Closed Thread
Old 08-30-2013, 01:08 PM   #3451
Fuse
Fuse's Avatar
Oddometer: 13
Ordered mine yesterday. Will be happy to write a report a soon as I can. It will be installed on a 2012 R1200GS.
Thanks to everyone who's part of this.
Got beer?
Fuse is offline
Old 08-30-2013, 01:30 PM   #3452
Carlo Muro
Supercàzzola
Carlo Muro's Avatar
Oddometer: 2,130
Originally Posted by luckygrownup View Post
Would this device help with low rpm remapping ? My 2013 R1200 GSA seems to run to rich and occasionally stalls out when slowing down to a stop. It also pops when cool. I use 93 Octane fuel and ride at sea level. I want a leaner fuel remap on my GSA. Would this do it ? I also want the flexibly to clear the real map in case I ride in higher elevations. My bike always seemed to ride too rich right from the day I bought it with 13 miles. I have 8000 miles on my bike and commute on it 1/2 the time.
I'm not the expert in this thread so take this with a grain of salt.
I've never seen a stock GS run too rich. There might be something else wrong with the bike. FWIW I've ridden my stock '07 through Leadville, CO with no noticeable degradation in performance. You can get higher than that in North America but it's not easy. If it were ever going to run rich it would have done it there.
Carlo Muro is offline
Old 08-31-2013, 07:47 AM   #3453
ericm
Oddometer: 419
Popping and stalling is due to being too lean. Some cycles are too lean for complete combustion, which leaves unburnt hydrocabons in the exhaust. They accumulate and ignite, causing the pop.
The ICE air does not change the map. It only modifies the input to the ECU to get it to use a slightly richer part of the map on transient throttle. This is covered in the links.
If you are using gas with ethanol, try using E0 gas with no ethanol. Ethanol requires more air, which makes the engine run lean. Not all engines compensate fully for it.
Also try 91 octane. GSes run on it in states like California which do not have 93 octane. It will have a bit more energy per liter than 93. If you get detonation, then you would need to switch back to 93. But since GSes are tuned for the swill that passes for gasoline here in California, it should not be a problem. But switching to E0 would be more important for addressing your lean running symptoms.
Modern fuel injected engines compensate for altitude. They don't run rich like a carbureted engine.
ericm is offline
Old 08-31-2013, 01:58 PM   #3454
TommyHolly
Teaparty member
TommyHolly's Avatar
Oddometer: 215
Can you run 87 Octane in the R1200GS?
"When the debate is lost, slander becomes the tool of the loser." - Socrates
"Everyone is entitled to his own opinion but not his own facts." - Daniel Patrick Moynihan
TommyHolly is offline
Old 08-31-2013, 03:39 PM   #3455
Daz the Aussie
Dualsporting Actor
Daz the Aussie's Avatar
Oddometer: 947
So Poolside, how are the "Aiming for ship dates in August" orders coming along? In the last August mail today perhaps?
"We need a new thread for fuel tank capacity bitching." - Super Sneaky Steve
"Where do I go now that I've gone too far?"
My actor site: www.dazbyard.com
Daz the Aussie is online now
Old 09-01-2013, 02:58 PM   #3456
Ayrshire Bull
why the hell not?
Ayrshire Bull's Avatar
Oddometer: 2,593
depends - what oil are you using?
"It's not what you look at that matters, it's what you see." - HDT
Ayrshire Bull is offline
Old 09-01-2013, 04:10 PM   #3457
slowoldguy
Tire Tester
slowoldguy's Avatar
Oddometer: 8,609
lol
RTB V- The Texas ADV Rally- Hurry before we fuck this up!
http://www.rollthebonesrally.com/
"If you can't fix it with a hammer you can damn sure teach it a lesson".
slowoldguy is offline
Old 09-01-2013, 09:11 PM   #3458
SeaBass
SeaBass's Avatar
Oddometer: 1,036
Inquiring minds want to know
SeaBass is offline
Old 09-03-2013, 05:21 AM   #3459
TommyHolly
Teaparty member
TommyHolly's Avatar
Oddometer: 215
Originally Posted by slowoldguy View Post
lol
I'm asking because the ICE-Air was able to change the mixture enough that the guy with the fuel chart was able to run 87 octane? He never mentioned what year his bike was in the test. I'm not sure if older versions used 87 in the past?
Old 09-03-2013, 05:29 PM   #3460
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,878
I posted up some news about that in the Vendor thread.
IICE Air Hotrod your GS  Fuel Injection  Tech Info  Buy  Order List  Installation
Poolside screwed with this post 09-04-2013 at 12:56 AM
Poolside is offline
Old 09-04-2013, 07:16 AM   #3461
ericm
Oddometer: 419
I don't know of any BMWs that were spec'd to run on 87. Maybe some of the detuned low compression airheads, but my '77 R100RS needed to be dual plugged to run on 91.
My 1999 1150GS would ping on 91.
ericm is offline
Old 09-04-2013, 02:15 PM   #3462
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,878
Originally Posted by ericm View Post
Popping and stalling is due to being too lean. Some cycles are too lean for complete combustion, which leaves unburnt hydrocarbons in the exhaust. They accumulate and ignite, causing the pop.
The IICE air does not change the map. It only modifies the input to the ECU to get it to use a slightly richer part of the map on transient throttle. This is covered in the links.
Thanks for chiming in fellas, and here's my two cents, luckygrownup.
As Carlo said, the boxer motor isn't operated at what you would call a rich mixture anywhere in the operational range. Eric is on the track too. Exhaust popping for the boxer and Motronic combination is caused by the mixture swinging too lean to combust. The unburned oxygen and fuel gets ignited with-a-pop during the next exhaust stroke.
And a slight adjustment to Eric's comment. The IICE Air richens up the mixture during leading throttle acceleration, and pays small dividends during transient throttle. The big increase to transient throttle enrichment is from the IICE Cool.
Poolside is offline
Old 09-04-2013, 02:33 PM   #3463
Wallowa
Oddometer: 5,366
Did I Miss The Launch? Is the IICE Cool On Sale?
Did I miss the release and sale of the IICE Cool? Or is this a "tease"..
"In Wallowas"
2007 R1200GS Adventure " ...to explore off-road, alone in my case, way out in the boonies...that feeds the soul!" After 2014 BOM my bike is forthwith the "GS McGee"!
Wallowa is offline
Old 09-04-2013, 04:37 PM   #3464
YetiGS
No Talent Ass Clown
YetiGS's Avatar
Oddometer: 7,418
+1
-Scott- MotoGearGrinder.com
Semper Fi
YetiGS is offline
Old 09-05-2013, 10:44 AM   #3465
bracky72
Oddometer: 953
You guys didn't get yours yet? There was a big "cool" sale last month! Oh the power!
J/k
bracky72 is offline
Closed Thread
Times are GMT -7.   It's 03:38 PM.
