Go Back   ADVrider > Riding > Regional forums > Pacific Northwet - Where it's green. And wet.
Old 09-04-2013, 12:01 PM   #9736
Mr. Fisherman
PROUD 2B Riff Raff!
Mr. Fisherman's Avatar
Oddometer: 10,755
Originally Posted by peterman View Post
Turkey pot pie,or
Beef Strokamoff
it's what's for dinner!
Bet it isn't as good as it was in Timber.... just sayin'
Mr. Fisherman is offline   Reply With Quote
Old 09-05-2013, 08:17 AM   #9737
DireWolf
Knees in the Breeze
DireWolf's Avatar
Oddometer: 13,275
shoulda come to the pasture picnic,,lots of food and nobody fell down.
At least not on a bike.
DireWolf is offline   Reply With Quote
Old 09-05-2013, 08:55 AM   #9738
pHelix
Eternal n00b
pHelix's Avatar
Oddometer: 1,254
A very enjoyable meetup last night. I took the opportunity to regale the crowd with my story of Linkweewee's spill in glorious detail and technicolor.
Too bad Linky wasn't there to defend hisself.
Kevin
We are not alone. There is ALWAYS someone downstream and downwind.
pHelix is offline   Reply With Quote
Old 09-05-2013, 12:25 PM   #9739
tblume
deus ex machina
tblume's Avatar
Oddometer: 2,178
Saddest part is his last payment is next month..
We were looking at the next bike he'll crash if this one is totalled; st3 Duc, 1050 Sprint, or another speeeeed trippa.
And yesterday I had the pleasure of riding my buddies BRAND NEW black on black, no stuckers KLR that he just bought...
Maps? We don't need no steenkin maps. They're alley's fer crysakes. You'll find them between the main streets. Find one, ride it til you can't, move over and grab another one. Repeat as needed.
OMB
tblume is offline   Reply With Quote
Old 09-05-2013, 02:24 PM   #9740
RideAbout
Mentally Retired
RideAbout's Avatar
Oddometer: 1,719
30mph lowside = total loss?
Ed did a lip-skid up and over the length of a mini-van....everything buffed right out.... sort of.
We livin' in a throw away society I tells ya!
West - "Oeste Sanchez"
RideAbout is offline   Reply With Quote
Old 09-05-2013, 03:34 PM   #9741
tblume
deus ex machina
tblume's Avatar
Oddometer: 2,178
Agreed; I could be wrong but there's damage to the left side front and rear- tail is tweeked by pannier rack, tank dented, exhaust dented, headlightassy, windscreen, blahblahblah.
7 years old
Mysterious way slacked chain
Mysterious empty clutch fluid
Almost paid off
Write off IMHO$00.2...
It'll make a bitchin' flat tracker once it's naked though... DIBS!
OMB
Old 09-06-2013, 05:17 PM   #9742
linkweewee
tantum quantum
linkweewee's Avatar
Oddometer: 14,149
The mechanic at Cycle Parts told me yesterday that besides the rashed-up expensive front end bits, the bent muffler
and destroyed Happy Trails rack and bag, bent Givi crash bar and destroyed Cee Bailey's wind screen, that the bike pointing front wheel down in the ditch and running for @ a minute before stalling means no oil to the cylinders while running.
this interests me as the owner is a Ducati knowledgista
http://eugene.craigslist.org/mcy/3991991736.html
Life is hard. It's harder if you're stupid.
-John Wayne
linkweewee screwed with this post 09-06-2013 at 05:25 PM
linkweewee is offline   Reply With Quote
Old 09-06-2013, 06:10 PM   #9743
what broke now
Petroleum Brother
Oddometer: 1,395
That's a nice price if it has been taken care of. Lots of thrill in the st line. You'd be down the rabbit hole a bit compared to Japanese maintenance, but they can be barrels of fun.
what broke now is offline   Reply With Quote
Old 09-07-2013, 05:53 PM   #9744
Dansrc51
I need a cape....
Dansrc51's Avatar
Oddometer: 1,590
Need some input. Here's a shot of the fork that was leaking
as you can see, there is a spot that has been rubbed into the fork tube. There doesn't seem to be any roughness to the fork and it slides well. I tried Peter's suggestion and worked some 400 grit paper under the seal to clean and rough it up and there doesn't seem to be any more leakage. I pumped the fork multiple times and it looked ok....
So what now? Can I fill the fork oil without removing it from the triple? I'm sure it needs to be topped off. Should I change the fluid on both tubes? (got the maint. dvd so I could figure it out).
Also, now that I have the tire off, how best to fix the dented rim? I wacked on a it a few times with a rubber mallet, but I think I'll need to remove the tire and place it on a work bench. Taking suggestions here.
Lastly, the brakes have been nothing but sponge. On closer inspection, one side is completely worn and the other is like new. Could it be the fork fluid was on the pad? Maybe a bubble in the line?
Thanks for letting me pick ya'lls brains.
hi-brow, low wit
Dansrc51 is online now   Reply With Quote
Old 09-07-2013, 08:05 PM   #9745
linkweewee
tantum quantum
linkweewee's Avatar
Oddometer: 14,149
Ask Peter if he can heat up the rim with a welding torch and bang it back into shape. Assuming it's an alloy rim, that may or may not work...
-John Wayne
Old 09-08-2013, 07:37 AM   #9746
*REGO*
Commited Adventurer
*REGO*'s Avatar
Oddometer: 99
[QUOTE=Dansrc51;22277362]Need some input. Here's a shot of the fork that was leaking
Following the discussion above, and the mangled bolt on the brake caliper shown on one of the pictures, I suggest a new bike is in order.
OK. Good thing you have the maintenance manual. Sound like the brakes need to be flushed/cleaned out, pins/guide shims checked and new pads. Sound like they were sticking and not self aligning with wear. If the forks leaked, and you put abrasives under the seal, they should come out too for a cleaning and rebuild, or you are just going to get more of the same in a short time. Wheels are tough to beat true, but some repair can be made. I have had best luck with a two guy effort. With the wheel off the bike, the tire removed, the rim laid flat on 2 by 4 wooden blocks (in an attempt now to scratch the bottom side and not dent the disk) guy one holds another 2 by 4 on the bent section and guy two wails away with a 8lb sledge hammer. I have tried to place wood block where the tire should be to reduce over adjustment and to keep the good adjacent rim from moving too much. There are people who do this well for a living, but they want $. Good Luck. If you need help, I am willing, and I have a shop.
"obstacles are those frightful things you see when you take your eyes off your goal."- Henry Ford
*REGO* is offline   Reply With Quote
Old 09-08-2013, 09:42 AM   #9747
YamaGeek
Ancient trailbike padwan
YamaGeek's Avatar
Oddometer: 6,293
Just from this lowly bicycle mechanic's perspective, the rim is better off being replaced.
Aluminum alloy doesn't become malleable with application of heat, and because aluminum is very conductive of heat any localized area application will soon just heat the entire rim.
You can always try to 'bang' it back into shape but that part of the rim will be work-hardened and subject to stress cracks if it doesn't fracture when being reformed. I'd use a hydraulic press to gently press the dent back in, but it will always have a hop in that spot that will be impossible to true out with spoke tension.
The brake issue sounds like a stuck piston which may or may not require the caliper to be replaced.
We're here because of a love most exestential. (toothy)
YamaGeek is offline   Reply With Quote
Old 09-08-2013, 10:29 AM   #9748
tblume
deus ex machina
tblume's Avatar
Oddometer: 2,178
You wanted a winter project, yes?
Tear down the front end, rebuild the fork with new seals and stuff- can they be tuned to you?
Rebuild the calipers- no need to replace them.
New rim and re-used spokes/hub etc- fab a fixture for truing and balancing (I have some ideas there)
Throw some rain tires on the Honda for the commute though...
OMB
Old 09-08-2013, 10:36 AM   #9749
MortimerSickle
Semi-Adventurer
MortimerSickle's Avatar
Oddometer: 12,317
...fab a fixture for truing and balancing...
http://www.harborfreight.com/motorcy...and-98488.html
And, you can always get at least 25% off.
I miss round headlights.
"When I was a young man, I liked to race my horse...." -
G.H.W.S. 1878-1962
MortimerSickle is offline   Reply With Quote
Old 09-08-2013, 12:28 PM   #9750
tblume
deus ex machina
tblume's Avatar
Oddometer: 2,178
Been using that one (thanks kevin) but its, uh, ..tolerance... for runout is iffy, and the cones are sloppy and the original shaft was bent, and blahbibbityblah...
I'm thinking of a precision machined shaft with acme threaded cones and some kind of single point spindle, but it's idea phase now.
OMB
Times are GMT -7.   It's 09:34 PM.
