Old 08-31-2013, 07:42 AM   #181
LasseNC OP
XSessive!
LasseNC's Avatar
Oddometer: 1,072
What do you guys think? Ride height is taller than I initially wanted, but it is the lowest I can go, while still maintaining 95mm shock travel and then a small amount of clearance extra.
Old 08-31-2013, 08:02 AM   #182
joexr
Oddometer: 3,773
You need to see where your steering rake is. RD's already handle well. If you steepen the steering head angle much you'll end up with twitchy steering.
Old 08-31-2013, 08:13 AM   #183
sprouty115
sprouty115's Avatar
Oddometer: 1,585
Was thinking the same thing. See if you can get a rough estimate and compare it to the stock setup.
sprouty115 is offline   Reply With Quote
Old 08-31-2013, 10:11 AM   #184
LasseNC OP
XSessive!
LasseNC's Avatar
Oddometer: 1,072
I'll ride it and see if I like it :)
Old 09-01-2013, 07:31 AM   #185
LasseNC OP
XSessive!
LasseNC's Avatar
Oddometer: 1,072
Dropping frame off at the welders in a few minutes :)
Today I made a bracket for the licenseplate and taillight. Might be too much for the tail vibrationwise.
Need bushes, exhaust and airfilter mainly. Then I am on the road atleast :)
This conversion went easier than I anticipated.
Old 09-01-2013, 09:31 AM   #186
Twin-shocker
Oddometer: 1,673
By the look of it your bike will handle very poorly, the CG is about 50mm too high, the steering angle is too steep, and the rear suspension squat geometry is far from ideal.
The stock TS bikes handle relatively well, so wonder why there is a need to make modifications that will mean its not as good as stock?
Old 09-01-2013, 09:36 AM   #187
LasseNC OP
XSessive!
LasseNC's Avatar
Oddometer: 1,072
It's a common modification, it works.
Old 09-01-2013, 11:05 AM   #188
Twin-shocker
Oddometer: 1,673
Ok.................but wonder if it might not work better by fitting more modern front end, and some quality rear shocks
Old 09-07-2013, 08:46 PM   #189
Lisa-Isabella
70's Girl
Lisa-Isabella's Avatar
Oddometer: 16
Thank you boys for a most enlightening thread I have benefited from your links and ideas for my 350 build, but I better start my own thread
Lisa-Isabella screwed with this post 09-08-2013 at 12:40 AM
Lisa-Isabella is offline   Reply With Quote
Old 09-15-2013, 01:43 PM   #190
LasseNC OP
XSessive!
LasseNC's Avatar
Oddometer: 1,072
The monoshocking is drawing out. I am changing the framerails so I can place the bike lower.
So attention has changed to wheels. Here is a set of aluminium rims!
Old 09-16-2013, 07:34 PM   #191
Lisa-Isabella
70's Girl
Oddometer: 16
You are so funny Lasse
You change direction more often than the wind ...... I mean that in the nicest loving way .......... It's like you are building 10 bikes and I am loving every minute of it
With my 350 build, I'm promising myself to just follow one course, one direction. Problem is I can't decide which direction to go ........
Old 09-17-2013, 04:49 AM   #192
JonnyCash
turd polisher
Oddometer: 1,616
Better clean up that sink before mama finds out what you've been doing!
I wouldn't bring her home to Mama, but Mama ain't home tonight.
JonnyCash is offline   Reply With Quote
Old 10-06-2013, 09:19 AM   #193
LasseNC OP
XSessive!
LasseNC's Avatar
Oddometer: 1,072
The aluminium rims didn't work. They were made for 1 cross, while the RD has two crosses. So the contact point of the nipple would be too far off.
I moved most of the bike the 100km to my new home today.
Trying to mock up the new location for the rearshock. Adding 25mm. when it is on the mainstand, so that the wheel will clear the ground. Found another guy to weld my frame. I'll take it to him on tuesday I think and see what he can come up with.
Old 10-13-2013, 08:40 AM   #194
LasseNC OP
XSessive!
LasseNC's Avatar
Oddometer: 1,072
Old 10-18-2013, 10:44 AM   #195
LasseNC OP
XSessive!
LasseNC's Avatar
Oddometer: 1,072
Times are GMT -7.   It's 11:57 PM.
