Old 09-08-2013, 06:21 PM   #8686
steveWFL
steveWFL's Avatar
Oddometer: 1,344
Just some BS. "Short trip" coming up.
Refused to pay $40-50 to mount my rotopax spare fuel tank onto the KLR's wolfman luggage rack. This project then went "KLR on the cheap" style
Instead I got $16 worth of parts/nuts/bolts and fab'd my own.
I usually shop Target, but Teressa finds this cutting board at the Wal-mart store
So under the knife it goes..... and the cut off pieces fall right into the recycle bin. Not that I'm all green like that....
Couple of dollars worth of Ace Hardware bolts and these weird rubberized straps that allowed us to bolt a flat object to a tube and we're there.
Added the part of the rotopax tank that gets mounted to a plate. Then I added some padding strips for no other reason than piece of mind. Plus i like it because the rotopax/wolfman plate didn't have such
Now I'm ready to throw over the wolfman soft panniers on and roll. With 50-60 miles, 1 gallon more gasoline for the desert (in addition to the KLR's already 6.1)
KTM EXC - in 530 flavor
'10 Concours14 with >85,000 miles and ticking'
'99 ZX9R Ninja - rolling retro style
'99 ZX9R - because I like the other one so much
'08 ZZR600 minty
steveWFL screwed with this post 09-08-2013 at 07:42 PM
steveWFL is offline   Reply With Quote
Old 09-08-2013, 07:06 PM   #8687
xrmattaz
sputum is my bread/butter
xrmattaz's Avatar
Oddometer: 3,205
Originally Posted by Tommyg2bad View Post
Those look like Happy trails racks. Should hold up to whatever you bolt to it. Mine had rocket boxes bolted to it when I got it. I went with Wolfman bags and they work for them too.
I just want some hard locking bags, as I will use this bike primarily as a commuter and grocery getter. 90% sure I'm going to bolt up some Pelicans or similar.
'00 KLR (#6 since '88, keeping this one!)
'06 Road Glide
Coupla street legal quads, gotta love AZ!
'06 Gas Gas TXT300 Raga (gone...back surgeons fault)
Many many others since 1976, first 3 "cars" in my life were motorbikes.
xrmattaz is offline   Reply With Quote
Old 09-09-2013, 12:45 PM   #8688
steveWFL
steveWFL's Avatar
Oddometer: 1,344
I just received an ebay pelican IM2600 case I'll be using as a topcase in addition to wolfman panniers, FYI it appears to be a top-notch product. If i wasn't using soft panniers I'd be purchasing some pelicans that access from the top
'08 ZZR600 minty
Old 09-09-2013, 02:05 PM   #8689
Danger4u2
'04KX500isDanger4u2
Danger4u2's Avatar
Oddometer: 665
I have pelican cases from caribou. Side opening, they do lock to the bike and the lids lock.
I don't like the fact that something is always getting in the hinge area.
I would like the top load but only with the inner bag other wise your digging in a jumbled mess.
Looks like they only make them for the 2nd Gen. now.
http://cariboucases.corecommerce.com/
Go faster than everyone.
Only worry about what's in front of you.
Danger4u2 is offline   Reply With Quote
Old 09-09-2013, 02:13 PM   #8690
xrmattaz
xrmattaz's Avatar
Oddometer: 3,205
I really really like the olive green aluminium night vision goggle box as a top box.
Found 'em for $40. shipped.
'06 Road Glide
Old 09-09-2013, 02:28 PM   #8691
steveWFL
steveWFL's Avatar
Oddometer: 1,344
are they heavy?
'08 ZZR600 minty
Old 09-10-2013, 02:48 AM   #8692
griffo1962
griffo1962's Avatar
Oddometer: 1,553
Originally Posted by BLU_FZ1 View Post
Gents,, what have you guys used to fill the 2 holes in the slide? I need to do this as i was blown into the weeds by a Hyosung 250
liquid epoxy
griffo1962 is offline   Reply With Quote
Old 09-10-2013, 09:44 AM   #8693
misterjack
Universal
misterjack's Avatar
Oddometer: 51
KLR650 shift lever
Time to replace my shift lever. Need something sturdier that can withstand a few drops offroad. looking for any advice.
thanks
tire tracks on the moon....
misterjack is offline   Reply With Quote
Old 09-10-2013, 10:14 AM   #8694
sandalscout
blah blah blah
sandalscout's Avatar
Oddometer: 2,252
thanks
I've been happy with my Moose:
http://www.motorcycle-superstore.com...ift-Lever.aspx
It's withstood a number of drops with no problem, and mine it 1" longer, so it's more comfortable with my size 12 boots.
sandalscout is offline   Reply With Quote
Old 09-10-2013, 05:41 PM   #8695
bdcorrigan
bdcorrigan's Avatar
Oddometer: 648
Has anyone experienced their bike turning over but not starting. Choke on or off fuel in the tank it won't start. After a few tries of turning it over finally started with the choke off and I slowly put the choke on to bring the idle up above 1k rpm's. Never had this problem yet, thoughts?
bdcorrigan is offline   Reply With Quote
Old 09-10-2013, 11:16 PM   #8696
Dan Diego
Oddometer: 964
Vacuum hose off or lose? Sounds like the culprit.
I have no interest in living a balanced life. I want a life of adventure.
Dan Diego is offline   Reply With Quote
Old 09-11-2013, 02:26 AM   #8697
Newfiebullet
Newfiebullet's Avatar
Oddometer: 193
It's funny you mention this.
For the past 3 weeks or so my bike has been incredibly difficult to start when cold.
If I give it full choke it just floods. Give it partial choke and it'll catch, but not run. Then go with no choke, and basically let it chug and chug, as it starts to catch but won't run. Eventually it'll start to run, and after 3 or 4 times of that will stay running.
Once it's warm it starts perfectly.
I haven't posted about it, because I know my carb needs a rebuild, and I have the parts on order to do it, and I'm assuming/hoping that that will solve the issue.
Right now I'm considering driving the truck to work because it's too embarrassing trying to start the thing at the end of the day to come home. Plus I'm starting to worry that I'm going to burn out my starter.
Newfiebullet is offline   Reply With Quote
Old 09-11-2013, 06:44 AM   #8698
misterjack
Universal
misterjack's Avatar
Oddometer: 51
What is this little lock box on the back of the klr called and where can I find one?
Old 09-11-2013, 06:55 AM   #8699
sandalscout
blah blah blah
Oddometer: 2,252
That's the stock tool kit storage location. Good luck finding a used one, I could never find a complete, unbroken one for sale when I wanted to replace mine.
The box, screw, nut and strap are about $50 from online OEM parts house (RockyMountain, BikeBandit, etc).
Old 09-11-2013, 07:16 AM   #8700
XDragRacer
Oddometer: 3,188
Just curious; WHICH parts have you ordered?
Don't know of a Kawasaki carb rebuild "kit," rather--seems like all carb parts are catalogued individually.
Just wondering, what parts you would replace performing a "rebuild."
XDragRacer is offline   Reply With Quote
Times are GMT -7.   It's 04:37 PM.
