Old 09-08-2013, 04:27 AM   #2116
johnny80s
johnny80s's Avatar
Oddometer: 267
I poured a concrete pad for my no-mar tire changer.
johnny80s is offline   Reply With Quote
Old 09-08-2013, 05:58 AM   #2117
ClearwaterBMW
The Examiner
ClearwaterBMW's Avatar
Oddometer: 5,972
may we please see a picture?
Greg
'11 R1200 GS Adventure with a DMC M72DX Sidecar
'14 R1200 GS & '14 R nineT (march, 2014)
Live life like you mean it... but take your family and friends (and DOGS) along for the "ride"
ClearwaterBMW is online now   Reply With Quote
Old 09-08-2013, 06:18 AM   #2118
johnny80s
johnny80s's Avatar
Oddometer: 267
Looks like this.
Old 09-08-2013, 06:44 AM   #2119
teomannaskali
Oddometer: 763
How did you get moss on it so fast??
teomannaskali is offline   Reply With Quote
Old 09-08-2013, 07:14 AM   #2120
Plane Dr
Plane Dr's Avatar
Oddometer: 866
Rear drive hub install.
01/09 DRZ470SSW more bits than necesary
2005 R1200 GS AKA The Mothership
2003 Z1000 Nuclear Pumpkin (gone)
86 RG500WW (gone)
Bikes are like women. What you think you want, and what you want, change after the first ride.
Plane Dr is offline   Reply With Quote
Old 09-08-2013, 07:15 AM   #2121
ClearwaterBMW
The Examiner
Oddometer: 5,972
love that high-resolution picture. Quite hysterical, actually
Greg
Old 09-08-2013, 12:44 PM   #2122
johnny80s
johnny80s's Avatar
Oddometer: 267
Bought a GSA kick stand, center stand and silver plastic from Motoree.
I know Clearwater you want a picture.
Old 09-08-2013, 01:16 PM   #2123
mikegc
mikegc's Avatar
Oddometer: 1,662
What have you done to your GS or GS Adventure today?
Looks like this.
A sunset or sunrise photo would be nice, too.
Mike
IBA 25881
Duty- Honoring a Friend
mikegc is offline   Reply With Quote
Old 09-08-2013, 01:36 PM   #2124
ClearwaterBMW
The Examiner
Oddometer: 5,972
you better I would
that's just how boring my life has become
Greg
Old 09-08-2013, 01:58 PM   #2125
Musashi50
Musashi50's Avatar
Oddometer: 39
Had Touratech Bar Risers installed. So far, I like 'em just fine. Interestingly pushing the bike off the center stands seems easier, more controlled now. Probably just my imagination! Also, installed a "Bead Rider" I had laying around. Sure was nice on my ride home from work today. Got to feel some airflow "down there". Much nicer than the stock seat alone. YMMV...
Cheers!
~Bruce~
"So, where did I hide my keys... This time?"
Musashi50 is offline   Reply With Quote
Old 09-08-2013, 04:00 PM   #2126
Mr Head
PowerPoint ADV
Mr Head's Avatar
Oddometer: 7,698
Changed oil in the engine, trans and F/D for the final time.
Tweaked the TB balance every so slightly to perfect. Rode down to the coast to warm up the oil. A little light cleaning and the damned thing is perfect.
What was I thinking?
Come Wednesday it's not my bike anymore.
So, yesterday more shopping.
...Dick
"You don't go to Mongolia for the food." - Sebastian & Kim
2010 KTM 990 Adventure R
My Life With The 990R
Smugmug
Mr Head is offline   Reply With Quote
Old 09-08-2013, 04:28 PM   #2127
krellheat
Pepsi Challenged
krellheat's Avatar
Oddometer: 2,119
Discovered a leak from the oil cooler where the tabs are spot welded to the cooler.
Just remember, once you're over the hill, you begin to pick up speed.
Devil's advocate. Hell conscientious and informed and downright argumentative dissenter.
krellheat is offline   Reply With Quote
Old 09-08-2013, 04:30 PM   #2128
tjt94
Oddometer: 610
I put my rebuilt under warranty ABS pump back in my '01 1150. It tok about an hour including bleeding the lines. Module Master has been great to me. I paid unde $300 a year and a half ago for a rebuild and this has a 5 yr warranty. BMW wanted $2500 for a new one and only warranted theirs for a year. I put 20000 miles on since the rebuild and it just started to throw faults again. MM found more bad solder joints on the circuit board. I'm not surprised since the bike is not garaged and in outside in 120 degree heat often. Anyway, it is fully functional and probably will be for many years.
tjt94 is offline   Reply With Quote
Old 09-08-2013, 06:22 PM   #2129
Gruesome
Alter Heizer
Gruesome's Avatar
Oddometer: 957
Cool2 LED strips on the handguards
I finally installed the LED strips on the handguards on my R1150GS. I bought a spool (5m) of these LEDs over a year ago (edit: almost two years ago!), and had connectorized and sealed them already a while ago. Now I finally installed and connected them. Initially I was thinking of hooking them up between +12V and the positive tap of the turn signals, but now I just connected them in parallel to the parking light. They are pretty bright.
I cleaned the handguards with some prep solvent (leftover from painting my cases mandarin yellow), so hopefully the adhesive on the LED strips will hold up.
Here are some pics:
Wiring (fully connectorized):
That parking light is a bear to get to, and of course the bulb gave up in the middle of installation. Radio Shack had some 14V 200mA that fit.
With high beam:
Added: These strips are about 0.24W/LED, 14.4W/meter. They can be cut every 3 LEDs or 5cm. With the corner wrap-around, my strips are 18 LEDs = 30cm = 1ft long, which makes them about 5W each. They have three 150 Ohm series resistors (labeled '151') per group of three LEDs. I think these 5050 SMD LEDs put out about 50 lumens/Watt, but I'm not sure.
Picture at dusk, to show the amount of light thrown back on the bike, and to the side:
Added: post with details for connectors etc.: http://www.advrider.com/forums/showp...2&postcount=17
Gruesome screwed with this post 02-08-2015 at 07:32 AM Reason: add strip dimensions
Gruesome is offline   Reply With Quote
Old 09-08-2013, 06:30 PM   #2130
ClearwaterBMW
The Examiner
Oddometer: 5,972
You did a very nice job with that but I want to ask you: at night when those LEDs are on is someone coming at you able to see your turn signals? I always get concerned when bright LED lights are so close to turn signals that they may cause oncoming traffic to be unable to notice you turning. please be sure of that for your own safety
Greg
Times are GMT -7.   It's 10:03 PM.
