oddometer: 1,337
Here: http://advrider.com/forums/showpost....&postcount=883
Current Steed: '08 FJR1300
9 states left to ride: WI, MN, ND, SD, UT, OK, KS, AK, and HI.
EvanADV is offline   Reply With Quote
Old 08-27-2013, 07:28 PM   #919
RoadRdr
Mostly Pavement
RoadRdr's Avatar
Oddometer: 221
Originally Posted by EvanADV View Post
Thank you. That gives me a place to start. I don't have the Parnes balancing tool but that adapter looks like it will provide a solid pivot point for the mounting tool.
Thanks.
2012 BMW R1200GS Adventure - 2014 Honda Grom
RoadRdr is offline   Reply With Quote
Old 08-28-2013, 05:12 AM   #920
Speedo66
Transient
Oddometer: 6,815
Have had the tool for a couple of months, and finally got to use it last week. Two new Shinko 244's with tubes on my XT225, and a flat tube replacement on my W650.
With lube and tires irons, removal was the usual PIA, same for breaking the beads. Had to put a piece of board on the tire and run over it with my car to break the bead.
Installation was a breeze though, much easier than usual. The W rear tire had a really stiff sidewall, but pushing the opposite side down into the rim allowed the tool to do its work very nicely.
I worked on 2 pieces of 2x6 to protect the front disc and rear sprocket, this also allowed the tool to drop all the way down. The design of the tool pretty much eliminates pinching a tube. Once I got one side back on, I inserted the tube, partially inflated it, and bounced the whole wheel/tire assembly on the ground a number of times to loosen any tube folds, I do the same when both sides are on before full inflation.
When I first bought the tool I agonized a little over the price, but I'm now convinced it was money well spent. In my mid 60's, this gives me the extra edge I need to keep doing my own tire changes.
Oh I used to be disgusted, but now I try to be amused-E.Costello
'01 Kawasaki W650, '05 Yamaha XT225
Speedo66 screwed with this post 08-28-2013 at 05:20 AM
Speedo66 is offline   Reply With Quote
Old 09-24-2013, 12:41 PM   #921
JustRon
ex-broadwayron
JustRon's Avatar
Oddometer: 1,275
I changed my rear tire last wknd, and the tool fit my axle perfectly (no shim needed, like for my front). I had to show someone at my garage how easy it is, because it really looks like magic... took less than 2 minutes to seat the bead.*
*It should be noted that it took me over an hour to get to the starting point- one bead inside the rim, and one bead outside. I've seen people do this online using their hands, and it takes 30 seconds. I had soap on the bead and was using all my body weight (jumping on the thing!), spoons, whatever. It actually took 2 of us using a freaking No-Mar Changer just to get one bead over the rim! The sidewall is ridiculously stiff (Motoz Tractionator)- I could probably ride with 3 psi if I wanted. My friend couldn't believe I wanted to remove the tire from the No-Mar to finish the job, but when he saw how fast it was, he was shocked. I just need to figure out how to get started... the easy part of changing a tire.
2010 Beta 520RR
Baja crash Report
JustRon is offline   Reply With Quote
Old 09-24-2013, 02:45 PM   #922
Speedo66
Transient
Oddometer: 6,815
I used the tool to put the first bead on also, worked fine. Did you try it?
Old 09-24-2013, 02:59 PM   #923
JustRon
ex-broadwayron
JustRon's Avatar
Oddometer: 1,275
Honestly, I didn't even try it. I can't picture how that would work, though.
2010 Beta 520RR
Baja crash Report
Old 09-24-2013, 03:04 PM   #924
PineyMountainRacing
Oops....
Oddometer: 2,399
Putting the first bead over is the best part of the Tyre Tool. You don't have to try and lever it on where the 2nd bead gets in the way. The tool just pushes it to the edge and the bead falls over.
Old 09-24-2013, 03:14 PM   #925
Speedo66
Transient
Oddometer: 6,815
What I usually do is stand the tire up on the ground, lube it, and jam one edge of the wheel rim into the hole as hard as I can. It hits the bottom of the tire/bead, and stays there. Put the wheel down, and push the rest of the tire over the rim. I used to use tire irons. Now, do the same, but use the tool. It really worked fine, it's doing the exact same thing to the lower bead as it does with the upper bead, except it's easier.
Old 09-25-2013, 07:06 AM   #926
JustRon
ex-broadwayron
JustRon's Avatar
Oddometer: 1,275
None of my bikes need a tire change for a while (I think/hope), but next time, I'll come back to this thread as a reminder.
I couldn't do that... sidewalls were too stiff. I had the edges lubed, and the tire flat on the ground. I put the rim on top of the tire and tried to push it into the tire... that's worked for me before. Not this time- not even close.
The rimlock didn't make things easier, either. Heh, my friend asked if the tire was the right size for the rim.
2010 Beta 520RR
Baja crash Report
Old 11-20-2013, 08:05 AM   #927
Xeraux
Archvillain
Xeraux's Avatar
Oddometer: 30,892
From the same website...
Every saint has a past and every sinner has a future.
If, after I depart this vale, you ever remember me and have thought to please my ghost, forgive some sinner and wink your eye at some homely girl.
Xeraux is offline   Reply With Quote
Old 11-21-2013, 09:17 AM   #928
vintagespeed
fNg
vintagespeed's Avatar
Oddometer: 1,761
neat!
has anyone mounted up paddle tires with this tool? particularly small diameter paddles, like 14"?
i mount up knobs no problemo (usually...) but this looks like a really cool tool! and at $20 per tire to have the shop do it, would pay for itself in a few seasons, and a few saved toobs!
530EXCR and a bunch of 2 strokes that you dont want to read about. :)
TAT-2013: http://www.advrider.com/forums/showthread.php?t=913898
SoCal_NoDak-2012: http://www.advrider.com/forums/showthread.php?t=829203
vintagespeed is offline   Reply With Quote
Old 11-27-2013, 05:54 AM   #929
GlennR
Playin' in the Fire
GlennR's Avatar
Oddometer: 2,167
How do I "get on the list" for the next order?
GlennR is offline   Reply With Quote
Old 11-27-2013, 06:01 AM   #930
PineyMountainRacing
Oops....
Oddometer: 2,399
Glenn, there is a thread under Vender section started by EvanADV. Check that out.
Times are GMT -7.   It's 10:06 AM.
